How do i make multiple copies from my epson tx 121?
I want to make more than 1 copy of a document.
mastersaintx
  • 928 Answers
SOURCE: epson cx3900
The simplest way to do this is to scan the file then save it on your computer and then attach it to an email.
You can refer to the link below. Go to page 15
http://files.support.epson.com/pdf/cx38__/cx38__qr.pdf
Its not the exact model but it will suffice.
Posted on Aug 22, 2008
  • 15 Answers
SOURCE: CX7400 Epson printer will only print one copy at a time
If you are printing from your computer, in the print options select how many copies you would like to make in the preferences.
Posted on Mar 01, 2009
SOURCE: My hp 1320 prints multiple copies instead of one copy
Go to "printers and faxes."
Right click on your printer and select "Printing preferences."
Select "Advanced" tab
Double click "paper output"
If "Copy count=2" then change to 1 and apply
IF IT ALREADY IS SET TO 1 THEN:
Set "copy count=2" then APPLY
Repeat the above and now set "copy count=1"
The process of setting and resetting the copy count fixed my issues.
Posted on Mar 01, 2010
destom
  • 126 Answers
SOURCE: kyocera fs-2020d doesnt do multiple copies of documents
This message often shows up when the memory is full from one document (normally a large file) to fix it you have to add external memory
Posted on Nov 09, 2010
ruwidperd372
  • 279 Answers
SOURCE: using epson stylus tx 121,
You need to install Epson Twain Driver, go to this link to download:
http://download.cnet.com/Epson-TWAIN-Scanner-Driver/3000-2118_4-10007006.html
Good luck
Posted on Feb 05, 2011
How to recover fax in memory
Your fax can print a list of documents stored in memory, along with the transaction number (TX/RX NO.) of each document. Once you know the transaction number of a document in memory, you can print it or delete it.
1 Press [Menu].
2 Use [up] or [down] to select , then press [Start/Copy].
3 Use [up] or [down] to select , then press [Start/Copy].
? Printing a Document in Memory
1 Press [Menu].
4 Use [up] or [down] to select the transaction number (TX/RX NO.) of the document you want to print, then press [Start/Copy]. The LCD toggles between and .
If you are unsure of the transaction number (TX/RX NO.), print a list of documents in memory (see page 34).
5 Press [*] to print the first page only, or press [#] to print all pages of the document.
The fax prints the document.
Jan 18, 2011 | Canon FAX-JX200
Problem printing multiple copies of a single page document
I have a similar problem with an old HP LJ1300. They have not updated the driver correctly and don't intend to fix it. I can't find any reference to AcuLaser C900 on Epson's support page. So maybe they stopped supporting the C900.
May 06, 2010 | Epson AcuLaser C900 Printer
Auto Document Feeder copier problems
The scanning glass probably needs cleaning.
Jul 31, 2009 | Epson ACULASER CX11NF All-In-One Printer
I want to copy a document
How often do you need to "copy" documents. Do you have a document scanner?  Your Epson is a printer.  You'll need a scanner to scan a document into your PC then you can print it out on your Epson.  If you only need a copy once in a blue moon, and you don't have a scanner, save yourself a few bucks and just go to Kinko's or maybe even your local grocery store or library and run your copies there.  They probably cost about 25 cents a page.  A new scanner will run you about $100 bucks.  If you decide that you need a scanner, you might even want to consider investing in a multi function printer which will scan-print-copy-fax.  Hope this helps.  If so, please remember to rate my solution.  Thanks.
Mar 14, 2009 | Epson Stylus Color 600 InkJet Printer
How to copy with Epson SX 100 pleaae?
first of all on the printer.then place the document to be copied (the orignal)on the scanner glass.then press the option button copy on the printer.then press in which mode you want.if you want the document to be copied in colour press the colour button on the printer.if you want the document to be copied in black press the black button on the printer.and place the blank paper in the paper tray ,thats all.
Feb 25, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus cx7400 wont print but one copy at a time
Epson Stylus S20, when I alter number of copies required from 1 to say, 8, it prints only ONE. Why? wgaynair@gmail.com
Jan 24, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Scanning multiple copies
The trick is to put the scanner in PROFESSIONAL MODE !!!!! Select that option in the top right corner of the Epson Scan application when it first opens up.
http://files.support.epson.com/htmldocs/gt25__/gt25__ug/projs_1.htm
Dec 21, 2007 | Epson Stylus CX4200 All-In-One InkJet...
Copy feature on Epson CX 4800 doesnt' work.
call epson and tell them your problem, the can help you, most of the time epson will replace the printer for you for free.
Nov 28, 2007 | Epson Stylus CX4800 All-In-One InkJet...
131 people viewed this question
k24674
jasbo
jasbo
