Question about Emerson EWD7003 DVD Player
My DVD player is, quite literally, on the blink...
I own an Emerson DVD player hooked in (correctly) to a Symphonic 25-inch television with a built-in VCR. When I play VHS problemo. However, whenever I play DVDs, the brightness fades from normal to much darker every 20 seconds, then back again. There are no other glitches. ringing crystal. No scratches on the DVDs, nor finger prints. I was bombing around on another forum and they said color fade, if that's what this is, occurs when a DVD player is hooked up through a VCR. If that's the problem in this case, then it's quite a quandary, as the VCR is built into the TV. Also, I already tried a DVD cleaner-DVD and it didn't help, either. I used both the micro-scrubber cleaning function and the color-fade function. Nada! I'm a huge film buff. I need my DVD player. Please help!
Re: My DVD player is, quite literally, on the blink... - Emerson EWD7003 DVD Player DVD & Blu-Ray Players
Get a a/v converter and hook up to tv part
Posted on Jun 10, 2007
  • 50 Answers
Hi Your problem is Copy protection on your DVD's! Without going into techno-bable, your DVD player detects that you are connected to a VCR, (You have no choice in your case as it is built-in), there are methods such as "Copyguard" and "Macrovision" that try to stop you from copying your favorite DVD onto VHS. The audio is left alone, but the video will go bright and dim, and the colors will be messed up, making the result un-watchable. You will find that the cheap DVD's you get for a couple of bucks at the discount store will play fine, as it would be too expensive to protect them. There are "little black boxes" available as "video stabilizers" that will cure this problem, (but you didn't hear that from me!),otherwise you must connect into a t.v. without a built-in VCR. P.S. Make sure the t.v. you switch to has RCA type A/V inputs on it, as you will have to purchase a separate RF modulator otherwise. Good Luck!
Posted on Aug 15, 2006
3 Suggested Answers
  • 15 Answers
SOURCE: green light blinks and player will not play dvd or vcr
take it to any repair shop and have them llik it over. It probaly has something stuck in the cassette area. th repair may cost $20 to $50, most of that is what the public calls a "walk in the door fee." If your comfortable doing it yourself just take the lid off and remove whatever looks like it doesn't belong there, like pet hair or something a child could have stuck there, ie a toy or a pen. Hope this helps.
Posted on Feb 01, 2008
SOURCE: Philips Universal Remote with Emerson VCR/DVD Combo
There you will find all needed information
Posted on Jul 05, 2008
SOURCE: Need code for Emerson TV,DVD,VCR Combo
called comcast
Posted on May 28, 2009
0 characters
3 Points
I have a 39 inch Emerson hdmi led tv and it is hooked up to Directv. I'm trying to hook up my daughters DVD player it is a Sv 2000 DVD CD player e everything is hooked up we get sound no picture.
hi try using RCA cables to make sure youre connections r not the problem..plug the rca cables n the output of dvd then into tv input & set tv input to AV .good luck
Sep 02, 2015 | Emerson DVD & Blu-Ray Players
Trying to hook up an emerson dvd player to tv and its not working? older tv it has no cable hook up or control box for channel set up, shouldnt the dvd player still be able to work though?
IM GUESSING THIS MIGHT BE AN RCA TELEVISION? if you dont have an rca in hook up on the tv give up and buy a new tv or you can find an older item what it is is a switch that has an rca input and a coax output it was used to hook up the older video game systems it is still sold in most stores and that will work if you do have rca inputs and lost the remote you need to get a universal remote to switch the input on certain older rca tv's you could go to channel 00 and it would set it to the input with the switch you shoudl be able to use it by putting the tv on channel 3
Feb 28, 2010 | Emerson EWD7001 DVD Player
Who makes Durabrand portable DVD players? I can't
Durabrand is made by Funai along with:
Funai, Symphonic, Sylvania, Emerson, Aventura, ESA, Magnavox, Insignia, Philips and Misakai
Unfortunately, all of these brands are to be avoided if you can afford to ignore the low prices. Equally 'unfortunately' because of the potential recurrence of failures, many places won't accept them for repair and you are generally better off replacing the unit.
Don't like starting off your new year with bad news but . . .
Jan 01, 2010 | Durabrand 8.5'' Portable DVD Player
I'm having an odd problem with my Sylvania DVR90VE. My new DVD of Transformers Revenge of the Fallen's second special features disc will only play some selections on the disc, not most. It's a 7.8GB disc...
> Do I need to update the firmware?
If you are lucky; Sylvania is a branch of Funai which is the 'bottom of the barrel' on quality so it may be just another case of Funai-ism.
Other brands belonging to Funai:
Symphonic, Emerson, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, Philips and Misakai
I earned part of my income from servicing consumer electronics some years ago and historically, Funai gear has been among the worst built.
Dec 28, 2009 | Sylvania DVR90VE DVD Recorder/VCR
Magnavox mwb multiregion hack
icon_minipost.gifRegion code posted by paulstoner75, January 25 2008:
This player is manufactured by the Funai Corporation for Magnavox. This is a very basic DVD player, and despite it's many features, it is not bad for a $31.99 player from Wal-Mart, however...
After speaking with the Funai Corporation Support Line, they have no problem giving out region hack codes for other models they make such as Symphonic, Emerson, as long as the user understands if you make a mistake and something happens, not their fault, etc..
For this basic player - No codes exist.
Jul 24, 2009 | Philips Magnavox DVD Player MWD200F
Symphonic WFR205 DVD recorded but not finalized
I have similar problem. I have recorded all of my old tapes on a DVD-RW disc (lots of time spent on it) and as I wanted to finalize them - it would display an recording error. Recently I purchased a new Sony blue ray player and I realized it would play the not finalized discs. I am still looking for a solution how to record these memories on a PC so I can edit them.
Jan 30, 2009 | Symphonic WV806 DVD Player/VCR
It will depend on the signal you get from television stations, as well do you have this running through a stereo, the t,v. I mean. Depends on a number of things as D.V.D's are recorded a certain way such as with "Dolby THX" for instance. If I am right, you are running your television with built in dvd through a home stereo, am I correct?
Aug 23, 2008 | Insignia DVD & Blu-Ray Players
Need dvd code for symphonic WF104 I am using a scientific atlanta remote control
I'm guessing you have tried these already, but, you can try:
2017, 2213, 1029, 1134, 1150
if it is the ER1
014, 186
If that doesn't work, try a search by doing this:
Turn on the device.
2. Press and hold SELECT and the appropriate mode key (CBL, TV, VCR, DVD, or
AUX) until the mode keys blink twice. For example, to search for a TV code, press
and hold SELECT and TV at the same time.
Note: If you reassigned mode keys, you may, for example, press SELECT and
VCR to search for a TV code to assign to the VCR mode key.
3. Press 9 9 1. The mode key you selected in step 2 blinks twice.
4. Point the remote toward the device, and press PLAY . The remote automatically tests each code in its library, beginning with the most common codes. The mode key blinks once each time the remote transmits a new code. The mode key
blinks twice when it reaches the last code.
5. As soon as the device powers off, press SELECT.
6. Verify the new code is correct by pressing POWER.
7. Did the device power on again?
• If yes, press SELECT to assign the code.
• If no, complete the following steps:
a) Turn the device on.
b) Press channel up or channel down to step forward or back to the correct code.
c) When the device turns off, press SELECT to assign the code.
Apr 03, 2008 | Symphonic WF104
Hook up dvd(nexxtech edp3110) to emerson ewv403 and then to sanyo tv(ds13204)
Hey why dont you use a video sender incase your intrest is the picture and then search the channel on tv
Mar 21, 2008 | Emerson EWD7003 DVD Player
Emerson EWD7003 DVD Player Logo
371 people viewed this question
Top Emerson DVD & Blu-Ray Players Experts
Level 1 Expert
Are you an Emerson DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
