Question about Garden
How do i adjust the steering levers on dixon zeeter 30
2 Suggested Answers
ftw1952
  • 10319 Answers
SOURCE: I have a dixon zeeter
the rod should have a lock nut on it so you can adjust the foward gear. Upon reaching the best setting lock the nut to hold in place
Posted on Jul 16, 2011
How do i tilt the 2007 chevrolet aveo lt steering wheel for my own comfort
Steering Wheel Adjustment .The lever is located under the steering column, slightly to the left. To adjust the steering wheel: 1. Pull the lever down. 2. Move the steering wheel up or down into a comfortable position. 3. Pull the lever up to lock the wheel in place. Do not adjust the tilt lever while driving.
Mar 11, 2017 | Chevrolet Cars & Trucks
Husqvarna zero turn mower steering problems how to adjust neutral and balance steering
There is adjustments on both steering arms located under the seat. You can make the adjustments by lifting the unit's wheels off the ground and determine if the are "creeping" when the unit is running. Adjust the linkage until neither wheel creeps. Then the tracking can be adjusted by turning the screws located at the base of the steering levers.
Note, the levers do not return to neutral automatically.
Jun 10, 2016 | Husqvarna Garden
Why won't my transmission re-engage on my Dixon Speedztr 30 lawn mower?
Sounds like a broken or disconnected cable to the drive unit trace the cable run to the drive just make sure all connections are sound.
Jun 22, 2014 | Garden
What weight of hydraulic fluid is used in a dixon lawn mower
The motor takes 30 SAE. the drives take 20/50 SAE motor oil. I contacted the manufacturer of the hydro gear drives to find out what was used when I rebuilt one. There is only one manufacturer of all hydro gear drives. Their recommend Mobile 20/50 SAE.
Apr 05, 2013 | Dixon Ticonderoga NEW 61" DIXON ZERO TURN...
My 12 year old Dixon ZTR mower turns to the right only slowly. Left turning is normal. The right steering lever has to be held farther forward than the left one to go in a straight line. Repair shop...
Hi, first check your tire pressures are equal then check/replace wheel drive belts and pulleys for uneven wear. If all ok adjust the drive link arms until it travels straight. Regards Phil.
Jun 14, 2012 | Garden
Adjust height of Prizm steering wheel
Some Geo Prism's (and sister car Toyota Corolla) have adjustable steering columns, and some do not. The adjustment lever is on the left side of the steering column, underneath the turn signal arm. Pull this lever out...away from the steering column, and you will feel the entire column loosen for up and down positioning. To re-secure after fine tuning the desired height...push this lever firmly back into position beside the steering column. If your Prism does not have this lever...your car is not equipped with the adjustable optional column. Hope this helps.
Mar 19, 2012 | Ford F-350 Cars & Trucks
I need a left rear axle for a dixon mower it is bent so the chain jumps off, and a diagram of the rear assembly. It is blue with the levers between your legs, it has a 12hp motor. I am not sure what year...
You can eventually find your manual here:
http://www.dixon-ztr.com/node2171.aspx
There are a ton of manuals.... on that page. Looks like it will be a tedious hunt with out a model number.
If the link does not work go to
and click on support.
If you can come up with a part number you might be able to get it here:
http://www.lawnmowerpros.com/Dixon.htm
They also have parts manuals on this page:
http://www.lawnmowerpros.com/Dixon/Dixon-Parts-Diagrams.asp
Thanks for using FixYa.
Kelly
Mar 09, 2010 | Mtd LAWN MOWER PART # 903-0382 AXLE...
Steering Adjustment for a Dixon ZTR
Try the 3310 as pictured below
May 31, 2009 | Garden
2000 Mercury Villager: Is there a shift lever adjustment? When placing foot on brake pedal and pulling shift lever rearward it doesn't feel like the transmission is completely disengaging and it is...
You may have a loose shift linkage in the steering column. Remove the upper and lower plastic covers behind the steerong wheel (5 or 6 philips head) and see if you have any loose torx head or allen head screws. Ea
rlier models had this isue.
Also, go to this site for Villager Quest help.
http://autos.groups.yahoo.com/group/villagerquest/
Here's adjustment procedure too
SECTION 307-05: Automatic Transaxle/Transmission External Controls 2000 Villager Workshop Manual
GENERAL PROCEDURES Cable Adjustment —Shift Control
  1. Place the gearshift lever in PARK (P) position.
  1. Raise and support the vehicle. Refer to Section 100-02 .
  1. Remove the splash shield.
  1. Loosen the shift cable nut.
  1. Position the shift linkage in PARK (P) position.
  1. Tighten the shift cable nut.
  1. Move the gearshift lever through the entire shifting range.
  1. Verify that the engine will crank with the gearshift lever in PARK (P) or NEUTRAL (N) position.
  1. Adjust the transmission range (TR) switch as necessary, refer to Section 307-01 .
Item Part Number Description 1 043B13 Driver side air bag module 2 — Steering wheel nut 3 3600 Steering wheel 4 — Radio volume control cover 5 — Air bag sliding contact electrical connector access panel 6 — Cruise control cover 7 14A664 Air bag sliding contact 8 13K359 Multifunction switch 9 — Tilt wheel lever 10 13318 Turn indicator cancel cam 11 — Steering column assembly 12 — Steering column mounting bracket nuts (4 Req'd) 13 3C695 Lower column shroud 14 — Steering column opening cover nuts (3 Req'd) 15 — Steering column lower yoke bolt 16 3N725 Steering column lower yoke 17 — Steering column clamp bolt 18 3C695 Upper column shroud 19 7210 Gearshift lever
May 05, 2009 | 2000 Mercury Villager
Garden Logo
248 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
