Question about Sewing Machines
How do you thread a Elna mini opal sewing machine
techworm
  • 56 Answers
SOURCE: thread getting caught around bobbin case
It isout of time you need to time it.by adjusting the screw on the bobbin holder turn it left or right and the tension knobe and foot tension.
Posted on Nov 12, 2007
SOURCE: Janome M100 mini sewing machine
Providing you have checked to make sure the needle is in correctly, if the machine will not pick up the thread then the machine will need retiming.
Posted on Jan 22, 2008
SOURCE: Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Posted on Aug 23, 2008
SOURCE: Elna SU missing stiches and breaking thread
it sounds like the needle hook timing is out. You need to get the needle in the lowest position and measure the gap from the needle to the hook point on the bobbin shuttle. It should be 1/4". You will need to remove the foot and foot plate to be able to see. I use a 1/4" drill bit as a gauge. If you need to adjust it, you will need to remove the free arm cover to the right of the foot and loosen the 2 allen head screws that hold the drive gear. Adjust the gap, tighten the screws and retry. Usually if the needle catches the thread to early, it will make a bad stitch and the upper thread will break. If it catches to late, it will make thread loops and the machine will skip stitches. Good luck, these are a good machine and worth fixing. Phil
Posted on Nov 13, 2008
  • 1116 Answers
SOURCE: do not know how to thread bobbin on elna
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_Supermatic_threading_diagram.htm
Posted on Feb 21, 2010
Testimonial: "Immensely helpful thankyou very much"
How do you adjust the tension control on an Elna lotus SP
The tension dial is on the front of the machine right above the needle. The higher the number, the tighter the tension is applied to the top thread. HINT: When threading the top thread, ALWAYS RAISE the presser foot throughout the entire threading process. This allows the thread to seat completely in the tension disk. Tension is correct when the top and bobbin threads meet in the middle of the fabric.
Elna Lotus Instruction Booklet
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
Elna SP ST SU sewing machine repair tips (I use liquid Tri-Flow Synthetic Lube or silicone spray to loosen parts seized from old oil. Do NOT use WD-40, cooking oil, motor oil...)
Apr 29, 2017 | Elna Sewing Machines
I have an old Elnita 130 sewing machine with no manual. How to I thread it? It appears to work but shows signs that I did not thread it correctly.
elna make elinta machine and a 140 is the same threading as a 130
try entering the sites as most I go to require an account ( free) to procedure to read or down load and that process would be better for you
I went google and typed in--user manual for elinta sewing machine model 130-- and the sites show 130, 140 and more so select a site and go from there
thee is also a www.youtube.com>watch that runs for 1.29 and shows how to thread an old elna sewing machine
you might pick up a clue from that film
Dec 16, 2016 | Elna Sewing Machines
How do i adjust the tension on elna 2003?
Not quite sure what you are asking. The upper tension is governed by the tension disk. Higher number is tighter, lower number is looser. Usually, the mid-range is a good place to start. Tension is correct when upper and bobbin threads meet in the middle of the fabric.
NOTE--ALWAYS RAISE the presser foot when threading so the thread will seat in the tension disk!
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
How to Adjust Sewing Machine Tension on Craftsy
Just FYI:
Why my Elna sewing machine is bad Or dont buy an Elna 2007
Dec 08, 2016 | Elna Sewing Machines
How do I thread elna model 1010
i sent you a link for a manual or you can try youtube for a video
Apr 18, 2013 | Euro-Pro Shark Mini Mechanical Sewing...
Elna 1500 sewing machine stitches dont interlock
it's possible that the machine is out of time
you can check with youtube or fixsewingmachines.com for video's on the problem
Apr 09, 2012 | Elna Sewing Machines
Sewing Machines Logo
319 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
