Question about Tag Heuer Link Automatic Chronometer WJF5112.BA0570 Wrist Watch
Tag heuer carrera twin-time automatic
Carrera twin time automatic
was running slow, was worn every day , one day not worn - stopped .will not start .tried wearing /shaking/ winding .any solutions?
escapement
  • 2334 Answers
SOURCE: tag heuer carrera - does not work timely !!!
There is no reason to panic. Your watch needs overhaul. Find your nearest watch repairer and ask to do the job. He will be able to tell you if there are any mechanical faults.
I do not think there are any and your watch will tick as brand new after overhauling it.
Mechanical watches needs overhaul every 5-7 years.
Posted on Jan 03, 2009
escapement
  • 2334 Answers
SOURCE: Tag Heuer Tiger Woods watch stops regularly
You should go back to the watch repair shop and ask for complete check-out of your watch. No watchmaker can return the watch to the customer without properly checking all the gearwork, timekeeping, battery power and all the features the watch has.
As your watch was serviced and the battery replacement took place, the executives of all the work done are responsible for all the faults your watch is having right now.
As watch repairs are quite expensive and time consuming, they (probably) will argue with you about this issue, but DO NOT give up, as these are YOUR consumer rights to ask for the job to be properly done (under warranty or paid by you). In case if you will be turned down, ask for FULL refund and find another shop.
If the repair shop is ready to undertake the job again, do not rush them, as the complete watch overhaul and check may take up to 6 weeks (this MUST be done at no any cost to you if you have the warranty or allready paid for the job).
P.S. I suspect that there is some fault in your watch geartrain, because if it is shooked or moved, the watch works, but when idle-it stops. That means the service of your watch was NOT DONE properly, and some failure or even dirt in geartrain was missed by the watchmaker (sometimes it happens- nobody is perfect!). This doesn't mean you have to agree with it, so, go and get your watch properly serviced and checked out.
Do not forget to rate, please.
Posted on Mar 09, 2009
escapement
  • 2334 Answers
SOURCE: quickly change date on my Tag Carrera
When yoy pull out the crown you will notice there are two clicks. You have to pull out crown to the first click only and then adjust a date by turning the crown.
Rate me, please.
Posted on Mar 13, 2009
dmbgo
  • 58 Answers
SOURCE: TAG Heuer Carrera Calibre 16
Hi
This is a warranty issue, the watch should not lose time like this. Take it back to the supplier ASAP
Cheers
Dave
Posted on Jun 22, 2009
Bob Gemmell
  • 209 Answers
SOURCE: I have a TAG HEUER Grand Carrera and the second has stopped
Are you aware that these are automatic watches and need to be moved to keep the watch going, kinetic energy winds up the movement which allows it to keep going, if it is left off your wrist and in a drawer or sat stationary it will stop. Shake it violently (without dropping it) and it will restart.
Posted on Aug 26, 2009
My Carrera automatic does not keep time, it loses at least 2 minutes a day
2 minutes a few months is OK but 2 minutes a day is too much. Bring it to service center for clean & service.
Feb 17, 2011 | Tag Heuer Automatic Chronograph Series...
My watch stops very often its tag heuer grand carrera calibre 17 rs2 automatic one what do i need to do for continuous running of my watch
It rather depends what you mean by "very often".
An automatic watch will run for 2-3 days before stoping if it is not used.
These watches thrive on being used and are best used every day.
It could be that your watch needs cleaning (I had one that was like that when I bought it and I had it cleaned and it ran for years after that).
Jan 21, 2011 | Tag Heuer Grand Carrera 17 RS CAV511B...
I have a Tag Heuer Grand Carrera. It worked perfectly for a year. But now, it doesnt work. When I shake the watch, it starts and then stops again after few minutes. I was told to wind it. But I dont know...
If your watch is "automatic" then would I be right in thinking you took it off for a few days and it stopped?
If this is the case (since most of the Carrera range are automatic, then the spring will have run down and needs re-winding.
You were correct in thinking that shaking it will re- start it but to keep it going you need to shake it gently from side to side for some time. (One supplier quoted 500 times!) be patient and keep wearing it.
Oct 14, 2010 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
Do Carrera automatic watch need a battery to run? because it stop me alot that why it just run for a few mins and stop forever until i move again
Automatic watches are mechanical (spring driven) and they are wound by the gentle swinging of the arm as you walk.
If yours has stopped, then it needs to re-wound by swinging it side to side (keeping the watch face level).
You will need to do this for some time (as many as 300 times, according to one maker).
When fully would the watch should run for about 3 days if not worn.
These watches thrive on use!
Apr 29, 2010 | Tag Heuer Carrera Automatic Chronograph...
Hi my tag heuer monaco has stopped working but when i wind it to the correct time it starts again for a while, what is wrong with it
I'm sure its an automatic - next time it stops do not set time just shake it and see it if starts again - automatics need to be worn most of the day to last during the night
Mar 04, 2010 | Tag Heuer Watches
Looking for an owners manual for my Tag Heuer
Go to the TAG web site ( insert "www.tagheuer.com/the-collection/" into your search engine).
Select "Carrera"
Select "men" or "women" as appropriate.
Select the model of the Carrera you have.
On the right of the screen you will see a list of options, select "user manual"
Adjust the magnification to make the text readable.
Jan 11, 2010 | Tag Heuer Carrera Twin Time WV2116.FC6181...
Hi
Cheers
Dave
Jun 21, 2009 | Tag Heuer Link Automatic Chronometer...
Seconds hand starts ticking then stops
Your band may be too loose. This is the model that moves when worn correct?
May 12, 2009 | Tag Heuer Automatic Chronograph Series...
Tag heuer carrera automatic wv211a
Your watch is a automatic. All automatics need to wind-up before being worn at first , or if not worn all the time. Automatics will work with-out being wound ,but will not keep time. Wind your watch at least 50 turns (using the crown) or shake about 150 times , and then try it . Automatics need that back-up power to insure it's accuracy.
Jun 19, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Tag Heuer Link Automatic Chronometer WJF5112.BA0570 Wrist Watch Logo
400 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
