Question about Frigidaire Dryers
Whirlpool LER3624EQ1 electric dryer will not start. you can hear the timer/setting switch clicking so it is getting power
It was working fine when I used it last night and now it will not come on. I check the breakers and they are all good. It is getting power because when you turn the nob for the setting/timer you can hear it making a faint clicking sound. I checked the door switch and it does not feel loose but I am not sure how to check to see if it is working or broken.
IFIXALL
  • 868 Answers
SOURCE: Kenmore 90 Series Electric Dryer will not run
Listen very closely to the dryer right as your pushing start.Is there any sound at all.Listen very closely because its critical on making the diagnosis.
Posted on May 22, 2008
rickzilla
  • 706 Answers
SOURCE: Whirlpool LER5644EQ2 Electric Dryer that won't start
Regarding model LER5644EQ2, here is a link to a parts website complete with an assembly drawing and parts list. In all probability,you have a blown thermal fuse and that will need replacing http://www.pcappliancerepair.com/model-display.php
Item #23 on the drawing .. a quick test would be to ( with power removed or disabled) measure the resistance across the two terminals and it should not be an open circuit or it is blown. The drawing shows exactly where it is and the parts list shows the item number/ cost and where to buy a replacement. Hope this helps..
Regarding model number is YLEQ5000PW1, you may have the same problem with your thermal fuse.. the parts website does not show a detailed darwing of your model but it should be similar to the other one I've cited in the location and thermal fuse.. The link I am sending is for the parts list for your washer and the thermal fuse.. http://www.pcappliancerepair.com/model-display.php
Let me know if that isn't the problem and we can look at other ways to zero in on a solution..
Hope this helps...
Regards...
Posted on Sep 11, 2008
AlmostBob
  • 550 Answers
SOURCE: Push to Start switch does not Start Kenmore Elite Dryer Mod # 11065944401
A likely cause is failure of the relay.
the start switch provides a current to energise a relay,
the relay latches open (draws energize current from switched circuit) until current path is broken by the timer or door switches.
if the wires have come off the relay(happens) or the coil of the relay has failed, there will be no start.
With plug pulled
trace the wires from the start switch, to the first device, looks like this 8fc4980.jpgmay be opaque. if any of the wires have come off refit them and retry start.
relay diagram looks like this 5a14628.gif test with meter for conduct between terminals labelled 85 86 (or Coil in other labelling standard),
or take to appliance parts store, can test and provide replacement on site.
Appliance part store will likely provide part labelled whirlpool, not a problem all the small parts are interchangeable
NOTE dryer relay may have up to 8 terminals,
2 for coil
3 (open close common) for each phase
Posted on Oct 30, 2008
WRMtech
  • 70 Answers
SOURCE: I have a Whirlpool Dryer # LER3624EQ1. I replaced
try changing the resistor. it moves the timer motor
Posted on Feb 24, 2009
lhendrix04
  • 11 Answers
SOURCE: Kenmore electric dryer won't start
DOOR SWITCH
Posted on Apr 20, 2009
Hello...i have a whirlpool dryer ler7646eq1...the dryer will not start...i can hear some action near the switches but dryer will not start at all...any idea where to start....it is getting proper power...
Here are somethings to check.
Make sure you have power and inspect power cord.
Check the door switch when you push in the door switch does it click? Try setting the timer to a different setting see if it works there. The next thing to check would be the thermal fuse but this would require opening up the cabinet.
Apr 08, 2010 | Whirlpool Dryers
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Whirlpool electric dryer will not start
should be on back behind rear panel on the duct assmebly
Aug 15, 2009 | Whirlpool Dryers
Whirlpool Model LER5644PQ0 won't start
Nope, it's the door switch and yes they are tricky little buggers! Good luck!
Apr 10, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
WON'T COME ON AT ALL.
you have not said anuthing about ohming out the start knob,and have you checked both legs on the power cord are getting 120 volts each?let me know what you find-mike
Sep 09, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
46 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
