Question about TallyGenicom Tally 5040 Passbook Matrix Printer
Driver TallyGenicom 5040 for windows7 - TallyGenicom Tally 5040 Passbook Matrix Printer
4 Suggested Answers
  • 127 Answers
SOURCE: TallyGenicom 5040 printer not detected by
check if your signal cable is working correctly and if the drivers have also been installed right.
thank you
wonder
Posted on Oct 08, 2009
SOURCE: tallygenicom 5040 passbook printer problem
Olivetti passbook printer not initialize.
Posted on Mar 07, 2010
  • 169 Answers
SOURCE: where to find tallygenicom 5040
For the latest drivers for the 5040 visit the manufacturers (Dascom) web site www.dascom.com
A direct link to the drivers is;
http://support.dascomeurope.com/index.php?option=com_docman&task=cat_view&gid=50&Itemid=48&lang=en
Posted on Apr 01, 2011
Paper jam error
wash the feeder rubber & clean the sensor of tray unit.
Dec 30, 2015 | TallyGenicom Tally 5040 Passbook Matrix...
How do I get Tally T5040 passbook Printer driver?
Check the manufacturers website (dascom.com):
http://www.dascomamericas.com/Support/Default.aspx?type_id=3&info_id=5&itemid=23&name=T5040&act=4
Jan 07, 2015 | TallyGenicom Tally 5040 Passbook Matrix...
Lipi printer 6605 driver
how can i instal tallygenicom 6605 driver in windows7
Apr 06, 2013 | Tally 6306 Matrix Printer
Where to find tallygenicom 5040 driver
http://www.tallygenicom.com/products/productdrivers.aspx?id=5990
Best, Hunter
Mar 02, 2011 | TallyGenicom Office Equipment & Supplies
How to install tally genicom 5040 driver
Have you tried removing the current printer and installing the printer again using the current driver on Tally's website? http://www.tallygenicom.com/products/productdrivers.aspx?id=5990
If this does not work, can you elaborate on the "problem" you are experiencing?
Best, Hunter
Mar 02, 2011 | TallyGenicom 5040 MSR-H - Passbook - B/W -...
Upgrade firmware from 1 to 2
Hi there
This is only the driver you need to update it because it not see the fonts, and if you have the new windows Vista or Windows 7 then this driver you have now not work, you need the right deivers for it
Feb 14, 2010 | TallyGenicom Tally 5040 Passbook Matrix...
TallyGenicom 5040 printer not detected by computer. what is the problem?
thank you
wonder
Oct 08, 2009 | TallyGenicom Tally 5040 Passbook Matrix...
Our 5040 tally printer is not being detected by a computer running on Xp and we have tried both parallel and usb cables.
I would guess that the printer is set to use the Serial Interface. I think this is the default interface setting on the 5040, hence the USB and parallel interface will be disabled.
You can change which interface is active from within the printer menu, once you have enabled the USB interface the PC should then detect the printer when you plug it in.
Details on entering the Menu on the 5040 can be found on the Dascom web site; http://dascom.firma.cc/support2/technical_notes/serial_matrix/5040/5040_tn004.htm
Tallygenicom 5040 passbook printer problem
Right, the problem lies in these triangles. They're part of what's called "lower paper feed unit" and are drien by an electromagnet to start/block when needed. This magnet has a tiny problem letting go, so the triangular wheels stop in wrong positions, blocking the paper. The best solution is to change the "clutch" with the latest UCL version (3), you'll know it for having aluminium toothed wheel rather then plastic ones.
Jul 16, 2008 | TallyGenicom 2280 Matrix Printer
TallyGenicom Tally 5040 Passbook  Matrix Printer Logo
2,013 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
