How fix wimax bm622 blank wan
BLANK WAN
5 Suggested Answers
furlough5
  • 28 Answers
SOURCE: the wireless wan in my aspire 6930 no longer
Hi minhvantran2. The first step is to click your wireless button. It doesn’t look like a button, but it is. It’s a little touch light that looks like a satellite dish, located just above your Num Lock key. Make sure it’s set to Wireless Lan enabled (should flash on the screen when you press it). If it lights up, problem solved. If it reads enabled, but doesn’t light up, then you’ve got just a couple more steps.
1) Go to Control Panel
2) Check to see that you are in “Control Panel Home” and not “Classic View”
3) Click on Network and Internet
4) Click on Network and Sharing Center
5) In the left column (small print) click on “Manage network connections”
6) Now look for your wireless connection.
To enable wireless:
1) Right click on your wireless connection
2) Click on Disable
3) A window will appear saying "Windows needs your permission". Click continue.
You should now see a pop up telling you to turn on wireless. Click on that pop up and it will "repair" the connection. This should solve your problem. Hope this helps!
Posted on Sep 12, 2009
rtrahan
  • 741 Answers
SOURCE: SonyVaio VGN-TZ398U/XC - Wireless WAN: Integrated Mobile Broadb?
You are not obligated to use Sprint. If you look at the first sentence it says "Optional Sprint....'
Yes you can use any carrier you want. Most new computers today come preload with AOL, Sprint, AT&T. In hopes you will choose one of them since it is already loaded, but not activated.
Posted on Feb 05, 2009
  • 742 Answers
SOURCE: wan connection
In newer laptops, turning on the WAN (wifi) radio receiver is done via keyboard key combination.
Look closely at the function keys. Do you see any wifi radio icon printed in orange or any color that is not similar to the normal key color? In some model, a wifi icon (looks like a wave like ")))" is in F2. Now pressing FN+F2 turns the wifi ON. Press and hold down the FN key and press F2 (or the key where the wifi icon is printed) to turn on your WAN.
Posted on Feb 08, 2010
maxcarson
  • 7627 Answers
SOURCE: how to solve blank wan in bm622
Can you be more specific? "blank wan"? May be this will help? http://www.youtube.com/watch?v=EVjjmkn41BU
Posted on May 01, 2013
Testimonial: "ined pasword of bm622 in admin user "
Blank wan mac address
You can't telnet based on the mac address you would be using the ip address. The mac is burnt into the device and isn't touched by a firmware update. If you did an update and the ip address changed, you can use a port scanner such as nmap to do a ping sweep and find the devices ip address.
Nov 17, 2013 | Computers & Internet
How to solve blank wan in bm622
Apr 30, 2013 | Computers & Internet
Cisco 861 behind Wimax Router from ISP
> WAN IP: 44.55.66.777
> ISP Router LAN IP: 111.222.333.174
> Cisco Router WAN IP: 111.222.333.175
Really? Each "octet" must be a value between 0 and 255, inclusive. A value such as '777' is not valid
Aug 27, 2012 | Cisco 861 Router
Wimax BM625 blank wan problem
buhusan ng gasolina at sindihan... tapos.. blankwan solve..
Sep 10, 2011 | Computers & Internet
HUWEI eCHOLife BM622 WiMAX CPE, I have connectoin from network but still no upload & download strenght. plz help me
I think, the problem is your AC/DC Adaptor Try to Changes it... Or if thus it work your modem is the problem...
Apr 16, 2011 | Honda GL 1100 Gold Wing Motorcycles
I brought new wireless router G ADSL2 4 PORT ROUTER but i dont know how to fix
Configure your router with below method then all messup will be fixed. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAn settings and set wan settings as internet service provider settings. Then click on wireless settings then enable wifi also enter SSID name and enable broad cast turn on wifi . If you want to secure wifi then enable WEP in wireless security .Enter code it is your password to connect wifi. Then connect internet cable to WAN port then you can use internet with it. Let me know if you need further assistance. Thanks for using FixYa.
Aug 04, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
(F5D6230-3) Wireless Router: i need to know how to change my mac address on my ...
In your browser's address bar, type 192.168.2.1.
By default, leave the password blank.
On the Belkin setup page, go to Internet WAN.Then go to MAC address. You may close your computer's MAC address or type a specific WAN MAC address, if required by your ISP.
I hope this helps!
May 16, 2010 | Belkin (F5D6230-3) Wireless Router
SPA 9000 VOIP - Need to log into system to change configuration.
No.
Try 'admin' and "blank".
Try "blank" and 'admin'.
Failing that, do the "reset to factory settings",
and then reconfigure your VOIP settings.
Apr 02, 2010 | Linksys Cisco SPA9000 VoIP Gateway - 1 x...
Setup with roadrunner
Connect Router - Desktop
Open RSP By typing 192.168.2.1
On the Left side under Internet WAN Click Connection
Type
Leave the password blank and click Submit
The Connection Type Should Be Dynamic
Click Next
There should not be any Host name & Click apply
On the left Side Click MAC Address Under Internet WAN
Click Clone And Click Apply Changes
It Should Work
Dec 27, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
How do I find the Public (WAN) IP Address on my router?
Step 1 Open a web browser (Internet Explorer for example) and type in the LAN IP Address of the router (default:192.168.0.1). The username is admin (all lowercase) and the password is blank (nothing). Step 2 Click the Status tab and click the Device Info button. Step 3 The Public IP address will be listed under the WAN heading in the IP Address field.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Computers & Internet Logo
1,399 people viewed this question
David Payne
David Payne
