Question about Acer AL1715 17" LCD Monitor
Dismantaling monitor from base
Hi i see your post i'm trying to do the same can you tell me how you did it? Thanks
  • 78 Answers
  • 558 Answers
Acer monitors are usually put together with 5 screws on the back of the monitor, 4 where you can see them and 1 under the pivot mount, this can be accessed by removing the pivot cover and then unscrewing the pedestal then you can get the last screw, after that you need to pry the half shells apart and then you can get at the cover for the power board the VGA screws and the power socket screws must also be removed.
Posted on Mar 22, 2009
Hi I have a peugeot 206cc 2005 can tell me how to change the radio aerial roof base thanks Carl
Have a look on youtube. Some good diy guys post how to's. Alternatively, find a manual on ebay or have a dig through google images.
Feb 27, 2017 | Peugeot 206 Cars & Trucks
My i2352Fh monitor has developed a white vertical line which tracks back and forth across the middle half of the screen how do i get rid of it? the screen is 3 months oldn
Thanks Melony - had exactly the same problem - your post above helped me fix it...... Here is how to fix it .
  • On the base of the screen press the Menu button (far right),
  • Then press < or > to get to the Extra (looks like a screwdriver and spanner) and press Menu again to Enter.
  • Press < or > until you have selected the RESET and press menu again to Enter.
The line should be gone. Close the menus and all should be fine. I hope this helps someone. I searched the internet and this was the only post that gave me a clue. Thanks again.
Dec 16, 2012 | AOC I2353FH 23" WIDE Monitor
Remove base from monitor
Hi my name is Roety,
I can help you with your issue ,
To remove the base first lay the TV face down on a soft quilt or couch, the base is held on with four screws that go into the back. With the screws removed pull the stand/base straight out the bottom.
Thats all
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Roety
Apr 29, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
Cant fix the base to the monitor correctly
Well, i have  user manual for your monitor, that helps you to know how to fix the base stand on the monitor.
please follow the below link -
http://h10032.www1.hp.com/ctg/Manual/c00834092.pdf
Good Luck!!
Thanks
Aug 13, 2009 | HP w1907 LCD Monitor
Attaching Samsung 2033 monitor to base
The solution is that you simply have to really force the monitor onto the base post. Thanks anyhow.
Jun 23, 2009 | Samsung 204T 20" LCD Monitor
Im trying to install agp...how do i disable the on board vga
Hi there.
Remember that if you are swapping from on-board graphics to a card you have to go into the BIOS and tell the machine that the primary graphics adapter is AGP/PCI Express.
Plug the VGA cable into the on-board graphics port, start the computer and enter the BIOS, tell the computer to use the AGP/PCI card as primary, press F10, save the changes and exit the bios.
The computer will try and restart so let it boot to post and turn it off, then put in your card and try to boot again.
Please post back if you need more help or advice.
Good luck and thanks for choosing FixYa!!
Jun 04, 2009 | HP Compaq Motherboard
Height adjust for Dell UltraSharp 1907FP 19" LCD Monitor
Is it stuck, or just not adjustable? Try setting it on a phonebook. I'm kidding. If it is an adjustable base, sometimes they need a little downward pressure before the button will depress and allow it to move upward.
Thanks,
Chris
http://BoiseLCD.webs.com
Jan 03, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Power on/off
Hi, Try using another outlet.
Does your AC power cord have any indicator lights which is why you know the power cable works fine?
Base on your assessment, I would say the power supply board on the monitor needs to be replaced.
Thanks,
Mike H.
Nov 02, 2008 | Acer AL1717 17" LCD Monitor
LCD problem with my laptop "Aacer aspire 3690"
Based on your posted image, it would look as if you have an LCD panel problem. You can verify this by attaching an external monitor to your laptop, using the Fn + F? keys to activate it. If the display is correct, then you have just confirmed that is the LCD display that is at fault.
There are readily available replacement parts, as shown here.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | Acer Aspire 3690-2196 Notebook
Dell 1900fp 19" moniter Ultrasharp
Button on the bottom back base raises and lowers, if not low enough then you can remove the base. removal button is back and center of monitor.
of course you will have to deal with a way to mount it then.
Dec 12, 2007 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Acer AL1715 17" LCD Monitor Logo
191 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
