Question about De Dietrich 22 in. DTI305W Electric Cooktop
De Detriech Induction Hob DTI304 - Right Hand Side Fault
I have a 3 Yr Old De Detreich Induction Hob (DTI304JE11), this has worked fine for the last 3 years, but has just started to flash and beep every few seconds on the right hand two positions.
If I power off the unit and then repower it after a few seconds both sides click, then the left is ok for use, but the right hand side has a dash flash on contol panel accompanied by a beep.
Any ideas?
  • 2 more comments
  • uhannibal Nov 04, 2008
    I have the same problem!
    The two right heating pads are not working, there is a red line, like it is locked or something right by the area where the level of heating is supposed to be (1-12), and there is a BEEB every 20th second, thats making me crazy... The left side is working fine, so it is not the electricity thats broken. You can hear the stove is working, like when a computer is overheaten..
    Can anyone help??
  • brennan19 Dec 14, 2008
    beeps every few seconds - dash light on both left hand plates. Right hand ones are fine
  • cbud10 Feb 25, 2009
    I have the same problem with my 3 year old De Dietrich induction cooktop. Can anyone tell me who they contacted for repair?
  • TAKIS Mar 30, 2013
    I have almost the same problem with DE DITRICH DTI304JE11. The left hand side is not working at al.
  • 63 Answers
SOURCE: Burnt induction hob
hi my name is mark, you can try softscrub or a glass cook top cleaner made by jenn- air or a genaric brand from the supermarket.
Posted on Mar 10, 2009
  • 42 Answers
SOURCE: Magnetic contol on Induction hob is very eratic,
your induction hob reqs.,special induction pans to make them work correctly.
Posted on Sep 28, 2009
SOURCE: Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Posted on Nov 06, 2009
jyackle5
  • 8197 Answers
SOURCE: Need to fit an induction hob (DTi714V) into a
Go to link below to see how to install.
http://www.dedietrich.co.uk/documents/dti714.pdf
Posted on Apr 19, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: we got an E3 error
Sorry to read about your problem, I hope this helps you out.
stop using and call a service company, before further damage occurs.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 23, 2010
My 5 ring induction hob works fine but has stopped showing H or h. Is it possible to turn this feature off accidentally or is it a fault?
do not think there is any OFF switch for the HOT indicator .if it all works why even worry about it .
Aug 08, 2015 | Neff Cooktops
Induction hob not heating up. What does 5h or SH error code indicate?
if they are not steel bottomed pans they will not work with induction hob test them with a magnet
Apr 07, 2013 | Smeg Cooktops
Induction hob neff T4243 has cracked will I need to replace it
Did you crack your hob by means of impact or did it happen on its own accord?
I have a neff induction hob and has just cracked in 3 directions while cooking this evening. I am just trying to determine if there is a common fault with this neff product or I am just unfortunate. Mine is under warranty and have a engineer coming on Monday, so have the whole weekend with no hob as I have been advised not to use it.
Many thanks
Feb 28, 2012 | Cooktops
Glass on neff t4243 induction hob has cracked
hi,
is it possible to replace a cracked glass on my Neff induction hob?
where would I get the glass for my Neff induction hob replaced?
is it very costly?
the model number is t4483x2/09
Right hand side of hob flashing reverse 9 or p inop on t4343 other side of hob working ok
right hand side hob not working. Flashing on and off with a sign that looks like a reverse 9 or P maybe?
Feb 28, 2011 | Neff 23 in. T4343 Electric Cooktop
When turning on my 2 year old Neff induction Hob T4543N1 it displays a full set of E errors and cuts out it does after two attempts corect itself and function perfectly
I had flashing Es every time I turned the hob on - got worse and worse until unusable. Neff help line useless - service call cost ridiculous. My problem was the capacitor on the 5 volt power supply had failed. 5 volt supply was at 3.8 volts. Replaced the capacitor and the hob's now perfect - a joy to use. Only helps if you are tech savvy and willing to open the unit, but may give you some hope or point you in the right direction.t
Jul 28, 2010 | Neff Cooktops
Eurokera hob - lights flashing, buttons not working
hi i have a eurokers ceramic hob and it has not worked in about a yr. it is touch screen and only 1 mth old when problem happend it was like it over heated and now when you turn it on it flashes on the dial i cnat make out it and the hob wont come on. pls help it is brand new and dont want to throw it out.HELP PLS
Dec 26, 2009 | Cooktops
Jun 18, 2009 | Cooktops
Induction hob switching off
check that the hob is wired correctly underneath 1,2,3 should be linked together as live 4,5 as neutral and earth takes its place as earth,
if it is wired correctly then i m afraid the hob needs a new induction element it is all one complete unit on these hobs not seperate so your looking at £1000 + to fix it plus engineer call out charges
Dec 06, 2008 | Kuppersbusch K 23 in.EKE604.2 Electric...
Open Questions:
De Dietrich 22 in. DTI305W Electric Cooktop Logo
1,224 people viewed this question
Top De Dietrich Cooktops Experts
Paul Carew
Are you a De Dietrich Cooktop Expert? Answer questions, earn points and help others
