Question about HP Computers & Internet
Laptop keyboard uneven
HP G72-259WM laptop. Keyboard has slight rise on lower left side. Replaced original keyboard and have same problem.
mdsaeed67
  • 849 Answers
SOURCE: water on keyboard
dry the water using dryer or put the pc in sulight for couple of hours, otherwise contact a service personal
Posted on Nov 05, 2008
benwabnick
  • 2404 Answers
SOURCE: I am missing the control key button on the lower
The only thing you can do at this point is to find a broken sony laptop keyboard and take the keys off that and put them on your keyboard or just to get a brand new keyboard cause if certain keys fell off then others may be soon to follow.
Just from a search from Ebay brought up this:
http://cgi.ebay.com/Sony-Keyboard-KEY-VGN-S370-VGN-S380-VGN-S430-VGN-S460_W0QQitemZ270336571206QQcmdZViewItemQQptZPCA_Mice_Trackballs?hash=item3ef150b746&_trksid=p3286.m20.l1116
You can buy just the keys you need and the total cost would be less then the cost of a new keyboard and a new one can cost around $80.00 as according to this website:
http://product.pelltechnology.com/Sony_Vaio_VGN-S460_Keyboard_replacement.asp
At least you have a choice in which way you want to go.
Posted on Jun 21, 2009
FixinFax
  • 3085 Answers
SOURCE: hi, the letter U key of my laptop's keyboard won't
It is easy to replace the keyboard on this model. Search eBay....$20.00 I have done many of them.
Posted on Sep 22, 2009
MUKHTAR
  • 2022 Answers
SOURCE: Keyboard diagnostic says keyboard is operating
may be the keyboard is short i advised you to change it becouse it cant be repair.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Posted on Dec 27, 2010
hmerchant110
  • 7191 Answers
SOURCE: I have an HP G72-259WM
Since there is no power button or desktop icon for the webcam, the only way to test and use the webcam is to open a webcam application.
You can use the HP MediaSmart suite for Windows 7 which includes a webcam application. HP MediaSmart Webcam can record videos, take photos, etc.
For more details and step by step instructions to use HP MediaSmart, click this link.
Also, you can set up and use the HP Webcam in messenger programs like Windows Live Messenger, Yahoo Messenger, AOL Messenger, Skype, etc. For set up and usage instructions for messenger programs, click here.
Hope this helps. Thanks for using FixYa.
Posted on Sep 04, 2011
HP 2000-208CA Keyboard Some Keys Don't work
I had a similar problem after replacing a damaged keyboard, turned out that the ribbon cable kept pulling slightly from its socket each time i replaced the keyboard, try lifting the keyboard gently and check that the ribbon cable is fully inserted correctly.
Apr 06, 2013 | Computers & Internet
LAPTOP KEYBOARD UNEVEN
What type of HP is it?
Feb 14, 2012 | HP Computers & Internet
How to remove the keyboard
Keyboards become worn out over time. Individual keys can become damaged, become less sensitive to key strokes, or disengage from the keyboard. Keyboards can also become corroded from spills. Many keyboards on HP laptops can be replaced. Hewlett-Packard has made hundreds of different laptop models. Each model may require slightly different steps for replacing the keyboard. To locate a replacement keyboard, you can contact HP directly or another online or offline source that sells computer parts.
1.Power off the laptop. Flip the laptop over to access the device's underside.
2.Remove the battery cover and take out the battery.
3.Remove a screw to the left of the memory bay. This screw will be one of two resting in the middle of the underside of the device. You want to remove the right screw, the left screw is attached to the CD/DVD-ROM drive, not the keyboard. (This screw may be red in color.)
4.Flip the laptop back over and raise the laptop screen so you have access to the keyboard area. Insert the tip of a Flathead screwdriver along the bezel and detach it. Carefully pull the bezel up and set it aside. The bezel is connected to the device with a ribbon cable. Do not remove this ribbon cable. (The bezel is the above the laptop and is the cover that houses the power button.) Once the bezel is up, notice the three screws that are beneath it.
5.Unscrew the three screws holding down the keyboard.
6.Lift the keyboard forward toward the mouse area. Be careful, it is still connected to the motherboard by a keyboard cable.
7.Release the cable from the keyboard. Push both ZIF connectors on the side of the cable upwards, toward the laptop screen. Pull the cable from the connector and the keyboard is now released.
8.Insert the keyboard cable of the new keyboard into the ZIF connector. A pair of tweezers may be required to put the cable in place. Lay the keyboard flat down and rescrew in the screws. Replace the bezel cover. Flip the keyboard over and replace the screw on the underside near the memory bay. Insert the battery and battery cover.
Sep 19, 2011 | HP ProBook 4710s Notebook
What is the function key to turn wireless on
How to turn on/off Wireless in various Laptop Models ------------------------------------------------------------------------------------
Vendor/Model-----------Type----------Location
Dell D600 & D610-----KeyBoard-----Fn+F2
HP nc4000 & nc4010-----Button-----Above Keyboard
HP nc4220-----Button-----Left Side of Laptop Near USB Port
HP nc6000 & nc6220-----Button-----Above Keyboard
HP nx9010-----Button-----Front side of laptop
HP Omnibook 6200-----Button-----Left side of laptop
IBM T43-----Keyboard combination-----Fn + F5-----Click "Turn On"
IBM X32-----Keyboard combination-----Fn + F5-----Click "Turn On"
Toshiba M1 & M2-----Switch-----Left side of laptop-----Towards
front
Toshiba R100-----Switch-----Right side of laptop
Toshiba TE2000-----Switch-----Left side of laptop-----By Vol ctrl
Toshiba Tecra 2100-----Switch-----Left side of laptop-----By Vol ctrl
Sep 09, 2011 | Computers & Internet
I can't find the wireless putton on my HP pavilion Entertainment PC dv8700
It should be located in the "F" keys on the upper portion of the keyboard...once you find the key that looks like the wireless symbol (a tower with parentheses around it) kind of looks like this:
((( i )))
once you find that press the "FN" key at the lower left hard side of your keyboard PLUS the the ((( i ))) key!
That should turn it on, or look on the edge front of the laptop with the lid open to the left of the keyboard, there might be a switch! Hope this helps, if not message me!
Aug 04, 2011 | Microsoft HP Pavilion DV6276US Notebook PC
How do i turn my wireless on my laptop
front
Hope it helps !
Jul 14, 2010 | Advent Netbook
I don't know how to turn on wierless
> front
Or you can do that from device manager.
May 31, 2010 | Dell Latitude D610 Notebook
Hi, the letter U key of my laptop's keyboard won't
Sep 22, 2009 | HP Pavilion dv6000z Notebook
Left side of space bar on Dell XPS M1330 difficult to use
I had the exact same problem and contacted Dell support. They sent a tech to swap out just the keyboard. I have a feeling these keyboards are not of the highest quality as I do have some issues with the Ctrl key now. But it's much less annoying than the broken spacebar.
Feb 28, 2009 | Dell XPS M1330 Notebook
HP Pavilion zv6000 Notebook PC keyboard replaced
Probably the keyboard you got is defective. I have seen buttons working in very bad conditions. When a key doesnt work or several is bad news.
Try to get a replacement. Since you have already reseated this simply check if the flex cable is properly locked, (ear plugs or similar) and not moving.
Mar 19, 2008 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
