Question about Whirlpool LER7646E Dryer
How do I replace heater element on Hoover TC650 dryver?
I have a Hoover condenser dryer - Model TC650 and about a month ago it started causing a burning smell, loud bangs and it was overheating. I was told it needs a new heater element.
I bought the whole heater element as suggested, but for the life of me I have no idea how to get to the main wiring to uncouple the old element and attach the new one.
I took the old element off, but there is a long white cable that goes into a hole in the back of the machine and at the end of that cable will be 4 coloured wires with attachments to something inside the machine. My problem is how do I get to the end of the old white cable and to the coloured wires so I can unattach the old element and attach the new one?
I assumed I have to take the outside metal casing off the dryer to get to the inside of the machine, but I can't even figure out how to do that. The metal casing is in one whole piece.
Any help?
  • 49 Answers
SOURCE: Hoover Tumble Dryer TC650
yes
Posted on Aug 19, 2008
SOURCE: Admiral Dryer (Model # ADE7005AYW) wire connector burning causing no heat
I had the same problem with my dryer. Fixed it with high temp wire (875 F) and end connectors rated for the same temperature. Make good connections between the wire and the connectors because if they are poor they will heat up as well. Sometimes the thermostat will cause this problem as well or an older heating element that is going bad.
Posted on Jan 18, 2009
aborcass
  • 2651 Answers
SOURCE: replacing heater element
on your old heater there was a "thermostat, mounted to the lower end of the heater correct?? youllneed to remount that to the new heater( one end will gp to one terminal on heater) ohter "thick wire" goes to the other heater terminal, and on eto the open thermostat connectore, the last wire should be smaller in size and connect to teh side of the thermostat you just installed
Posted on Jan 21, 2009
aborcass
  • 2651 Answers
SOURCE: my whirlpool electric dryer smells hot.
generally if the uint shuts off from overheating and then will not restart for a 10-20 min period of time usually a sign htat hte motor is overheating and needs repalcing
Posted on Mar 31, 2009
milten1
  • 1304 Answers
SOURCE: Recently the heating element was replaced along
more often than not those connections are loose and that jsut cannot be
but check your outlet voltage it should read 220 across the poles anything else it could eb trouble
Posted on Oct 06, 2009
HOOVER AUTO DRY 5050ED KEEPS STOPPING
hi there, I have repaired many of these dryers. It will be a faulty heater element, most likely. They cost about $40. If you get a tradesman to fit it, they will prob charge you about $200 all up. Maybe its better to buy a new dryer for around $300? Good luck.
Lance in brisbane.
Jun 17, 2012 | Hoover Dryers
HOOVER TC650 need to replace drive belt how to access the motor ?
The TC650 does NOT disassemble in this fashion..... Pleas read the posts properly or you are wasting your time and the readers trying to fix faults.....
Oct 10, 2011 | Dryers
MY MODEL IS DV665JW/XHC DRYER THERE IS NO HEAT
if it is a condenser type dryer you may find the condenser has not been cleaned and this suffercates the unit and over heats. to protect the heater element there is a thermostat cut off which has more than likely blown which breaks the electrical circuit. so this would need replacing which is found near the heater element at the rear of the unit. then clean your condenser.
hope this helps
Aug 20, 2010 | Samsung Dryers
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
Hi the my filter light keeps flashing and iv got no heat!
My guess is that the heater element has gone out. There could also be a lint clog in the exhaust vent...it takes air out through the filter...across the heater element....and back through the tumbler to heat the clothes. This is usually what causes heat elements to go out is the excess lint that gets on them and causes them to overheat and burn out!
Dec 14, 2008 | Whirlpool LEQ8000JQ Electric Dryer
Hoover TC650 Tumble Dryer will not heat up
Not all that familiar with the Hoover Dryer line but in general if you have 12 volts being fed to the heater element.. you identified why it isn't heating .. Your husband is correct in that heater power should be line voltage.. You may have a non-resettable thermal fuse that has opened or a relay that feeds power to the heater is not being commanded to turn on by the logic on the control board. If your husband is handy and technically competent, he should verify that there is 220VAC at the input termnal block of the dryer itself ( carefully) to make sure you don't have one phase missing.. Those are the chief suspects... not sure that helped you but you now have a few ideas where to look...
Regards,
Rick
Nov 28, 2008 | Dryers
My Hoover TC650 condensor dryer has a fault. When turned on it makes a noise (buzz) but the drum does not revolve. If I turn it by hand and then quickly close the door and press the button it will...
i saw your question and never worked on a hoover dryer so i checked it out go here to see video
https://www.how-to-repair.com/help/hoover-candy-tumble-dryer-drum-not-turning-and-belt-ok-faulty-capacitor/
i have to tell you on all the dryers i've ever worked on they never had a cap in them,only washers,on a dryer that isn't a condenser dryer if you get the dreaded buzzing sound and start it like you did,open the door,hold in the door switch and spin the drum with your other hand while someone else pushes in the start button and it would start it would be the motor,i've seen a condenser dryer and the problem always was with the filter,people that had just bought one didn't know you had to clean out the filter box,never took one apart,i saw that nobody answered you so i hope this video helps you out and i learned that condenser dryers have a cap in them.
Dec 30, 2017 | Hoover Dryers
Dryer heater not working
If it is an electric heater that means that either the heating element, or the thermistor , or the cirrcuit breaker connecting the element must be replaced.
You find diagrams and replacement parts here, just enter the model number.
See also following suggestions from repairclinic :
There's no heat.
How Dryers work
Find a part for your Dryer
Oct 12, 2008 | Hoover Washing Machines
Condenser sensor dryer not very hot
the heationg elements are tied together so they either work or don't work,it sounds like your hose vent might be clogged,also check power coming into the dryer on the terminal block,make sure you have 115 on each leg,mike
Sep 12, 2008 | Dryers
Dryers Logo
129 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
