Question about John Deere Toys
1996 john deere gator new coil still no fire
Has new coil and i took the stator and had it tested. Still no fire to coil or plug. I checked saftey switch on trans and brake both are functioning properly. Not sure what else could be preventing enginefrom firing
momsjustknow
  • 135 Answers
SOURCE: peg perego john deere gator 4x2
Here are the printable instructions from the Perego website.
http://www.pegperego.com/pegcatalogue/toys/downloads/Gator_Work_FIUS0301G24.pdf
From what I can tell, there are levers on both sides of the grill that you press to flip the grill down to the ground. You can then get to the battery to pull it out and charge it.
Hope this helps!
Good Luck! from Moms Just Know
Posted on Nov 03, 2008
  • 60 Answers
SOURCE: old john deere gator and battery new charger still will not move
Could be several things.  Your battery could be bad. After not being charged for a while, they do go bad- often. You may want to try a new battery along with your new charger.  You could also have a switch /connection problem. If you get a new battery and it still doesnt work, you may want to check the switches and wiring. It is not uncommon for the switch to go bad especially if it had been stored outside.
Posted on Mar 11, 2009
mikeramesar
  • 37 Answers
SOURCE: cannot find out how to get to the battery for a
Where the front bully bar is, there is an indent in the middle , enough for your phillips head screw driver to get into, you must undo that screw and there will be a tab on either side of that panel to pull and the front bummer assembly will hinge out towards you, you can then unplug the battery and connect your charger..
Good luck!!
Posted on Dec 27, 2009
  • 156 Answers
SOURCE: help for my childs John Deer Gator
the peg perego gators have two switches in the shifter that need replaced.
I have replaced them before on my grandkid's gator.
Here is the website I get my parts from
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
You can also call them direct at 1.801.655.0800.
They seem to always know which part I need and I have always been very happy with their service.
Hope this helps
Posted on Mar 18, 2010
  • 19 Answers
SOURCE: john deere gator 1999 4x6 overheating.replaced
bleed air out of cooling system contact dealer for instructoins
Posted on Aug 17, 2010
Peg perego john deere tractor charger indicator light does not light up and tractor does not take a charge - brand new
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show
any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 02, 2012 | Peg Perego John Deere Gator HPX Ride on...
My Peg-Perego John Deere Battery Powered Gator HPX will no longer drive
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 08, 2010 | Peg Perego John Deere Gator HPX Ride on...
My sons john deere gator is dead do they send new batteries or chargers for it
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in, otherwise you can order a new one here www.powerwheelsoutlet.com
Sep 05, 2010 | Peg Perego John Deere Gator HPX Ride on...
Help for my childs John Deer Gator
May 09, 2010 | Peg Perego John Deere Gator HPX Ride on...
My kid has a peg perego john deer gator, battery tests fine but still it wont go? i swapped out the pedal assembly with another one i have and still nothing.
Apr 05, 2010 | Peg Perego John Deere Gator HPX Ride on...
John deere gator kas motor
fuel filter may be blocked
carby may need a good clean out & retuned
Cheers Rob
Mar 23, 2009 | Peg Perego John Deere Gator HPX
Old john deere gator and battery new charger still will not move
Dec 15, 2008 | Peg Perego John Deere Gator HPX Ride on...
Toys Logo
Top John Deere Toys Experts
Colin Stickland
Colin Stickland
J.D. Browning
J.D. Browning
john h
Are you a John Deere Toy Expert? Answer questions, earn points and help others
