Question about Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL11 display module wires disconnected and we don't know where they hook into.
Our display module fell when we were fixing something else on our Fisher Paykel GWL11 top load washing machine and became disconnected from the wires. We have not been able to figure out where the wires plug back into. The set of wires are still attached to the Motor Controller Module, but disconnected from the Display module. We have looked it over many times and can't figure out where to reconnect it. Any ideas? Help!
  • P_Roz Feb 18, 2012
    We ended up ordering a new part for close to $200!! But we think we know how it goes on now because we took it apart. The brown board on the back which we thought was a cover was actually a circuit board. (We had no idea). We will know once the new part arrives, but we believe it would just clip on the board with the metal pieces connecting to the metal pieces on the underside of the board. Unfortunately the board is now destroyed and it would have been a simple matter of connecting it to that. I may include pictures later.
  • P_Roz Mar 04, 2012
    The problem was that we just needed to clip the wires onto the brown board on the back - the circuit board and it would have been fixed. Problem solved.
3 Suggested Answers
  • 28 Answers
SOURCE: my fisher paykel eco smart is GWL11 not GWL15
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
Posted on Jul 03, 2008
  • 57 Answers
SOURCE: squealing
more than likely going to be hard to get the pump it is on back order through the company
Posted on Jun 27, 2009
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
On the gwl11 fisher paykel washer the first and 7th lights are lit and washer won't function
according to the service summary that comes with the washing machine, you have error code #130, a faulty rotor position sensor. first check would be to unplug the machine, remove the screws holding the push button panel, and pop it off. check your wiring harnesses (connectors going to the brown control module). the wires going to the rotor position sensor will contain black,violet, blue, grey, and orange. they connect to the motor control module at the second from the left hook-up. trace those wires to the rotor position sensor. if the wiring is connected, google the part number and purchase a new one. you will have to open the top of the washing machine to get to the sensor. lift your lid, remove two white rubber caps and remove the screws. when you lift it up, ensure that you have replaced the push button console, and glance under to rear right side. you should see the colored wires there attached to your sensor.
Sep 15, 2013 | Fisher and Paykel GWL11 Top Load Washer
Displays code 107
Error code 107.
(01101011) Motor Control Module Reset Error
The Display Module has detected that the Motor Control Module has reset when it should not have. This can be due to a Motor Control Module supply disturbance or microprocessor failure.
Primary Source: Motor Control Module.
Action: Replace Motor Control Module.
Mar 15, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fix code 104
104. (01101000) See Fault Code 106
106. (01101010) Display Module to Motor Control Module Communications Error
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Jan 24, 2012 | Fisher and Paykel GWL11 Top Load Washer
GWL11 fisher & paykel with error code 56 (lights 3,4,&5) what does this mean?
This code usually relates to the bowl not disengaging proper to agitate - few things to check - is there enuff water in the machine? - is the clothes packed to one side kinda? - remove the display cover to check if you don't have a kink or the tube for the water level controller hasn't come off - remove the tube & blow into the "bowl end only" attach & try it out - you haven't lost a sock lately or something, it could be stuck between the two bowls? - machine not syphoning? - if none of these work then the RPS is gonna be the most likely problem.
Aug 22, 2011 | Fisher and Paykel GWL11 Top Load Washer
After power failure my GW712 wont work, the lights come on but the start up beeps don't sound and the touch pad don't do anything, also there is a whirring sound coming from the control panel.
Hi - that sounds nasty - its possible the display or the control module has failed as a result of the power failure.
I suggest the motor control module be the 1st unit to be replaced, don't think you can get around this one.
Jun 21, 2011 | Fisher and Paykel GWL11 Top Load Washer
Top load fisher paykel 2004, mid cycle of wash alarms won't agitate or drain
Hello - No one can help you if you don't describe the alarms, colours of the lights its position on the display. It could be the drain pump but cannot be sure - need some help here...
May 02, 2011 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
69 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
