Question about KitchenAid KESC307 Electric Kitchen Range
Display panel stopped working
The display went out about a year ago. Oven still turns on and works fine but I can't see any temp reading. Sometimes if the oven s on for a long period of time the display will briefly turn back on again. What could be wrong? I have a repair man coming but want to have an idea of what could be going on.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 76 Answers
Nov 9, 2009 ... I could thump it with my fist, not hard, just a light thump, and it would come back on ... Problem with KitchenAid KESC307 Electric Kitchen Range ... the ribbon cables and the panel can be removed to a convenient work surface. www.fixya.com/support/t3391463-kitchenaid_range_kesc307hbt8_display www.fixya.com/support/t3391463-kitchenaid_range_kesc307hbt8_display
Just checked this site and it has an answer to your problem. Very complicated, but I am sure you will be able to follow it
Posted on Feb 15, 2012
  • 1314 Answers
SOURCE: oven sparking problem
i think you will find the power cord is burned this happens if it wasnt tightend up properly and gets loose turn the oven breaker off before you pull it out
Posted on Jan 24, 2008
SOURCE: kitchenaid oven KGRT607 HBS6
I also have this problem. Replaced control board, but didn't help.
Posted on Feb 01, 2008
philbran
  • 242 Answers
SOURCE: After using the self-clean cycle, display panel went black and oven door stayed locked.
Happens alot dont feel bad , self clean mode runs the elements at 500 deg. to cook off everything possible , what happens is the cabinet gets to hot and heats saftey temp. fuses until they go out and they are not resetable. they are always located in different areas of ranges but usaully in the back. you can ohm them out to check them if you have a meter.let me know if you have any other questions.
Phil
Posted on Apr 14, 2009
zazonker
  • 68 Answers
SOURCE: Dual fuel kitchenaid; burners work, oven does not
I had a similar problem. There's a thermostat before the control panel. You need to remove the knobs and the front panel to get to it. You'll also need to remove a couple of trim pieces to keep from bending the panel. The part number is Whirlpool W10017820, sells for about $40.
Posted on Jun 03, 2009
SOURCE: KitchenAid Superba gas range/convection oven. Oven won't turn on.
Replace the igniter
Posted on Dec 02, 2009
My oven is dead - no display, no nothing. Circuit breakers are fine. Turned them off overnight, still nothing on oven this morning. This happened about a year ago but oven came on again ten minutes...
What you need to check is for power at the clock.TURN OFF BREAKER gain access to clock and use volt meter. One the clock will be wires maked L1 & N on those 2 wires when breaker is turned back on their should be 120 vac. IF 120 vac at those 2 wires,replace the clock, if not 120 vac into clock check for burnt/broken wires
Aug 20, 2011 | Jenn-Air Electric Single Oven
I have a Samsung refrigerator with a bottom freezer. The 'fridge and freezer temp settings are displayed on a panel between the upper and lower doors. The unit is about 4 years old. About a year ago,...
Hi adc3,
If the display has stopped working, it is often caused by a blown fuse. Please locate the main control board and check if there's a fuse that may have blown. For the ice maker issue, please check if the ice maker has been turned off. You can check it by looking for a wire that looks like a coat hanger that is located at the right side of the ice maker. Ensure that this wire is not in the raised position. If it is turned off, just simply lower the wire to the down position to turn on the ice maker. If this did not work, please check the tooth on the drive or driven gear of the ice maker. If you noticed a broken tooth you should replace the ice maker.
Hope it helps.
Thank you for using FixYa.
Jun 14, 2011 | Samsung RF265AA Bottom Freezer French Door...
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Apr 21, 2017 | Whirlpool GBD307PD Electric Double Oven
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
KitchenAid KESC307 Electric Kitchen Range Logo
131 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
