Question about Frymaster PSDU50 Shortening Disposal Units
Grease pump won't pump
Was frozen now thawed w/ new fuel filter still won't start
Fuel pump may have ailed this time.. You need to have fuel pump checked.
Jan 31, 2013 | 2000 Ford Explorer Eddie Bauer
My 2004 chevy venture won't start. Changed the
Did the fuel pump come on?
Did you check fuel pressure at the motor?
Try jumping the relay to get pump on?
Read a wiring diagram-- so you know what your doing?
Check Power & Grounds to pump when the tank was down?
Dec 22, 2012 | Cars & Trucks
Car squeking. are there any grease points to lube?
Very few if any grease fittings
You will have to get under there & look,
or have a repair shop check out your squeaking
Greasing anything on a 12 year old car won't do a thing
Grease is for high bearing load points, such as a ball joint
Top Strut Bearing Plates & Stabilizer Bushings, could be
part of your squeaking
Aug 28, 2012 | 2001 Mercury Grand Marquis
Pump hums but won't run
awwhhh it sounds as if you stored your pump dry all winter long ill bet, well ya just cant do that after it pumps salt water all summer , salt has crusted up inside pump and valves , try a hot water dose (not on motor) that might get it going again (repeat several times)
otherwise your gonna need to take it all apart clean in hot water and grease all up with foodgrade waterproof grease (see kitchen faucet parts section of hardware store)
on a salt water pool you have to store your filter and pump filled/capped with RV antifreeze (foodgrade) any good rv store sells it
salt wont crust up inside then
Mar 23, 2012 | Intex Salt Water Saltwater System Chlorine...
Kenmore model # 11607090 older model, been setting up for several years, but has never been used-cannot unlock the hand wheel. we were able to wind bobbin, but wheel will not turn.
as for the hand wheel not not being able to turn, it's possible that something could be loose or broken
you said it's been sitting for several years,, I would suggest that the machine needs to be serviced
by a sewing machine repair shop, where they can check the handwheel & find out why it won't unlock, & that the gears & inside the machine can be checked & grease & oiled & the timing check also
Sep 05, 2011 | Kenmore 1667 Mechanical Sewing Machine
I have a IR5190 Grease Gun, I'm only on the second tube of grease since new & when I loaded it, it won't pump out, I already disconnected the tube to make sure it wasn't clogged. Am I doing...
there is air trapped in the gun. there is either a air bleed valve on the top you need to press in and press the trigger a few times or you need to pull back the ram and unscrew the tube. then rescrew it back in a few turns. then press the trigger untill grease begins to come out and then screw in in the rest of the way.
Aug 17, 2011 | Ingersoll Rand IR5190 Ultra Duty Grease...
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
Hello. My 1997 Chevy Tahoe refuses to start. The problems began with a bad fuel pump. I changed. It worked. The fuel pump died again. I changed it again and it has been working. I parked it for two weeks....
Now you have a good battery & a starter that turns over the motor
Have you cycled the key on & off with a fuel pressure gauge on the
fuel rail?
Do you have a fuel filter that isn't over 3 or 4 years old?
Have you checked for spark while cranking ? Use an old plug on the wires,
if you have ignition wires,don't ground the wire without resistance
If you removed the ducting & MAF Sensor it won't start
Tell us what you checked & exactly how that was done.
Jun 09, 2011 | 1997 Chevrolet Tahoe
Frymaster PSDU50 Shortening Disposal Units Logo
46 people viewed this question
Top Frymaster Kitchen Appliances - Others Experts
Paul Carew
richie46
ray gallant
Are you a Frymaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
