Question about Sony FD Trinitron WEGA KV-32FV310 32" TV
Tv shuts down and i have to turn it on and change channels to get a picture and the color is fading
I turn it on the light blinks upwards to 14 times shuts down and I have to turn it on again with no picture, I have to change channels a few times before I get a picture, and the picture is washed out faded
    Top Expert:
  • Sony Master
  • 75,581 Answers
Hello
It system memory IC has the trouble. It is an eight solder terminal IC, can be located very near to the main system control IC. Replace it with same number. Its' number is most important to note, when you buy a new one.
A skilled job indeed.
Posted on Feb 15, 2012
  • 55 Answers
SOURCE: Have no red color and the other colors seem to be fading on my sony KV36FS13
in that tv you have surely the color circuit trouble - if you can you have to check  the red color circuit , first transistors then voltage or a capacitor not functioning ,
I HOPE THIS MAY HELP YOU - DELFO
Posted on Mar 20, 2008
welcomejee
  • 10594 Answers
SOURCE: Colors Faded in my sony KV-HA21M83A 21''
Its magnetic effect on picture tube. Power Off TV for 20-30 minutes then turn it On, hope problem will be resolved. Please also check and remove any speaker or some thing have magnet near by TV.
If color spots are still there, picture tube need to degaussed / demagnetized.
Posted on Nov 10, 2008
  • 4234 Answers
SOURCE: FADING COLORS
After 13 years, the most likely cause is a tired picture tube. There are adjustments that can be made to address this, but they would be short lived. Rather than spend money on this set, put it toward a replacement. After 13 years, the set owes you nothing.
Dan
Posted on Feb 13, 2009
darjr
  • 378 Answers
SOURCE: my tv colors have started to fade.
Ya, I think your Tv has weak CRT problem. or the FBT need replacement. You consult the tech. of sony service center.
Posted on Jun 11, 2009
ladywinn
  • 5138 Answers
SOURCE: KV-xbr 36 After tv has been
Is your Model number that is printed on back of TV (KV-36FS120?)
Posted on Jul 28, 2011
My picture fades out, I have sound can't change the channels?
soundslike you need a new TV or get this one repaired .
Aug 08, 2016 | Televison & Video
Bravia KDL52z5100. Why is red light blinking 14 times?
Tell the readers of your posting exactly what is the problem with the tv. Audiio? Picture? Backlighting? Etc.
Dec 29, 2015 | Sony Televison & Video
No picture with sound tv turns off. Mitsubishi model WD65837
are any lights lit up when it shuts down? If so which light what color is it and is it blinking or a just stays lit without blinking?
Apr 05, 2013 | Mitsubishi WD 65837 TV
Magnavox 42mf439b/f7, no picture or sound
I have the same tv with the same problem. Previously to resolve the issue I have left the system unplugged from the power overnight, however that did not fix my issue this time. Have you discovered a resolution to your problem yet?
Jul 04, 2010 | Magnavox 42MF439BF7 42 in. TV
Tv makes buzzing noise then picture fades and eventualy shuts off
Ur colors wheel is dead,must call tech.for this is very difficult to take out,and replaced have no tv tech. experience.Best to call tv shop service,to replaced this colors wheel,and have warrenty on it.
Jan 11, 2010 | Samsung HL-P5663W 56" Rear Projection HDTV
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Shutsdown
It sounds like the picture tube's again, they are around $350 each plus labor, there are three, usuall only one or two need to be replace at a time.
Jun 15, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Power light blinks and no picture
No picture - screen is empty. Sound is ok
Check IC101 (BA7630F), if video signal comes to input (pin 1) but not present at output (pin 14) then replace this IC
No picture and sound, only a high pitch sound at switch on
Remove horizontal transistor and measure the resistance across any two pins. This value should be no less than 200ohms
Picture fades away few seconds after start-up till no picture. Sometimes no picture at all. Sometimes picture OK for longer. Sound unaffected.
Faulty joints on CRT pcb. Cracked solder joints at tube socket connections on CRT circuit board. Caused variable supply to CRT heaters. Resolder all socket pins to pcb.
Nov 24, 2007 | Toshiba CZ36V51 36" TV
Picture problem
Your set is having convergence problems, are the colors messed up in these areas or does it looks normal beside the arc? If the colors are out of line then convergence problems are on the way. Shut down and look at the convergence board for loose solder connections first, Then resistors that needs replacing. Last may have to change Convergence amps.
Sep 10, 2007 | Philips 60PP9202 60" Rear Projection...
TV blinks intermittingly
No you didnt answer the most important questions> When the tv"blinks" does the sound go on and off with the picture? Or does the picture go out to a black screen or a grey screen? or does the whole set seem like its shutting off and on again? or does ir seem like the tvs trying to tune in a channel but keeps going past the right frquency? Answer these questions and we can get somewhere.
Jun 17, 2006 | RCA F27645 27" TV
Sony FD Trinitron WEGA KV-32FV310 32" TV Logo
69 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
