Question about AEG Washing Machines
Aeg 76669 washing machine
Does anyone know how to reboot an AEG 76669 washing machine, it is not curently working ad all the lights are flashing please help!!
  • AEG Master
  • 19,396 Answers
The only way to reset a washing machine is by unplugging the power cord for half an hour or so, then plug it back.
This will drain power from circuits and reset them completely.
If that does not work, then you will need to have the control assembly replaced.
You get parts and diagrams here or here.
Posted on Oct 25, 2008
AEG Lavamat 16850 shows err (some kind of error code) anyone know how to restore to factory settings?
suggestion, ring up AEG and ask for the technical department
give them model and code and they should give you the answer your looking for good luck.
Oct 05, 2016 | AEG Washing Machines
What does E50 flashing on a Aeg washing machine
Your Water inlet valve is bad or has failed! You need replace either Hot or cold valve.
Jul 25, 2014 | AEG Washing Machines
What means error code "C9" ? AEG Lavamat 76669
C9 Indicates Motor Fault. It seems that the Carbon Brushes have Worn out.
Replace it and more likely it would Fix the Problem.Once you replace that, you need to put the machine into Service Mode to Reset the Error.
Steps for Reset the Error Code
1. Press and Hold the Prewash and Soaking Buttons Together.
2. Whilst Holding them, Turn the Dial from Off one Click Anti Clockwise
Note - If problem persists, Check the motor plug for broken wires and check the state of the carbon brushes.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 28, 2010 | AEG Lavamat 88840 Front Load Washer
What does fault code c8 mean on an AEG Lavamat 76669
a C8 warning means the (Thermister) temperature sensing device has shorted or is open circuit, this replaces the old-fashioned thermostat that they used to fit. the water in your m/c could either stay cold or boil.
Jul 07, 2009 | Washing Machines
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
C9 error AEG lavamat Princess S update
go on line and contact AEG head office by email they will email you back with instructions in english.adrian
Feb 16, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG 16810 UPGRADE WASHER DRYER E10 ERROR
This is worth posting in case anyone else has the problem. The mechanic was stumped and then around 3 days later a Zanussi gave the same problem - steam emitting from the drum. He changed the valve - the entire unit. Problem solved. Zanussi and AEG have identical internals. He changed our valve - problem solved.
Jul 22, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Mar 03, 2008 | AEG Lavamat 88840 Front Load Washer
Aeg 76669 oko lavamat machine not starting all six lights [pre wash, main wash, rinse, rinse , spin, and end] flashing machine three years old just successfully completed wash cycle, loaded up for next...
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Jan 10, 2008 | AEG Washing Machines
Washing Machines Logo
427 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
