Question about Health & Beauty
On my model 9551 pro rechargeable Wahl clippers, everytime I used them the little spring inside breaks. Why and can you get the part.
I disassembled my Wahl 8552 Pro Series clippers do change the rechargeable batteries and now I can't figure out how to assemble it. I wind up with two extra screws.
How did you get it apart? I don't want to break the case and can't get it to release at the front of the unit.
Dec 15, 2010 | Wahl 8550
How do reassemble the blade for Wahl 8552
I had the same problem with the Wahl Pro Series Rechargeable model 8552, and called Wahl service. Here is what I learned:
Never unscrew the screws on a Wahl blade (they use those funky nonstandard screws to deter you) -- that's the main thing. The whole blade assembly is supposed to come off by pulling it up and off from the teeth.
But, if you did it (as I did), you can put it back together this way:
1. Place the large blade down on the table (Wahl logo down), and place the small blade on top of it (if you look carefully, you will see how it lines up).
2. Insert the spring points into the two holes of the white plastic part (on mine, the spring kept slipping out and I finally used a drop of superglue on each hole until it would stay in long enough to complete the assembly). Place that piece on top of the small blade (see photo).
3. The bent metal piece with the two screw holes then gets placed on top of the large blade, with the center ridge of the bent piece over the straight center portion of the spring -- so that you have to hold it in your hand and push it together against the spring in order to align the holes of the entire thing. As you are holding that, put the screws in from below and tighten. It's awkward and if you are like me, it will take several tries before you can get it all lined up correctly and tightened. The photo below is what the final assembly looks like before snapping it onto the clipper.
3. Clip it in: At the top of the assembly in the photo below, notice the small bent metal piece that will fit into the back of your clipper in the hole. Once you fit that properly, push the whole assembly down onto the clipper until it snaps into place.
Aug 03, 2010 | Wahl Health & Beauty
I have a Wahl clipper Pro Series Rechargeable model 9550 and can't figure out which charger goes to it. I have one labled for model 5550 only - is that it?
My clipper, model 8552 says use with model PCC charger only.
On the charger / transformer it lists the clipper models it will work with. It says class 2 transformer model A30316Q then lists the models in the middle of the unit and then at the bottom says model PCC PT#97562-103
Mar 06, 2010 | Wahl 8550
Diagram showing assembly of 4 parts of cutting head
I solved the problem finally. I discovered that the plate which has the 2 large threaded holes which carry the fixed cutter, had to be locked in behind 2 spring fixing points (on the body of the clippers) before inserting the tongue into the body of the shaver. When I first removed the plate I used a screwdriver blade to spring the tongue away from the body and the whole caboodle (4 pieces) fell out on the bench, so I didn't see how it was assembled. Thanks for your interest anyway.
Jan 08, 2010 | Kitchen Appliances - Others
Need wahl stable pro parts
Wahl Clipper Corp
2900 N. Locust St.
Sterling, IL 61081
815-625-6525
Nov 23, 2009 | Health & Beauty
I have a wahl pro series 9551 and the charger is broke i am after a new charger withour the clippers
Hello Lisa, Give the folks at www.electricshaver.com a try, as they have parts for most major brands of electric shavers and clippers in stock. You can also call them at 1-888-476-1785 and provide them with your model number and they can get the correct charger cord for your model.
Here's a link to a page that has a couple of charger cords that might work for your Wahl 9551, but you'll need to verify the voltage on the existing (broken) charger against the ones listed.
It would be best to contact them to make sure you get the right charger for your shaver. I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Health & Beauty
I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Jun 08, 2009 | Wahl 8550
Health & Beauty Logo
156 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
