Question about Kenmore Washing Machines
Kenmore 500 washer stuck in wash cycle
My washer keeps getting stuck in the wash cycle. If I click it manually to the rinse it finishes just fine. Only get's stuck in the wash part. I've tried running it empty, running other settings and the same thing happens. The only cycle giving me problems is the wash.
  • 18 Answers
SOURCE: Maytag Washer Getting stuckon wash cycle
the possibility of it being the timer is most likely..as the rest of the cycles remain ok.. if you require a timer,you can get one here at this link..(click the link here) http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=HAV4657EWW&mfgModelNum=&fkMfgID=1
please be aware that you will need the machine serial number in order for them to issue you with the correct part/s you will require.. parts are cross referenced with the serial number.
these diagrams will also enlarge in order for you to maintain your machine by yourself at little but the cost of the parts required... but please DO NOT ATTEMPT ANY REPAIR YOURSELF if you think you may not have the technical know how to follow these technical drawings..hope this helps
Posted on Dec 27, 2008
  • 185 Answers
SOURCE: Kenmore stacked washer/dryer - washer problem
check the timer
Posted on Mar 31, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
  • 414 Answers
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Posted on Jul 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: My kenmore 500 series washer stays in the rinse cycle
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Kenmore Front Load Washer won't complete cycle F06
Have you cleaned your machine lately? They make an in wash boost- it gets rid of the extra suds built up inside the machine that you cant see but your machine detects it and causes faults such as that. Also, there is a small wire on the control board that may need replaced if it keeps kicking the error code.
Apr 07, 2016 | Kenmore Elite 45986 Front Load Washer
Kenmore series 70 fills with water on rise cycle but stops halfway throught then starts agian and finishes is this normal
If this has always stopped during the rinse cycle, most likely it's the "cool down" part of the rinse cycle.
See the following Sears site for manuals. Enter your model number and you should be able to download the proper manual for your washer.
http://www.managemylife.com/mmh/owner_manuals/
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Rinse and Spin cycle stuck and not rinsing or spinning properly
Just read your posting.Now just a couple of questions.Are you using a warm fill for the wash or cold?if are using warm try cold only and take note of the time it takes to fill.I don't think your cold water is filling properly. My manual says that with only the 1st rinse light working it is your control module that is faulty. Please try a cold water wash and reply back so we can rectify this problem.
Jun 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
Kenmore 300 washing machine does not leave rinse cycle
This sounds like a bad timer. If the machine is several years old, the timer could be in need of replacement.
If you are handy, you can replace this device yourself and you should be able to obtain the part from any local Sears parts store or from the internet.
If you are not familiar with this kind of work, it would be best to have a technician replace the timer.
Jan 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
The spin cycle wont start as the rinse cycle finishes i here two clicks 1 to 2secconds appart and then nothing
Not sure which model you have, but if it spins after the wash cycle, and not after the rinse cycle, it is more than likely the timer.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
My Kenmore wash cycle stops between rinse and spin
Hi, Does the washer fill in the rinse cycle and then stop? Does it fill and agitate before it stops? If you advance the timer manually past that point, will it finish the cycle?
Question I need to ask in order to help you.
Please let me know so I can assist you further.
Vic
Jun 20, 2009 | Kenmore 22422 Top Load Washer
Washer will not discharge water after wash or rinse cycle
Pump failure. Unit probably has something stuck in pump....the washer eats the socks not the dryer. suggest shope vac to get water out, and then remove hose from pump and check to see if its clear.
Jun 08, 2009 | Kenmore Washing Machines
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
KitchenAid Washing machine stops mid-cycle and stays stopped
sounds like you need to replace your lid switch asssy part number 285671, unit not recognizing the door closed so for safetyreasons stops after first rinse and wont drain/spin. your tripping the switch by bangin on it
May 12, 2008 | KitchenAid KHWS01PWH Global Horizontal...
Washing Machines Logo
458 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
