Question about Air Tools & Compressors
Why does my paslode f350S shoot one nail, but not shoot the next nail/
  • B Johnson Feb 15, 2012
    what parts would I need to order to fix it?
  • 28 Answers
Had that problem on one of mine. If it is a multi degree nailer double check your degree setting. It will always shoot the first but will jam on the second.
Posted on Feb 16, 2012
rowdy45176
  • 2176 Answers
SOURCE: Paslode f350s leaking air through exaust after new
check the seal on top of the cylinder for debris or really loose fit.
Posted on May 31, 2010
  • 14 Answers
SOURCE: nail gun
have you activated the fuel cell by pressing the black nozzle down onto the cylinder?
Posted on Aug 04, 2009
rsmith972278
  • 160 Answers
SOURCE: how to load nails in the paslode f350s framer
Hi, I found you a free owners manual for your model. Click on the link below and save or print.
http://www.paslode.com/uploadedFiles/pneumatic_ops_manual.pd f
Hope this Helps, RSMITH972278 P.S. PLEASE RATE MY ASSISTANCE
Posted on Dec 29, 2009
  • 9 Answers
SOURCE: paslode f350s.just replaced all o
Simple. You have a leak you didn't have before. Either find it, or take it to someone who knows what they're doing. O-rings have a thickness, as well as a diameter. If you used generic rings, that's probably the problem. Use the repair kit by Paslode.
Paslode.com can tell you where your nearest dealer/repairer is.
HH
Posted on Dec 22, 2010
heatman101
  • 43501 Answers
SOURCE: I have a paslode 900600 . It cycles but it won't
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Posted on Mar 06, 2011
Why is it shooting 2 nails @ a time?
Your driver could be broken or worn down and may need to be replaced.
Mar 15, 2015 | Paslode F350s "powermaster Plus" 30...
Why want my paslode shoot nails all the way
Did you adjust the depth piece on the front? You can move this piece all the way up to try to nail deeper.
Also, I have tried nailing two pieces of oak together with no luck. It leaves the 2-1/2" nail about 1/8 to 1/16" above the surface.
Nov 07, 2014 | RTO PasLode 900420 Impulse Framing Nailer
Why is my gun bending nails?
Adjust the Work Contacting Element. See page 4 in the manual...
http://www.paslode.com/owners-manuals.html
Adjust the depth of drive.
Make sure correct fasteners are being used.
Use fasteners that meet Paslode specifications only.
Increase air flow to tool -- use larger air lines
(3/8 ID minimum).
Increase Air Pressure. DO NOT EXCEED 120 PSI.
Jul 23, 2014 | Paslode F350S PowerMaster Plus 30-Degree...
How to unjam paslode f350s nailgun
use the driver of the tool or a nail punch and hammer and try to knock out the nails
Sep 13, 2012 | Air Tools & Compressors
I have a charged battery, a new gas cartridge and a full sleeve of the correct nails but the nailer does not want to shoot a nail when I press the trigger. What could it be?
heatman101
Feb 08, 2011 | Omega Paslode 901000 Impulse Cordless...
Paslode f350s.just replaced all o rings,now when you pull the trigger air leaks out through the trigger,but only when depressed..will not fire nail.please help ..thanks bob
HH
Dec 05, 2010 | RTO PasLode 900420 Impulse Framing Nailer
My 900420 didn't shoot a nail ,i installed new battery and fuel cell,and is 33 degree nail r right for this model .
heatman101
Oct 16, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Feb 18, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
How to load nails in the paslode f350s framer purchased a used nailer now trying to figure out how to load the nails
Dec 29, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Will model no. ifn21950 shoot paslode 2
I would not recommend. Contact Campbell Hausfeld .com and order nails. You could damage your nail driver plunger if not careful. Plead rate . Thanks
Mar 27, 2009 | Campbell Hausfeld Tools & Hardware -...
Air Tools & Compressors Logo
434 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
