Question about Hitachi 57F510 57" Rear Projection HDTV-Ready Television
TV PROBLEM, SOMEONE HELP PLEASE
I got this tv and i can turn it on and see where it says input at the top, then the screen bounces around a bit and goes out and i cannot get it to turn back on. it turns on just no pic. can anyone assist me?
5 Suggested Answers
  • 41 Answers
SOURCE: My TV turns on and off randomly!
Remove the rear cover & turn set on, pull all the connectors off one at a time and push back on. I have had loose connectors cause this problem, and by doing the above has fixed it. Note do the pull off and push back on of the connectors, with the tv unplugged from the AC outlet.
Posted on Jul 22, 2007
ctf1800
  • 4402 Answers
SOURCE: Green Screen
Sounds like the green tube is shorted.
Posted on Dec 05, 2007
ctf1800
  • 4402 Answers
SOURCE: Hitachi HD big screen won't turn on. It was on, turned itself off and now won't power back up
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Posted on Jan 07, 2008
funkyjacob
  • 76 Answers
SOURCE: Hitachi 70SBX74b Won't turn on
Its the bulb you are looking at about $700 for one. You should get a quote first though. Also it may be the power box but if the light goes on for like s second and then turns off then it must be the bulb.
If you have any questions please dont hesitate to ask
Posted on Dec 04, 2008
aouate3
  • 123 Answers
SOURCE: TV..everything works...but screen goes red...I smack it, it goes back to normal, but then back to red.
it soinds like a convergence problem, i would try haveing someone take a look at it
Posted on Jun 14, 2009
I turned dish on and all I get is snow
Check the input cable to dish box for firmness and the orientation of the dish.
Feb 16, 2015 | DISH Network Televison & Video
Can you use a flat screen tv on this generator as someone bought one at Game stores and it blew his TV
Most generators do not have a true sine wave, and the voltage bounces around way too much. A higher quality Honda or Yamaha invertor generator should work.
Dec 08, 2014 | Televison & Video
My tv is not getting the signal from my direct dish.Just says no signal. I contacted direct and we tried several things via phone. They said the problem is with my tv not the dish or receiver. Nothing has...
Tries tv and the dish box unplug,replug it back an hour later for the tv to do a restting itself back to the factory setting and dish box to reboot and upgraded it software.This no signal problems should be fixed,not request another dish box for the replacement,because tv have no signal input bouncing around in the tv screen it is 90%-95% are broadcasting receiver boxes for tv incomming signal cable for tv signal problems.
Jun 27, 2011 | LG 37LC7D 37 in. LCD HDTV
My son was playing his PS3 for an hour or so. I went and turned it off for him when he decided to leave the room. I pushed the ON/OFF button (on the left side of the TV) and realized I had the remote...
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Jun 15, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Philips Magnavox Projection T.V
you need to replace a cople of the opticoupers most likely, if you want to repair this and save yourself a lot of dough, contact me at techman32k-at-yahoo dot com
Larry Dillon
Aug 06, 2009 | Televison & Video
White sparkly spots on screen
Dynex is a brand from BB which is very very poor for parts. It does have a problem, I would return it for a refund and look for a name brand. If I can be of any other help in your search for another one, please let me know.
Jun 07, 2009 | Dynex DX-LCD37 TV
TV screen bouncing up and down
look for the horizontal hold.
Jan 26, 2009 | Akai PDP4206EA Television
Toshiba TP50G60 Big Black Square Covering the screen?
try the closed caption adjustments. i had a tv that did the same thing and the captiong did it. turn caption off nd try.
Oct 09, 2008 | Toshiba TP50G60 50" Rear Projection...
8 month old Symphonic 20 inch lcd tv turns off itself every 3-5 seconds
these sets that shut down or turn themselves off after a few seconds usally have a bad backlite board in them. look closely at the screen and see if one section looks darker than the rest of the screen (top middle or bottom - top seems most common in my cases). some times if you put the tv on an unused input you can see the variation of light level on the screen, but don't get confussed by looking at the screen from too great of an angle. thanks ......techman 580-243-8025
Oct 27, 2007 | Televison & Video
32 in ILO tv, goes blank
Usually the blue screen is an indication that the video signal to the TV is not present. Most of the new TV's have a video input selection button on the TV and on the remote; try changing the video input selection.
Apr 27, 2007 | iLO 3200 32 in. LCD Television
Hitachi 57F510 57" Rear Projection HDTV-Ready Television Logo
24 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
