Question about Zenith DVC2200 DVD Player
Green screen??? Ok...i have a DVC 2200 dvd player...its several years old...but its worked fine until today. When i put a dvd in the player it loads...goes to the menu...then i play. But after a few minutes of doing just fine...the tv screen turns green...and its like the dvd player has frozen..won't open..won't turn off...won't do anything.. sometimes it might turn off after pressing several times...but then it will turn back on and every digit shows up on the little dvd screen. but then sometimes it will turn on do fine..then the whole green screen happens. Any sugestions on whats going on?? do i just need to get it fixed??
  • bessiekates Aug 30, 2008
    When we put DVD movies into our zenith DVD player, the movies are green. Why? What can we do to fix this?
  • 105 Answers
SOURCE: No disc is loading on my dvd player, but the screen and speacker still work.
Sounds like a major crash in the unit's microprocessor. Look for a tiny hole somewhere on the unit that says 'reset' next to it. This is actually a switch you activate by pressing it with a fine pointed pencil, or a straightened paper clip. Reset the unit. If it doesn't have a reset switch, try removing any batteries, unplugging the unit & leaving for 1/2 hour. If this fails, you will have to take the player to a qualified technician, because there are no user serviceable parts inside.
Posted on Jul 20, 2007
SOURCE: XBV442 DVD door won't open
I have opened many a player and given the tray a slight assist. Voila it unsticks
Posted on Mar 25, 2008
SOURCE: some discs won't play anymore that played fine before
Update: Just found out from Netflix that the encryption coding on many newer DVD disks is coded so that the DVD recognizes that there is a player with a recording device; hence, DVD will not play--a copyright infringement defense.
Posted on Jul 03, 2008
  • 814 Answers
SOURCE: Does not work always says check disc after loading
You need to try to clean the laser head and the transport. To do this you will need cotton swabs, isopropyl alcohol and small cans of lithium grease and compressed air.. Open the up the compartment that the dvd discs are placed. In the center of the compartment you will find the spindle and a laser transport. In the transport you will see the laser head. Take a cotton swab and put a small amount of alcohol on the tip. Rub the tip of swab gently across the head of the laser. Do this until the head look bright and shiney. Use the other end of the swab to dry the excess moisture off the laser head. Take another swab and use a small amount of alcohol on the tip and go around the transport device cleaning the dust and dirt from it. Use a small can of compressed air to blow away any dust and dirt in the compartment. Once the laser head is cleaned and the transport is cleared of dust and dirt, Move the transport to the outer most point and bring it back in to its closest point. Do this several times. Do not applie to much pressure while doing it.If you find ruff and uneven action. Clean the areas of problem and return the transport action to smooth and easy operation. If still not smooth and easy. Take another cotton swab and use some lithium grease in very small amounts to lubricate the transport rails. Again move the transport back and forth to lubricate the laser transport. This should return the transport to normal action. Now play a music cd to calibrate the laser head . Let the cd play through a couple of times. After doing this you can now try a dvd disc and it should play normally. If it still does not play correctly, check the spindel to see if it is loose. If this is the case use a drop of super glue to tighten it up. Let it dry completely and try the disc again. It should work correctly. If you are still having a problem.You either have a problem with the laser itself or the drive motor. The drive motor problem would usually be noticed on the playing of the cd. The laserhead and the motor can be replaced if this is the problem. You can find more information on how to do these repairs on you tube. Put cleaning and repairing portable dvd players in the search engine and it will bring up videos on how people have done these types of repairs. I hope this information will help you with your problem.
Posted on May 30, 2009
  • 814 Answers
SOURCE: screen won't show anything
You need to test the video output circuits with the help of the supplied cables and your television. Hook up the audio video cable supplied with the dvd player from the dvd player output circuit to the television input circuit.This set up is explained with a diagram on page 17 of the owners manual.After completing the connections, place a dvd in the player and play it. If you can see the video and hear the audio, then your video and audio circuits are still working correctly. You may just want to use this set up for the dvd player instead of attempting the repair process.The problem will be with the connections between the main board and the lcd display. This problem may be a bad connection or dirty contacts in the connection.You can take apart the dvd player and clean the connections.There is a chance that a connector is damaged and will have to be replaced.These connectors are usually ribbon cables and should not be that expensive to replace.The connector will have a part number on it. This is the number you need to look for a repalcement part.When you take apart the dvd player you should completely clean and remove all the dust and debris from the inside of the player. This can be done with small brushes and a can of compressed air. If you cannot see the playback then you are having a problem with the video output circuits. This problem will have to be repaired in a service center. The repair may not be worth it as the cost may be as expensive as a new player..The telephone number for Zenith customer support is 1-800-243-4994. They will be able to tell you how you can get service and repalcement parts for your dvd player. I hope this information helps you with your problem.
DVD Player will not power on. Power Indicator Light flashes repeatedly.
Plug out the device,Open the outer shell or strip the outer shell take a hair dryer heat up the board slightly until it feels slightly warm then plug in and switch on and remove disc.Then put outer shell back and fasten screws that where removed.
Jan 06, 2014 | Sony DVP-CX860 Multi-disc DVD Player
When I play DVD's my tv screen gets a rectangle box on it, the VHS is fine, it's just the DVD player.
Yes! you are right, this almost sounds like a captions problem, check the DVD/VCR Combo menu, if it has captions turn it off using your remote.
Mar 17, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
I have an 11 year old Toshiba DVD player. The last 2 times I rented a disk I had problems. Everything seems to be fine through the previews. When the movie starts to play, the screen goes green. The audio...
This is usually an issue with the component cables running to the TV. Remove the cables and retry with different component cables. If this doesn't fix the issue, its a problem with the DVD player itself.
As far as DVD players go, you've done quite well keeping yours going for 11 years. A cheap DVD player at the local big box electronics store here costs about $30, definitely not breaking the bank getting a new one.
Mar 07, 2011 | Televison & Video
Won't play DVDs.
I put in a dvd and get the "disc error" message. This magnavox dvd player is less than a year old.
Jan 05, 2010 | Philips Magnavox DVD/VCR Dual Player
Can not read disc
I mainly use my DVR to record TV shows on DVD-RAM discs (Panasonic brand or Maxell). I've had no problems with the DVD-RAM discs. However, today when I put a DVD-R disc in the recorder, I got an "Incompatible Disc" error message. I tried a second disc from the same set, and got the same message. I tried out some of the DVD-Rs that I recorded last year and I could read them. Tried a DVD-RAM. That was OK. So, I tried another DVD-R disc. That one is OK. I don't know if the problem is that these DVD-Rs are getting a little old (2 years??) or if the recorder is developing its own problems reading discs.
Dec 03, 2008 | Panasonic Diga DMR-EH75V DVD...
Zenith DVC 2200 brightness issue
Macrovision
An analog video copy protection scheme that alters the unseen part of a video signal such that a VCR or other macrovision enabled device may not record the video signal properly. There are several types:
- Automatic Gain Control
- 2-line color stripe
- 4-line color stripe
Symptoms of this include picture fading in and out or color banding of the signal.please mark the post as fixya!
Feb 11, 2008 | Zenith DVC2200 DVD Player
DVD player says "no disc"
replace the player because laser lens is probably burnt out.
you can get a new player for 30 bucks at target or walmart
Jan 15, 2008 | Samsung DVD-V4600 DVD Player/VCR
Polaroid pdm-0732 wont read dvd
I just solved my issue. My 2 year old son set the AV switch on the side of the player to 'in'. I switched it to 'out' and now it works fine.
Nov 25, 2007 | Polaroid PDM-0732 Portable DVD Player
No power
IF that player is new, take it back. I have the same problem on my daughters, but it worked fine until one day suddenly no power. I took it apart and found a fuse inside. I am trying to find a replacement fuse to see if that works. I had a stereo amp once that did the same thing and I replaced the fuse inside and all was well. Hope this is the same thing.
Nov 27, 2006 | Disney Princess MCP DVD2050P DVD Player
Zenith DVC2200 DVD Player Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
