Question about HP Computers & Internet
My hp will come on stay on about 5 to 7 minutes then beep 2 times and shut off how do i fix this
TRY TO REBOOT,OR SHUT DOWN AN RESTART.OR GO TO RESTORE AN TAKE IT BACK AS FAR AS YOU CAN ON THE DATE.
Posted on Feb 15, 2012
5 beeps dc 7800 ctm fix
try these
http://h30499.www3.hp.com/t5/Business-PCs-Compaq-Elite-Pro/hp-dc7800-5-beeps-problem/td-p/1142014#.VJYGUvXpAg
HP Guide to beep codes:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=uk&lc=en&docname=bph07107
(see your machine spevcs for which BIOS you have if you don't know)
http://h30499.www3.hp.com/t5/Business-PCs-Compaq-Elite-Pro/Boot-problems-with-dc7800-CMT/td-p/1080736#.VJYHL_XpAg
and many more generated by searching the internet for "5 beeps hp dc 7800"
The second reference I posted is possibly the place to start
20.December.2014
May 21, 2014 | HP Compaq dc7600 PC Desktop
Lenovo desktop 3282 beeps twice then 5 times and goes no further
Follow these steps to clear the password:
NOTE: These steps also clear CMOS.
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and
then unplugging the AC adapter from the computer.
4. Remove the battery
5. Remove the real-time clock (RTC) battery
6. Wait approximately 30 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any batteries at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
Aug 01, 2012 | Lenovo Computers & Internet
My E machines PC (5 yr old w/ XP) shuts down
I should have been glad if you count that beep for me. Every beep codes have distinct message. Anyway, may my tips shoots ur problems :
1. unplug the main power cable and remove the cpu cover.
2. check RAM sticks, power supply ports and other add on cards if properly seated.
3. And then back on.
Jul 29, 2010 | E-Machines eMachines Desktop PC
HP Pavilion dv8113cl Notebook PC 1 long 2 short beeps when I turn it on. Let it set for a while it will come up for a few minutes then shut down. I have have change the memory, but it did not make any...
First Check if You can run it w/o the battery on board , just by the Ac cable, and see if the laptop stay on, ifso the 2 beeps are indicating that the battery has died. If it does not stay on like with the battery in, then the internal power supply has died. and will need replacing.
Jul 14, 2009 | HP Computers & Internet
The control panel stays lit after cycle ends. it won't shut off and beeps several times during cycle
Hello grumpy 96
Welcome,
You said, the control panel stays lit after cycle ends. it won't shut off and beeps several times during cycle
First try Pressing STOP/CANCEL to clear the display.
If this does not do the trick.
Sounds like we need to try to reset the system!
Huuum At your service!
Lets try this,
Like with an error code.
This can reset the system if it is electronic!
Unplug the appliance and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works!
Waiting for your reply!
Please remember to leave a rating when you are done!
Thank You
Huuum
Please remember to leave a rating before you go!
Thank you
Sep 06, 2008 | Whirlpool GEW9250P Electric Dryer
HP 1 long and 2 short beeps
I had the same problem. Turn on your laptop (dv2000) and let it do its thing with the black screen and One long and Two short beeps. Keep the laptop plugged in...Now here is where the "are you kidding me" part kicks in.
Wrap your laptop (while it's on) in a blanket and put it on a bed or a couch (where the laptop won't have room to circulate air beneath it). You must leave it wrapped in the blanket for about 30 minutes minimum, or wait an hour if possible.
Chances are, your laptop will get ver hot and shut itself down at some point before you come back in an hour. When the hour is up, try turning on your laptop again. Ideally, it should work and you now have a working laptop again.
I realize this sounds crazy, but I am typing this quick fix from my dv2000 after doing exactly what i just subscribed. I read it on some other forum when i was on my wife's pc. If this doesn't work the first time, try it one or two more times. This trick has something to do with getting a "broken" (?) connection between the video card and the motherboard soddering back together.
Hope this helps at least one of you. Good luck.
Jul 23, 2008 | Computers & Internet
HP ZD 8215 Laptop Start-up Problem.
2 beeps with no post means either you have a memory failure or the motherboard has failed
Jul 16, 2008 | HP Pavilion zd8000 Notebook
HP mx705 17 in.CRT Conventional Monitor vertical goes bad
While it is sounding like a hardware problem. I'll throw in my 2 cents. Have you check the cables from the power to the source and from the monitor to the computer. Just make sure those aren't loose. One other thing...you mentioned you turn off the computer "afterwards" then it fixes itself. Is the fix for longer than it turns on at first? or does it stay on longer then goes out? Let me know what happens. Good Luck, Tim
Mar 14, 2007 | HP mx705 17" CRT Monitor
Computers & Internet Logo
24 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
