Question about Shure SM58 Professional Microphone
My shure mic receiver SLX4 is showing Ready indication but not recieving the Audio from SM58 mic...whether it is reciever problem or transmitter.. what is the solution
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
If you shout into mic and the audio signal LED on receiver lights everything is ok.First check your receiver to amplifier jacks and cables,If ok check muting transistor inside the receiver next to the audio output terminal.As an expert on cordless microphones I'll be glad to answer your questions. Send me an e.mail if you wish at moska.1982@yahoo.com
Posted on Sep 15, 2012
night71
  • 328 Answers
SOURCE: feedback
That is a great mic. It has a lot to do with the room your in and acoustics of it. If you are too close to your PA or monitor, it will also feedback. Lowering treble and reverb will also help.
Posted on Nov 04, 2007
  • 3 Answers
SOURCE: shure sm58 mic does not have full power
You should consider a microphone with more power to get the volume you need. I can personally recommend the CAD C195 Cardoid Condensor microphone. It has great output. The only downsidefor most people is that they don't have phantom power. This is what gives the mic its boost. In order to get the most out of any micrphone, you need to have a preamp, an equilizer, and an output. The output is your PA system that drumbanger mentioned.
But since you are using a Peavey, here is my strong recommendation. Get a mini preamp, and hook it up to your Peavey. You can use a Behringer 2mic mixing board for your preamp. It's small, and it can sit right on top of the Peavey.
XENYX 1002
http://pro-audio.musiciansfriend.com/product/Behringer-Xenyx-502-Mixer?sku=631262
CAD C195
http://pro-audio.musiciansfriend.com/product/CAD-C195-Cardioid-Electret-Condenser-Microphone?sku=270775
The reason why I suggest the two-mic XENYX 802 and not the 1 channel 502, is that the 1 channel doesn't have phantom power.
In order to connect the XENYX to your Peavey, this is all you need. You can get one at radio shack for pretty cheap.
http://accessories.musiciansfriend.com/product/Mogami-Pure-Patch-RCA-to-14-Mono-HiDefinition-Patch-Cable?sku=339031
Posted on Mar 22, 2009
  • 6 Answers
SOURCE: i have a shure sm58 wireless microphone when i
Unfortunately the sm58 capsule is very hard to get apart without damaging the contact surface.
You would have to take the contact side apart 1rst
bend all the little tabs away which hold the brass plated disk in place
then its a matter of edging the disk out....CAREFULL any scratch is bad!
Once you have the disk out you will need a 1/4" socket to remove the shaft bolt,
unsolder the green and yellow wires taking note where they were soldered.
Then the element can be pulled out.
What to after that, I'll let that up to you.
Be wary, you will void warranty.
Posted on Jun 30, 2009
SOURCE: Shure T2 SM58 intermittent transmit
Two screws on the back of the battery casing, then prise out the battery tray (it's a detachable moulded tray in the mic body) using a small screwdriver in the slot near the power button. Under the threads of the battery cover is screw which holds in the PCB, unscrew this. Take the full mic head off (not just the ball, but an inch further down with the capsule in it), and remove the circlip inside. The PCB then slides out towards the head end of the mic.
Posted on Mar 30, 2010
  • 417 Answers
SOURCE: shure sm58 just started outputting very low volume
Check your wire connections inside the mic where the xlr cable connects to the mic. Hopefully your mic has never been dropped as this will damage it. The sm58 is pretty much indestructible, so check your cabling that you use, try a different channel.
Posted on Apr 15, 2010
Is sm58 wireless mic compatible t4a receiver-shure
The "SM58" is just the cartridge on the top. It would depend on the model of handheld transmitter. The model number is on a sticker in the battery compartment.
Nov 07, 2012 | Shure SLX24/58 Wireless Microphone System...
Unable to syn my slx2 mic to reciever
Make certain it is an SLX4 receiver in the same exact frequency band as the SLX2.
May 14, 2012 | Shure SM58 Professional Microphone
Have Shure T2 Wireless transmitter - no audio - can fix?
There is a company in Chicago that can still repair old Shure wireless. Delta Audio 877-764-3634.
Oct 19, 2011 | Shure SM58 Professional Microphone
How do I reset the channel and group on my SHURE SM58?
The easiest way to change the microphone is to sync it to the receiver.
Jun 03, 2011 | Shure SLX Series Wireless Microphone...
Mic not working
On some mics, one of the lights will NOT turn on unless the battery is low. The mic is the transmitter, so I am not sure what you mean by it not lighting, but the transmitter is lighting?
Make sure the mic's freq. is within the scanned range of the receivers. Often the mics get mixed with other receivers and the resulting pair are incompatible.
The receiver should show if signal is being received. If it is, then the module in the microphone dynamic cartridge MIGHT have been damaged. If it is damaged, it has to be replaced.
Apr 27, 2010 | Shure SM58 Professional Microphone
Shure radio mic no sound
Call Shure Applications to help you troubleshoot at 800-516-2525, option 1. Have the wireless system and PA nearby when you call them.
Jun 04, 2009 | Shure SM58 Professional Microphone
Shure SM58 Professional Microphone Logo
193 people viewed this question
Top Shure Audio Players & Recorders Experts
Ben Armstrong
Vito Vacirca Jr.
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
