SOURCE: wat kind of wire should i use
What does the fuse on the back say? AWG 4 has around a 60 amp capacity, AWG 2 is about 95 amps. I wouldn't suspect you would need larger than 2. Remember the higher the Gauge the more Resistance per foot you have which means more of a voltage drop at higher current.
SOURCE: I have an mmats pro audio car amplifier model
i believe your amp is 2ohm stable so be sure your speaker are wired for a 2ohm load or higher anything below 2ohm would throw the amp into protect
