Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
System date keep on change
On every boot system date keep on going back to Nov. 2003.
    Problem Solver:
  • 10 Answers
I would do a master reset... but remember, this clears all data (except provider sw) from your phone... so make sure your address book is saved to your sim and if you have important msgs/pics/vids/audio, email them to yourself because the reset will clear them
Posted on Oct 29, 2008
What year is my savage 30-06 model 110 serial number F979072
. The "dating" service is intended more for dating and documenting the older collectable guns that are no longer in production and were made prior to 1980.
"F" prefix with a serial number lower than F498821 = 1989 thru Nov. 1st, 1995
"F" prefix with a serial number higher than F498821 = Nov. 1st, 1995 through the end of 2002
"G" prefix started in 2003 with the introduction of the AccuTrigger
"H" prefix started in January of 2010
Nov 26, 2017 | Optics
Change in display
Go to options - display - date/time format. Change it to short
Nov 27, 2013 | Panasonic KX-T7731 Corded Phone
New unit used 3 days. Microwave beeps and screen goes to menu, or set time screen. Sometimes changes the date all by itself. Does this in the middle of the night all night long.
I advice you to contact service if it has guarantee. This seems to be a psychological problem about your oven(!). Technical person need to do an electronic research surgery on its board to see if there is any wrong thing.
Nov 05, 2012 | Whirlpool GH7208XR Convection / Microwave...
Advent 5431 date keeps changing back to 2008
IS your TimeZone is Correct?
Right click on your clock, choose Adjust Date/Time.
Click Time Zone Tab. Make sure your Time zone is correctly set.
Boot into the BIOS (setup) screens and check the date and time there. If the date is off by years then that verifies you need a new CMOS battery. Do not confuse the CMOS battery with the large external battery you run the computer with.
Jul 25, 2012 | Advent Netbook
Bad back-up battery
If the computer cannot keep the Date and Time after you set it and when you boot up next time the Date and Time has changes or not set then the BIOS battery is flat and needs to be replaced.
When you remove the case the BIOS battery most likely will be a coin size 3volt lithium battery, type CR2032.
After replacing the BIOS battery, boot up the computer and go into the BIOS setting and set the Date & Time etc.
Jun 13, 2012 | Compaq Presario S4000NX (DF213AR) PC...
Volume setting keeps changing
This will work on if you are using windows XP. If you are using any other OS please revert back.
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On until you get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows. Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
If you feel that, my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Dec 18, 2011 | Computers & Internet
I suspect the on-board battery because I did some minor maintenance and when I re-booted the computer the time and date were at January 1, 2004 at 12:00 a.m. I have the SG-80
Thanks for using Fixya.
If your system BIOS time keeps on going back to Jan. 1, 2004 without you changing it. There is a 95% chance that you have a bad battery. All you need to do is to replace it. If replacing it doesn't help, try checking the battery terminal if they are still good. I hope this helps.
Thanks and have a nice day.
- Hotratchet
Nov 03, 2009 | Abit SG-80 Motherboard
Laptop
cmos battery is what keeps you system date. It sound like the cmos battery might be bad. If it's under warrenty I would definitely send it back. less headache to try to troubleshoot yourself.
Joe
Mar 24, 2009 | Acer Computers & Internet
NEC Dterm80- I need to change the date
On the adminstrator's phone (usually ext 100, 101, 110 or 10)
Do not lift handset
Press the FEATURE button
Dial 9#
Enter the hour & minutes (ex:01:25) using the dialpad
Press RECALL button to change AM/PM setting
Press HOLD to change the calendar setting
Press FEATURE button again to save & exit
Hope it works for you
Nov 03, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Roll back date
upon booting up press F2 of DELETE to go to bios set up and there you can change the time/date settings. or you when you are on the windows destktop already, on the system tray (lower right corner) you have there your system time, double clck it to adjust the date/time.
Dec 05, 2007 | Computers & Internet
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
29 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
