SONY KF WE 50S1 THERE ARE A LOT OF BLUE DOTS ON THE MONITOR SCREEN PLUS A GREEN TWINGE IN ONE CORNER AS IF THERE WAS SOME LIQUID BETWEEN SURFACES. REAR PROJECTION.
  • tony_h609 Oct 25, 2008
    SONY KF WE 50S1 PROBLEM WITH BLUE DOTS AND A GREEN TWINGE ON BOTTOM RIGHT HAND CORNER WORKING IT'S WAY TOWARDS THE CENTER OF THE SCREEN. THE ACTUAL PICTURE IS GOOD. IS THIS THE OPTICAL BLOCK ON IT'S LAST LEGS. NOT A DEGAUSING PROBLEM.
    Thanks for the help. Many hours of time saved by this advise. I feel sorry for so many people who purchased this sony system paying good money and for a 3 year tv. It was good to see Sony did help some by being persistant with their problem. I would have hated to be the first person ringing Sony about this problem just out of warranty. Thanks again.
    Scholar:
  • 136 Answers
This problem is caused by malfunction of the power supply unit.
Due to loose solderings of some SMD components on the power supply board, one of the supply lines could not provide enough current if the screen is bright.
Please be aware that at longer term there will be a big bang from the set and there will only be sound, or the set doesn't work at all. In that case, two of the FET transistors will be shortened.
The new power supply boards do have an improved design to avoid problems in the future.
After removing the back cover and the internal shielding plate, replacement could easily be done by removing only eight screws.
Posted on Oct 25, 2008
  • ready2helpu Oct 25, 2008
    Have you tried clicking the Photo button on the post editor's task-bar and following the instructions? Be sure to read all requirements and instructions. You are probably right to conclude that the problem is with the optical engine. However, due to the cost of a replacement,
    I suspect that the problem is with the optical engine. Its definitely not the roadmap problem or dust. I'm wondering if the optical engine simply isn't seated properly. What happens if you push or pull on the top of the set? Does the area affected change?
    The one gent was real close with his suggestion. Pull on the top of the cabinet. If the spot moves in relation to the edges of the screen, then it's in the engine. If it remains stationary, its the mirror. Those mirrors are notoriously difficult to clean.
    mostly it would be bad optical block.
    feel free for further assistance.
    thanks.
    if you want to call a engineer at your door step to repair it in front of you at your place
    this is the link just click the link directly.
    http://www.ercservice.com/Sony-repair/so...
    they repair any type of problems in sony televisions.
    and also provide you a warranty of near about 3 months if same problem presists again they do it for free.
    thanks.
    keep us all updated.
  • 905 Answers
The liquid look is the best clue for indicating a bad block
    Genius:
  • 1,011 Answers
Dear,
check if there is any interuption of indictive device.. change the angle of your monitor.. moreover,
did u put some magnet infront of it...
degauss should help
regards,
dont rate it until it helps or fix it
  • 3,037 Answers
Yes, you are experiencing an 'Optical Block' failure. Google 'Sony Blue Haze' and you will find a wealth of information relating to this particular occurrence. You could either replace it or get a new tv. If you need further help or have more questions, please let me know
  • 320 Answers
Is this a European model, as I am in the states and don't recognize the number. It sounds like what I see here as being a bad optical block with the following conditions:
Is it a LCD or SXRD projector?
Does the problme show up on all inputs and is it visble in the OSD and menu?
If so, it is likely a bad optical block. Depending on the warranty and any extensions Sony has given in your area (in the US, Sony has extended the warranty on several optical blocks) you may have complete coverage, the block may be under warranty and you may have to pay labor, or you may have no coverage at which point you're looking at a pretyy hefty repair bill, think $800 - $1500 for the block alone. Hope this answers your question.
  • Any Guy
    Any Guy Oct 25, 2008
    If this is a LCD projector, degaussing will have no effect whatsoever.
  • Any Guy
    Yes you are likely looking at a bad optical block. You did not say that this was an LCD projector, but I am assuming so. Plesse disregard all of the other fixes offered; if this is an LCD set, then YES you have a bad optical block. Sorry!
    Genius:
  • 1,250 Answers
DEGAUSS YOUR TELEVISION, ALSO CHANGE THE LOCATION OF TV
Problem with blue dots on screen plus blue haze in lower left hand corner. Replaced lamp approximate 1month ago with Phillips lamp Assy. Blue dots started to appear about 1 week ago and are increasing in...
The optical block is most likely causing the problem. It will continue to get worse. Sony may help with the repair since they have had a lot of problems over the years with their optical blocks across many models. On the older sets they usually only help with the parts cost. The average repair cost for a optical block replacement is $1200.00 to $1500.00. So if they help with the parts cost it really brings the cost down. Their customer service number is 1800-222-SONY.
I hope this helps,
Skyassoc
Dec 15, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
SONY KF-WE50 Preojection TV
You most likely have a bad optical block. The blue dots are a pretty good indication of this. Sony has extended the warranty of some of their models to include an extension on the optical block replacement. I don't recognize your model number (Not a US model?) so you will have to check with Sony in your country to see if your set is covered. Please be sure to rate this solution. Thanks!
Nov 03, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Bad picture
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Sony LCD Rear Projection TV - Optical Block Problems
http://splinke.googlepages.com/sonyrearprojectionlcdtv-opticalblock
Jan 19, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony wega KDF-42WE6 55
Jan 16, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
Sony TV Screen
Is you model listed below?
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KF-42WE610
Sound but no picture, tv will not turn off. Light goes red but a dim overall blue screen remains and fan is still running.
Nov 15, 2007 | Sony XL-2100U Projector Lamp for...
Kf-42610 blue hue and blue dots on screen
Hi Guys
The Blue dots or discolouration you are seeing is due too the Blue LCD screen having cracked from excessive heat. This normally happens when you have a power failure while the Television was on. This obviously because the Blue LCD sits next to the lamp - the main cause of heat. The correct part number on the 60" is A-1086-952-A. It is very, very ,expensive.
Sorry to have been the bearer of bad news. Good luck : )
Aug 29, 2007 | Sony XL-2100U Projector Lamp for...
Sony KF50we610 blue dots and blue cloud
Check the optical block repair at sony's warranty website...
Could be the problem they have been covering it under a recall of sorts. $1250 for the optical block and they are only doing it until the end of the year so don't waste any time
May 03, 2007 | Sony XL-2100U Projector Lamp for...
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
