Question about Uniden DECT 6.0 Cordless Phone ID
Help turning eco mode on
I need help getting through the menu & turning on the eco mode on a set of Uniden D1680 digital phones .
5 Suggested Answers
SOURCE: My uniden powermax 5.8 ghz set itself to Do Not Disturb.
The do not disturb feature (DND) allows you to mute the ringer, the base, and any registered handsets at the same time. The phone must be in standby mode. Press and hold do not disturb on the base. You will hear a confirmation tone, and the DND LED illuminates. To cancel the DND feature, press do not disturb again. You can also mute the ringer tone while the phone is ringing by pressing do not disturb on the base.
Activating the DND while the answering system is off will turn the answering system on automatically. The answering system setting will reset to the original setting when you cancel the DND.
If you press answer on/off when the DND and the answering system is on, both of the DND and the answering system will turn off.
To mute the ringer tone temporarily for each handset or the base, when the phone is ringing, press the MUTE soft key on the handset or the base. The ringer tone will return to the previous setting starting with the next incoming call.
Posted on Jul 07, 2009
  • 102366 Answers
SOURCE: Problem with Uniden D1680 Cordless Phone I have a
Press MENU/SELECT to bring up the menu. Select "Ans. Setup". Select "Ring Time".
The above is condensed from this manual.
Posted on Oct 10, 2011
  • 102366 Answers
SOURCE: I just purchased a Uniden
You can download the manual at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1680om.pdf
Posted on Oct 16, 2011
  • 61 Answers
SOURCE: I HAVE A UNIDEN d1680 SERIES PHONE AND WHEN
Try to reset the phone, remove all the handset batteries, disconnect power adapter and let it sit for 3-5 minutes and put back the system. This will remove all the phone memory and clear all the glitches.
Posted on Oct 22, 2011
Uniden DECT6.0 Model D1680 Problem: Need to change recorded message ,cant get past Security Code_ a 2 digit pin .Forgot what is was..
The only time the Security Code is used is to effect
Remote Access, ie, "call home and manage your
answering machine messages remotely" by pressing
the code numbers while the Greeting is being said....
The Security Code is set on the D1680 from the handset
by this procedure:
press [menu]
scroll to "Ans. Setup"
press [select]
scroll to "Security Code"
press [select]
the code will be displayed, first digit blinking
(enter a new digit if you want to change it )
the code will be displayed, second digit blinking
press [select] (chirp) press [END}
All of the Answering Machine System functions can
be managed remotely, and voice menus are provided
to guide you in these operations.
Entering the model number found on a small sticker under
the battery in the handset at www.manualslib.com will
fetch a free copy of the User's Manual in case the original
has been misplaced.
Apr 01, 2016 | Uniden D1680 Cordless Phone
Uniden cordless 6.0 answering machine , reset code on security code answering machine?
To reset the Security Code for remote access into the
answering machine system ( model D1680 & similar )
1 press [menu]
2. scroll to "Ans. Setup" press [select]
3. scroll to "Ans. Setup / Security Code" press [select]
4. first digit will be blinking, enter two digits of your choice
5. press [select]
6. press [END] to conclude & exit
Apr 11, 2015 | Uniden DECT 6.0 Cordless Phone ID
Uniden D1680 will not ring
you have silent mode turned on try umplug the base uniy for about 30 sec and plug back in or go to instructions book
Jun 21, 2014 | Uniden D1680 Cordless Phone
D1680-2C How do I shut off the ringer?
On the handset, press down-arrow while in standby mode. On the base, press - while in standby mode. See pages 4 and 6 of the manual.
Apr 08, 2014 | Uniden D1680-2 Expandable DECT 6.0...
How to turn ringer on and off on uniden d 1680 phone
To change the ringer volume, press up/down arrow while in standby mode.
For Silent Mode, see the instructions on page 10 of the manual: http://www.fixya.com/support/p12727093-uniden_d1680_2_expandable_dect_6_0_cordl/usermanual-E94DC8B-pdf
Jan 25, 2014 | Uniden D1680-2 Expandable DECT 6.0...
How to turn ringer on uniden D 1680 phone
How do i set date and time on my new d1680 cordless phone
Use the "Date & Time" menu. See pages 7 and 8 of this manual.
Jan 02, 2013 | Uniden D1680
Accidentally hit 09 when calling home and it turned answering system off. How turn it back on?
Assuming you have hung up your phone and aren't at home, dial your number and wait for the phone to ring 10 times. You should hear a series of beeps. Press 0 and then your security code. Then press 0 6 within 15 seconds of getting the system to respond to your code. The system returns to standby when there is a delay of more than 15 seconds between key presses.
This works for the Uniden D1680 but works for some other Uniden systems. I know 0 9 turns off the answering system for the D1680. Many Uniden DECT phone manuals are available here: http://www.uniden.com/scat/dectphones_mnl . They are listed in alphabetical and numerical order. Some of the other Uniden phone manuals are available by using the drop-down menu to select the Product Category on the right side of the page (near the top).
I hope this helps.
Dec 18, 2012 | Uniden Cordless Phone
Problem with Uniden D1680 Cordless Phone I have a uniden d1680 cordless phone system. How do I adjust the number of in bound rings
Oct 09, 2011 | Uniden D1680 Cordless Phone
Uniden DECT 6.0 Cordless Phone ID Logo
257 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
