Hitachi Magic Wand Hv250r Hand Held Massager
Problem for Hitachi Magic Wand Hv250r Hand Held Massager
Sounds like its working, but nothing happens
By acbernard on Oct 25, 2008
Although my magic wand sounds like it is working when it turns on, the head of it no longer vibrates. How do I fix this?
Best Solution
posted on Oct 28, 2008
Very Helpful)
Annais69
Rank: Apprentice
Rating: 100%, 3 votes
I had the same problem with mine, it's due to the fact that the smaller spring has become un-lodged from the ******** itself.
You will need:
1. Roll of electrical tape.
2. Utility Knife
3. A small slot head screw driver OR a pair of needle nose pliers.
The solution is to unscrew the silver ring so that is can be moved up and down. Now, you need to use a utility knife and cut the blue rubber off of the spring. Once you have the blue rubber but off you can see a large spring with another smaller spring inside. Push the head of the ******** till the larger spring's coils are an 1/8 to 1/4 of an inch apart. Next take either the small slot head screw driver or a pair of needle nose and jam the smaller spring back into the hole in the center of the white plastic piece inside of the larger ring. Next plug it in to make sure the vibration is working, reattach the silver piece and tape the larger spring with electric tape.
Comments:
Oct 28, 2008
- sorry it censored "massager"
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Hitachi Magic Wand Hv250r Hand
Questions and Unsolved Problems for Hitachi Magic Wand Hv250r Hand
Do you recommend Hitachi Magic Wand Hv250r Hand Held Massager?
Answer
Answer
75%grey on ''Salt&Pepper''Dark Blonde=6/0 base, requires coverage of Grey yet lightening of... (More)
Answer
I can no longer find your neck and neck pilow in ontario and I have degenerative disk disease and of... (More)
Answer
who is be my future boyfriend
Answer
I followed the steps in the solution but I having difficulty putting the spring back in place. My... (More)
Answer
motor still runs, but vibrations don't come through the head
Describe your Neck Rests problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Neck Rest Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
