Reddy heater r30 model starts fine , but will only run for a minute or two before shutting off. Has new sparkplug and good fuel. What else could cause this?
Buffalo12980
  • 625 Answers
SOURCE: Garage Heater
the kerosine heater uses a spark plug for ignition and a photocell to detect flame. at the back end of the blower motor is an air compressor. it is a vane and diaphragm compressor that supposed to put out 3.6 psi of air to the fuel nozzle. the fuel nozzle is a venturi type that creates a vacuum across the orifice to suck fuel from the tank. try this site for spare parts www dot desatech dot com. its the same place I get parts for repairing heaters.
Posted on Nov 30, 2007
  • 19 Answers
SOURCE: 50K BTU Reddy Heater Trips Circuit Breaker
If the unit lights Check the photo cell this can be done with an ohm meter and good light. Should have continuity in light.
Posted on Mar 02, 2008
  • 19 Answers
SOURCE: REDDY HEATER
Check the photocell with an ohm meter in bright light should have continuity.
Posted on Mar 05, 2008
tbugger
  • 232 Answers
SOURCE: reddy heater will not fire.
Your problem is most likely the lack of pressure from the air pump. Your pressure is extremely low. Pressure on a 100k heater should run 5psi. At 3psi there is not enough fuel and not enough air to atomize whats there. Bump the pressure up. If it won't come up, then you have an air leak. Test w/ soapy water. Keep your fingers clear of the fan!
Posted on Dec 04, 2008
SOURCE: reddy heater pro 110
Need parts for readdy Heater Pro 110 New
Posted on Jan 08, 2009
Starts runs for 3minutes then shuts off
pressure should b at 6 to 6.5 clean nozzle check for cracks in air ling and fuel make sure both filters r clean and the flame sensor is clean good luck
Dec 07, 2013 | Reddy Heater-70,000 BTU Kerosene w/T'stat
I HAVE A 170 REDDY HEATER THAT RUNS FOR APP.10 MINUTES AND QUITS BLOWING OUT BLACK SMOKE I HAVE CHANGED FILTERS AND CHECKED PRESSURE WAS AT6. PSI CAN YOU GIVE ME ANY HINTS
sounds like you have dirt in your fuel tank, as the heater runas it picks up the dirt in the filter plugging it up. When the heater shuts off, the dirt falls out of the filter. You start the heater back up and it does it all over again. Empty your tank and change the fuel filter. Should be fine then.
Feb 21, 2013 | Reddy Heater-170,000 BTU Kerosene Deluxe
Ready heater forced air runs few minutes then shuts off
Sounds like a full services like its getting too much air,and blowing out the flame. Check your fuel filter,and add a new spark plug ,also change the vanes on the pump, thus aFuu service. these sould be performed every fall before .
Dec 16, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Reddy heater model r100a runs approxamitly 15 to 20 minutes then kicks out.fan seems to run fine and already replaced the spark plug.
generally if a heater with a spark plug will run for 10 minutes or longer then that’s an indication that the electronics are functioning properly, so for now, eliminate "any fuel delivery problems" before trouble shooting the electronics. The spark plug should spark for the duration of the run time. If the flame goes out the heater shuts down (just like its designed to do). Imagine the fumes & danger involved if the heater continued to pump raw fuel into a hot combustion chamber!
Some possibilities:
  1. the plastic end cover is cracked. When the room heats up the crack expands allowing the air pressure to fluctuate.
  2. the air pump pressure is not correct. (instructions at www.reddyparts.com )
  3. the fuel filter is restricted.
  4. the nozzle is restricted or worn.
  5. there is an air leak between the pump & the nozzle.
  6. water in the fuel. When a droplet passes through there is a momentary flameout condition which will cause the photocell to shut the unit down.
  7. The photocell is defective
Some more troubleshooting tips
Mar 10, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater shuts down prematurly
If the heater runs fine for the 15 or so minutes without smoke/odor- do this
  1. check for water droplets on bottom of tank
  2. check for restricted fuel filter
  3. test photocell
  4. test safety control (reset)
You don't state whether this is a spark plug heater *or* Hot Surface Ignitor type. I made the assumption you were inquirung about a Spark Plug Heater. Disregard the list if the heater is an HSI type---- troubleshooting is different.
More troubleshooting tips for a Spark Plug Type heater
Dec 25, 2008 | Reddy R70ET Utility Heater
THE HEATER STARTS THEB BLOWS ALOT OF SMOKE
There are any number possibilities for intermittent running.
1. Bad ground connection at the Ignition Device (transformer, spark box)
2. restricted fuel filter causing fuel starvation
3. crack in the plastic end cover
4. crack in the airline
5. crack in the fuel line
6. crack in the nozzle adapter
7. water in the fuel
8. Others I’m sure I left out
You must be the one to troubleshoot & find the cause.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heating & Cooling
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
