Question about AOC CT720G 17" CRT Monitor
Color dis-order and then flickering display
It starts with color disorder, i mean the color blue display lost...only green and yellow..
then the display controller is not functioning, i mean i cannnot change the views of my minitor(brighness,size etc)
then finally it results to flickering of the display
    Problem Solver:
  • 8 Answers
Try uninstalling and reinstalling the monitor drivers if any are applicable, run a direct X test on your hardware make sure your video card is OK. Try doing a wiggle test on the VGA cable that is plug ed into the back of your computer, that sends the signal to the monitor. Work your way from one end of the cable to the other, look at the monitor screen and see if there is any change in the color , if that don't do it its possible there could be a lose connection between the circuit board and the picture screen inside the monitor, unless your mechanically inclined and know some basics of electronics its recommended you don't do this and get some one who is qualified to do so, but if you are mechanically inclined and do know basics of electronics and if your feeling confident remove the power cord from the wall outlet, remove the power cord from the back of the monitor, shut down your computer and unplug it from the wall outlet, remove the VGA cable from your computer, examine where all the screws are that hold the housing from the monitor together put a white sheet on your bed and carefully and slowly split the housing which are the front and back of your monitor, in the center of the white sheet so if any screws fall out you'll see them on the sheet, when you pull the two halves apart, if it doesn't come apart don't force it study its body and check for more screws when you get them apart , before you touch anything inside the monitor touch a metal object some where in the room that has no electric or electronics on or with in it, to release any static electricity from you body once you do so and open the monitor check all connectors for looseness or any corrosion don't touch anything else but the connectors. if all is well and the problem still exist bring it to a repair shop or bye a new one go to EBay or try www.MicroCenter.com those are your cheapest places, unless money is no object.
Posted on Oct 30, 2008
Excess green and yellow in KDFE50A10
Absence of Blue color is the fault. The t'Con board or panel should be suspected. Contact any experienced service technician.
Aug 29, 2012 | Sony KDF-E50A10 50 in. LCD HDTV
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
My dell 1201 projectors displays only in yellow
you have most likely lost 2 of your color guns, most projectors have RED, Green and BLUE as the projector colors (some newer projectors have added a 4th color). if one of your color guns has gone out, you may experience colors that are not correct. that is where I would start. go to the convergence routine, in your setup menu. this is where you can determine if one of your "guns" has quit working.
Mar 23, 2011 | Dell 1201MP Projector
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
I need to know what each color means on the existing radio stereo wires please... 1999 chev silverado.
I think this is the right table, but I don't know if it will display right. If not, go to http://www.installdr.com/InstallDocs/GM/PDF/460005.pdf
Typical GM Factory Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
Sep 06, 2010 | 1999 Chevrolet Silverado 1500
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Monitor colors not displaying any red only blue/yellow
update the latest driver for your video card might help.
Mar 19, 2009 | Gateway FPD1760 Monitor
RCA Pearl TH1100A backlight colors
Pp. 16-17 of your user's manual:
http://www.rcapearl.com/pdf/TH11xx_IB.pdf
Settings
Press forward to enter the Settings menu and then
press plus or minus or to highlight an item. Press play
repeatedly to change settings.
Backlight:
• to adjust the time before the display light
turns off (On/10s/20s/30s).
• to adjust the color of the display light
(Red/Blue/Green/Yellow/Cyan/Purple/White).
-Tha Mp3 Doctor
Dec 13, 2008 | RCA TH1101 MP3 Player
We just received a big screen tv as a gift and we want to hook up our dvd player and our vcr and have lost the manuals. HELP
You can hook your dvd player in tv by using component video input terminal having green-red-blue colors for video signal and red-white for audio signal. so total 5 wires been used here. color order should be exact at both units, tv and dvd player i.e green to green, blue to blue and so on.
vcr can be hooked at composite video input in tv having 3 pins, yellow for video, red-white for audio in both units, vcr and tv. pins color should be exact on both units.
need further help, post here please.
Sep 24, 2008 | Televison & Video
Pioneer DEH-P3700MP CD Player
Constant 12V+ Orange Switched 12V+ Yellow Ground Black/White Illumination Gray/Black Dimmer Brown/White Antenna Glass Front Speakers 5 1/4" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Sep 02, 2008 | Pioneer DEH-P3700MP CD Player
AOC CT720G 17" CRT Monitor Logo
89 people viewed this question
Top AOC Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
