Question about Ricoh Aficio 2018 Copier
Ricoh 2018 how to fix the crumpled paper?
2 Suggested Answers
  • 8404 Answers
SOURCE: Ricoh Aficio 2018 ink rubs off paper too easily
Your corona wire is not function properly ... dirty or broken ... and/or the heater is not up to par.
Replace the corona and the heater roll to fix this problem.
Posted on Jun 22, 2010
Ricoh aficio 2018 Paper jam B category but can't see any paper
CHECK ALL THE SENSOR WHERE THE PAPER PATH GOING TO EXIT
Jan 28, 2014 | Ricoh Aficio 1232C Color Copier
Second copy is crumpled
You need to isolated a problem.Verify the vertical conveyance feed and clean the feed rollers,verify the fusing unit and a duplex unit,and verify the exit unit.Stop the copy process before the paper enter in the fusing unit,and verify if the paper is crumpled or not.If is crumpled verify the paper tray rollers(casette feed rollers,vertical transport rollers).If not crumpled stop the proces after a half copy is out on the fusing unit.If crumpled change or clean the upper and lower fuser roller and the lower roller cleaning roller(aluminium roller)in the fusing unit.
Dec 14, 2013 | Ricoh Aficio 2015 Black Toner Cartridge...
Paper mismatch officejet 6500 crumples
There could be a foreign object or torn piece of paper that's stuck further inside the printer mechanism path. Try using a flashlight and inspecting any access or clean out hatches. Sometimes something will be caught inside and cause the paper you feed in to crumple and create a jam. I watched a video on youtube giving different ideas on how to fix this problem. Fixing Paper Pick-Up Issues
May 27, 2013 | HP Officejet 6500 Wireless All-in-One...
Paper size not original and continuous sheet not working in tray.
be sure that tray paper measure compatible with machine soft ware
Apr 30, 2011 | Ricoh Aficio 2018 Copier
Jun 22, 2010 | Ricoh Aficio 2018 Copier
Ricoh Aficio 2018D
This could be a very bad code its "main motor lock", either you have too much load on the drive unit ( paper stuck, locked up pcu or fuser ) and maybe bad BICU board.
-Carl, please let me know if this helps.
Jun 26, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Paper jam
If it is getting crumpled in the tray, there is something blocking the paper path.
What I would suggest is taking out the toner and drum cartridge, then remove the paper tray. Tip the machine on it's back and look into the paper feed area for something blocking the paper path.
When it is crumpling the paper like that, the feeder is working fine, just something blocking the paper path.
You can take a minela folder, and gently push it through the paper path to dislodge the obstruction.
Mar 31, 2008 | Sharp AL 1631 Copier
Ricoh Aficio 2018 Copier Logo
43 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
