Question about Night Owl Optics Cyclops Compact NOCC3 Monocular
The monocular does not work after installation of a new battery.
It appears after removal of the eyepiece, there is a white film over the internal lens that appears to be blocking the image from coming thru. Is this removable or is it suppose to be removed in order for it to operate.
2 Suggested Answers
SOURCE: I have not been able
If there is NO image this usually suggests that the image intensifier high voltage section isn't working correctly.
In actual fact there are NO DIY parts that can be "home" serviced in reality.
The very best thing you can do is return it to the manufacturers for repair, they are really the ONLY people who will have the necessary equipment to effect a reliable repair.
Posted on Mar 09, 2011
Can't find user manual for TASCO NV 360 Night vision Monocular.
It's really a pretty simple device, install batteries, turn on the switch, focus the eyepiece and you're there. If you need more, Tasco should be able to help via their website or customer service number.
Sep 30, 2013 | Radio Communications
The monocular wont focus but the lens look fine
Hello, the eye piece on the monocular will unscrew. Remove it then look throught the focus and see if you can see throught it. Also, check the output of the image intensifier tube. There will a 18mm white film plate witha clearn class cover. Now if there is any type of streaking on the inside of this image tube. The the image tube is on it way out. GB...stewbison
Sep 23, 2011 | Optics
The diopter setting eyepiece has come out of the body of my Bushnell 10X42 ''Waterproof'' binoculars, model 13-2410. I see keyways inside, but cannot screw it back in more than about 1/4 turn, which is...
The entire diopter setting eyepiece was off.I separated the eye cup from the rest of the diopter setting eyepiece, and aligned the channel guides on the lens piece to slide it into place. Then holding it in place, taking care not to gum up the lens, I experimented with how to screw in the retainer ring so that its white dot registered correctly. Finally reattach the eye cup and focus. It's like new!
Apr 10, 2010 | Bushnell Waterproof Binoculars
We have lost an eyepiece from our rrasco zip 323z binoculars. where can i buy a replacement?
For this model it probably wouldn't be economicaly viable to purchase the eyepiece. You would be better off buying a new pair with full warranty/guarantee.
Feb 17, 2010 | Tasco Optics
Lost Nikon Travelite ex eye piece
I'm supposing by eyepiece you mean the rubber or plastic eyecup. The eyepiece is the whole unit that contains the lens. Nikon has a service center in many countries. If you have one in your country then they can order the part. I have ordered from Nikon. They find the part number if you tell them your model and can email you an order form. Alternately Binoculars.com is very good to deal with as is Adorama Camera in New York. Both will sell internationally.
Jul 13, 2009 | Nikon Travelite V Binoculars
Need eyepieces for Nikon Monarch ATB 8x42 Binoculars
If its the caps that cover them Nikon in your country can order them. They take about six to eight weeks if they are not in stock. If its the actual eyepiece lens an all you would need to have purposfully removed them and in doing so destroyed the waterproofing. If its the caps contact Nikon. You can also download the instructions from their website.
Jul 08, 2009 | Nikon Monarch ATB 7344 Binocular
The eyepieces lens is foggy. can it be replaced
im sure it can be cleaned. before you send it for repair why not try a qtip to clean outside lenses.. breathe on lense and softly remove moisture with a qtip...both ends..gl...larry@reichinstruments.com
Jun 24, 2009 | Cstar Optics Spy-Scope (8x20) Monocular
I have a Swift model 802, 7X35 binocular. The
at the bottom hindge there is a nut you can remove . then take a long thin screwdriver and take off the screw that holds the eyepiece focus shaft. turn center wheel till eyepiece xbars come off body,carefull not to touch lenses. gl larry@reichinstruments.com
Jun 23, 2009 | Swift Audubon 804ED BWCF Binocular
Instructions
There are two conditions under which a blinking "H" will appear in the
LCD panel: (1) when the film has been loaded incorrectly or (2) when the
camera's self-test process detects an internal malfunction. If a
blinking "H" indication appears, perform the following operations in
attempt to resolve the situation:
1. Rewind and remove the film using the rewind button, then remove the
battery to clear the memory.
2. Clean the contacts at the base of the battery compartment with a
clean pencil eraser to ensure proper contact between the camera and
battery.
3. Replace the battery, power the camera back up1.gif and operate it as if
it had film loaded, pressing the shutter release.
Jan 11, 2008 | Canon Sure Shot 105 Zoom Date 35mm Point...
12x36 only one eyepiece focus
Assuming you have already tried replacing the battery, contact Canon Service Dept.
Nov 18, 2007 | Canon (12x36) IS II Binocular
Night Owl Optics Cyclops Compact NOCC3 Monocular Logo
151 people viewed this question
Top Night Owl Optics Optics Experts
wadingriver
wadingriver
Ted Maxwell
Are you a Night Owl Optics Optic Expert? Answer questions, earn points and help others
