Question about Philips Magnavox MS3252S 32" TV
Problem with 20" philips magnavox
My regulator,horizontal output transistor and r432 were all burnt out. after replacing these components, the tv powers up but there is no picture. there is a neon lamp close to the flyback which glows brightly. i guess it is indicating a fault in this circuit. what do you think is wrong...is it my flyback transformer?
  • Philips Master
  • 5,138 Answers
Check capacitor next to flyback 100uf 160 v its right behind it! If this is bad you will have no high voltage only other cause flyback!
Posted on Jan 21, 2008
  • ladywinn
    ladywinn Jan 22, 2008
    I had fogotten about F401 is a pico fuse 5amp ck it also capacitor is a 100uf 250volts
15MF/20MF/TV MAGNAVOX TV
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Jul 13, 2016 | Magnavox Televison & Video
I loss the horisontal regulator of my philips tv with 25pt463a/7ir model
Hello
You are talking about the horizontal output transistor damage I assumes and post this solution. If LOT has internal winding short, the horizontal output transistor will get shorted. It will be best to replace the horizontal output transistor, alongwith the LOT
Mar 03, 2012 | Televison & Video
Power light goes on (green ) for about 3 seconds then shuts off
the tv have a fault in the power supply circuit or horizontal circuit check the regulator transistor or ic in your power supply and other components there.check the horizontal output transistor in the horizontal circuit and other components around replace what ever component you find faulty and components associated with the faulty component.good luck.
Sep 25, 2011 | LG 42LC2D 42 in. LCD HDTV
My Sony Trinitron stand by/timer light is on and will let me put tv on but only stays on for a few seconds . Model #KV27S66 Oct 99
Your TV has an overload due to some faulty components inside it. This type of fault is usually noted with overheating of horizontal output transistor connected to LOT of the TV. This may be due to LOT fault, or fault to the transistor itself. When it overheats, it put a short between supply rail, and the power supply regulator system inside your TV will detect that short and will shut down automaticaly. Please note; if the TV works after some time, say after 15 or 20 minutes; and again shuts down after working for a short period, and the cycle repeats, surely there is a winding short inside LOT, which cannot be detected by normal multimeter measurments. If it is so, replace LOT and the horizontal output transistor at the same time.
Oct 14, 2010 | Sony Televison & Video
GET SOUND BUT NO CLEAR PICTURE ONLY HORIZONTAL LINES form bottom to middle black blur lines
Video output section of your tv is in trouble. Either it not gets proper voltage [low voltage if voltage is there]; or video output Ic or transistors whichever used may got damaged. Never switch on the tv in this condition; that picture tube may get damaged. Get it repaired soon.
Oct 14, 2010 | Philips Magnavox 20MT133S 20" TV
Tv went off with strange noise and we smelled something burning, but no flame. TV will not turn on. No light, nothing. IS TV fixable or should we replace? It is a magnavox tv that is at least twelve years...
Hi
as you said.. you have defective horizontal output transistor! and or the power section, please check the power regulator first. this is repairable..
Thanks!
Jun 11, 2009 | Philips Magnavox 27MS343S 27" TV
No sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
May 24, 2009 | Philips Magnavox 27MS343S 27" TV
Philips/magnavox 20 in tv
check the horizontal output transistor or the vertical IC,maybe one of them is defected .
Oct 30, 2008 | Philips Magnavox 27MS343S 27" TV
Screen oversize picture
Hello sidley,
The problem you described might be "blooming" This happens due to poor HV (High Voltage) regulation. The problem might be with the High Voltage Transformer and or the Horizontal Output Transistor.
The problem might also be related to the associated circuitry of the two components.
I hope this helps
Thank you,
Shuttle83
Jan 27, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox MS3252S 32" TV Logo
76 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
