Question about Gigabyte Computers & Internet
Continous beep on cold boot black screen
Replaced video checked mouse and keyboard still black screen
  • Gigabyte Master
  • 27,725 Answers
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM and Cmos battery are securely seated
Test all leads that attach to your hard drive including electrical extensions IDE SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
graphics card is seated properly with no dust in the socket you might have to remove it to check for dust
a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty
a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly click start right click on my computer so any faulty leads will end up with a computer error
hope this helps you
Posted on Feb 18, 2012
  • 101 Answers
SOURCE: NO video @ bootup
Are you sure that the memory you have installed is compatible with your motherboard.
It is weired but some memory do not work with certain motherboards, irespective of speed or voltage rating.
Posted on Aug 05, 2008
elksfc
  • 10 Answers
SOURCE: Will not boot with Keyboard and mouse plugged in
Did you try removing each memory module individually... Instead of just moving them around.. because the error you are receiving is a bad memory error code.
Posted on Jan 30, 2009
hmerchant110
  • 7191 Answers
SOURCE: ASUS P5S8000-VM/S no bios screen no beeps
From the description of the problem, it seems that either the power switch of your PC or the power supply cable is faulty. Also, please let us know if the motherboard LED is glowing or not. Do reply for more assistance.
Thanks.
Posted on Jul 21, 2009
ansoopani
  • 93 Answers
SOURCE: Intel D945GTP MB.Screen blank.Tried all the steps,
hmmmmm..check ur cpu instead of all the thinngs
Posted on Mar 01, 2010
shafykp750
  • 1070 Answers
SOURCE: There is no video, just a series of long beeps.
HIiiiii
Check Following
  • RAM / Re insert /Change Slot /CHANGE RAM
  • Any new Hardware Installed
  • Reset BIOS
  • Change the Cables
  • Remove the CD ROM CABLE/Cables
  • REMOVE FLOPPY or CD or any other Cables as New Hardware than HARD DISK Connection
Then try to boot
Problem Checked....... Solved.........!!!!
I am here
Posted on Mar 28, 2010
IBM ThinkCentre M51 does no boots
different pc has different bios beeps depends on the bios manufacturer, but in your situation it is most likely you have problem with your video device. is it connected in video card or directly plug in the built in video port of the pc? if its connected in video card, remove video card temporarily then connect it to built in video ports, or vice versa, if your in built in video port you can try testing it with video card in pcie slot.
Feb 28, 2014 | IBM ThinkCentre M51 PC Desktop
KEYBOARD NOT FUNCTIONING AND CONTINOUSLY BEEPING SOUNDS ON IBM THINKPAD R51 LAPTOP
Could be the keyboard has shorted out, maybe something was spilled on it? You can either get a cheap replacement keyboard from ebay (be sure to match the make/model & size) or you can just plug a usb keyboard in & use that. Once into windows go to device manager (right click My Computer on Desktop & click Properties, Hardware) & disable the IBM onboard keyboard.
Feb 22, 2013 | IBM ThinkPad R51 1830 (1830AHU) PC...
On start up fan runs, no beeps, black screen, no response from keyboard & mouse. Unplugged everything for 30 minutes, then tried again, start up began then went to black screen, no keyboard, no m
in your case, there might be some problem with the main board.
usually no beeps will related to the processor error / mainboard error / ram error / PSU error
to check the processor : try to exchange the processor with the same type.
to check the Memory: try use rubber eraser to clean the cooper plate of the memory. then plugged it again.
in case if there is a power supply error, then try to exchange the power supply using other PC PSU.
if all steps above are checked, the problem might be at the mainboard. in that case, replacement will be the best option.
Jan 20, 2012 | Acer Computers & Internet
My Dell Inspiron does not boot up only the solid amber light on the Motherboard on I try everything and still nothing works please help
Not so sure about this but I hope this will help.
-try to disconnect all the cables from the back (monitor, keyboard, mouse, usb's, power cable, etc.)
-then disconnect all the card (video card, sound card, NIC) if all are integrated then you dont have to.
-connect just the power cable
-try to turn on the computer and check if it beeps
-if it does not beeps need to replace the motherboard but before you do this check if the fan will spin even for a single second if does not spin then you also need to replace the power supply as well
-if it beeps then turn it off again.
-connect the video card and connect the cable of the monitor, keyboard and mouse
-turn on the computer then check if theres any display
-if theres no display check for any beep indication. and right it down on a piece of paper on how many times it beeps and if its long beep or short beep.
kindly provide an email if this things does not work so that I can give you a resolution.
Apr 01, 2011 | Dell Inspiron 530 Desktop Computer
When I go to boot the pc, it just beeps very loudly. Never boots.
thats normally means your video card has a fault, especially if nothing comes up on your screen and you just hear beeps
Jun 24, 2009 | HP Compaq Presario SR2011WM PC Desktop
PC will not start
This sounds like a memory error, can you define the beeps. There is a thing called a "beep code" on all motherboards, the website for the motherboard defines what the beeps mean. For example: one long beep followed by two short beeps of continous spaced beeps without a break. chris http://www.motherboardsrus.net
Jun 06, 2009 | Dell Precision Workstation 670 PC Desktop
NO video @ bootup
Aug 05, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
BEEPS
just reseat the memory modules it will fix the issue
Jun 07, 2008 | EliteGroup P4VMM2 Motherboard
Open Questions:
Computers & Internet Logo
53 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
