How to replace a dome light switch. Is there ome in each door jam
Yes, you have one in each door frame;
Fig. Headlamps (1999) - ZOOM LINK
Check links...
Fig. Courtesy Lamps, Page 01 (1999)
Fig. Courtesy Lamps, Page 02 (1999, Coupe, Convertible/Hard Top)
Fig. Courtesy Lamps, Page 03 (1999, Convertible/Soft Top)
Fig. Courtesy Lamps, Page 04 (1999)
Hope this helps; also keep in mind that your feedback
is important and
I`ll appreciate your time and consideration if you leave some
testimonial comment about this answer.
Thank you for using FixYa, have a nice day
SOURCE: 1999 Mercury Sable Dome Light won't shut off
Check the dash light dimmer switch. Perhaps it's set to have the interior lights on, when you turn the dash lights all the way bright, turning it a little more turns the interior lights on. Let us know how you make out.
SOURCE: 1998 sunfire, dome light stays on after both doors are closed.
check that the buttons on the doors are not stuck or broken.. you also have a dome override (should be near your light switch) or the roller that dimes the interior lights
SOURCE: 1999 silverado driver door dome light & radio shutoff not working
this is what it looks like it will be mounted on the door jam not on the door just look for it you will find it . it works bye when you open the door it grounds the dome light ground wire to the body. i have fixed thees before it isnt too hard. if the pic does not come up i will put the link under it
Door Jamb Switch Operation:
An electrical device that controls the on-and-off setting of a sub-system or system.
http://www.autozone.com/autozone/repairinfo/common/repairInfoMain.jsp?leftNavPage=productsHowTo&partCode=0900c152802145ae&title=Door+Jamb+Switch&targetPage=productInformation
Next to the headlight switch is a dimmer dial for the interior dash lights... if you turn it all the way up, the interior lights remain on... there is a "detent" on the dimmer. turn the interior dash lights all the way full on ...you'll feel the detent, then turn it down back past the detent a little bit...that should cancel the interior courtesy lights... wait a bit because the interior lights are sometimes on delay timers....
good luck let me know what happens.
SOURCE: 1999 Chev Silverado Door Light Switch
the actuator for the dome light is actually located inside the lock mechanism. Have you checked to make sure the dome light override button is in the out position?
