Question about BenQ FP731 - 17" LCD Monitor
Computer monitor problem
Dear sir, I have a omni tech pc, with windows xp installed on it. I brought a used monitor from someone, and observed that it sometimes makes terrible click sounds in its electron gun right in the tail glass tube. It occurs rarely, not all the time the monitor is made in san diego u.s.a. and is of sony company. On the right side below screen there is a logo EPA pollution preventer. model:CPD-17SF2, manufactured in april-1996, few days ago, I opened the case and cleaned the dust etc. the cable attached to pc, has two pins depressed. therefore it is providing full colours kindly respond on my e.mail:munsif_44@yahoo.co.uk munsif ali, ph:09203313524436 hyderabad, pakistan
  • BenQ Master
  • 3,828 Answers
Not one fixya people can help with much
if pins break when straightening
need a new part with good pins required as replacement
Posted on Mar 22, 2017
El Duderino
  • 47 Answers
SOURCE: Monitor goes blank automatically after about 40 minutes...
Hi Randygui, Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Posted on Nov 26, 2006
sandrew
  • 2961 Answers
SOURCE: artifacts on flatscreen monitor
The two cheapest things to do are, firstly, try your monitor on another persons pc, to see if any difference, and secondly try a different mouse as they can interfere with with graphics dpi.
Posted on Mar 23, 2007
  • 86 Answers
SOURCE: Benq FP91G+ monitor
The hourglass / egg-timer you're seeing has NOTHING to do with your new monitor. It is an indication that some program (possibly something NASTY) is running and using the CPU. While the CPU is tied up by the (possibly unknown) program, Windows displays the hourglass so you will know that the system is busy... First, update your antivirus program, then use it to scan your ENTIRE hard drive; this could take HOURS, so you might want to let the AV program work all night. If you don't have an AV program, you can do an online scan of your system in order to find the culprit; open Internet Explorer, then open this link: http://housecall.trendmicro.com Run the FREE online scan; again, this could take HOURS to finish, so you might want to let it run all night to see if the problem can be resolved... There are OTHER types of nasty software ("malware") which could have the same effect on your system, so if you can't find the source of the problem, open these links for more information: http://forums.majorgeeks.com/showthread.php?t=35407 http://forums.majorgeeks.com/showthread.php?t=44525 I realize that this probably isn't what you expected, but at least now you know what is most likely to be causing this problem, and the links I've posted can help you correct this problem... Lastly, this COULD be caused by a program you (or someone else with access to your system) has intentionally installed, but you didn't mention adding any software recently, and I think it is best to atacck this problem head-on. Best of luck; let us know what you learn...
Posted on Apr 01, 2007
  • 732 Answers
SOURCE: Monitor turns black after 3 seconds
teo6925, "Switch-mode-power-supply" is in partial shutdown mode. Can you see any electrolytic filter capacitors that have a slight "swelling" to their tops? They should be flat!! You may also need to inspect all the soldered component connections very closely for cold, thermally intermittant, "frosty" looking solder joint connections. May need large magnifying glass or 10x to 20x inspection microscope to locate these thermal/vibration "fractures" and then resolder them! If you have a capacitor problem, then you will need to carefully remove and replace with new ones. If you are novice at soldering I suggest that you document your work with digital camera or video tape so you can get everything back together with no "leftover" pieces! Teo, all you need to do to find out how BAD the problem of poorly manufactured capacitors is would be to search WEB for BAD CAPACITORS!!! Look for pic's of ELITE capacitors or CAPXON brand. You will be stunned beyond belief!!! Reading is free!! READ, READ, READ. Let us know what you find and do additional comment here on FIXYA. 12fixlouie
Posted on Jan 09, 2010
  • 60 Answers
SOURCE: Need to clean (more than dust) the screen of a Benq T903 monitor
They make alcohol swabs just for that purpose, Try Walmart. I've been using them for years and they have proved to be save.
Good Luck
Posted on Jul 11, 2010
Sir i have micromax q5 mobile when i install the pc suit then installdrv64.exe error found i. now the time i have use windows xp sp2..... plz give me how to use micromax q5 pc suite
The installdrv64.exe error indicates that the computer is installed with 32 bit Windows XP SP2 Operating System. Please unplug the Cellphone and re-install the PC Suite but do not install "installdrv64.exe" file as it is for 64 bit Windows XP Operating System. Now restart the computer and try connecting the Cellphone it should work now.
Mar 02, 2011 | Computers & Internet
RUNDLL Error Message, Windows XP
Dear sir,
Welcome to Fixya.
Rundll error is observed when computer is attacked by viruses and spyware.I think your computer is infected by virus and spyware.You can remove the viruses and spyware by using good Antivirus software,but if you want to get rid of all errors permenantely, solution is format your pc and reinstall your operating system then install good antivirus.
I think it helps
if you have any problem regarding this issue leave a comment or feedback we were happy to assist you.
Have a Nice Day!
Oct 02, 2009 | Dell Dimension E520 PC Desktop
Download windows xp trial
Borrow cd from someone. it will install 30 day trial.
Jun 22, 2009 | Microsoft Windows XP Professional for PC
Drive not instlled
When you bought you monitor there should be a drver CD for the monitor. If you have the CD, pu it in the CD_rom and then if you;re using Windows XP it will automatically open for drive installation. The PC will automatically detect a new hardware and will ask for the driver.The installation wizard will open and you just follow the instruction. Remember the drive is in the CD-rom. Choose CD-rom for drive location.
Nov 18, 2008 | LG Flatron L1750S 17" LCD Monitor
Can I install windows xp home edition to another computer
No.
OEM CDs are locked to the computer.
If you do install XP, it will ask for activation and you cannot activate it because an OEM licence is only for the computer it was sold with.
Aug 17, 2008 | Computers & Internet
How to install XP in toshiba Satellite L45-S7423 laptop
you have to use a standard windows start up disk with cd rom support like win 98 works well so the computer will recognize a older version then insert it and boot the computer with the operating system that u want to install but be advised if you have a warranty on the machine you will void the waranty i found out the hard way i had xp on my toshiba laptop and i put windows me on it couple of months later i had a cd rom issue and sent it to the manufacture and found out that the waranty was voided because i put a different operating system on the machine
Aug 14, 2008 | Computers & Internet
You cannot uninstall Windows Vista, but you can reinstall your previous operating system, which then replaces Windows Vista. To reinstall your old operating system, you must have the original installation disc. Back up your programs and files, insert the installation disc into your computer, and then reinstall the old operating system. To regain the hard disk space used by Windows Vista, reformat the disk during the reinstallation process. After reinstalling your previous operating system, reinstall your programs and files.
Feb 29, 2008 | Microsoft Windows XP Professional
Problem with the Windows XP Operating system
Who installed your windows?
If you still have yhe cd then pop it into the drive , restart you computer and it should automaticly install a fresh copy of XP.
If it does'nt then press F8 (varys on all computers look for boot control etc.)at start up and choose to boot from cd drive this will install windows> if it still does'nt work , just give a reply and ill give another solution.
Jan 19, 2008 | Microsoft Windows XP Professional for PC
Hellp me sir
Re-install XP over top of you old one. That may overwrite any bad data.
Nov 06, 2007 | Microsoft Windows XP Professional With...
BenQ FP731 - 17" LCD Monitor Logo
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
