Question about Maytag Neptune MDG5500AW Gas Dryer
Remove front panel of maytag gas dryer model MDG7400AWW
4 Suggested Answers
  • 4 Answers
SOURCE: remove front panel of maytag MDG7400Aww gas dryer
You have to remove the front panel first to access the clip that holds the front of the top down. Instructions:
crosstip medium screwdriver
1/4 inch socket
5/15 inch socket
  1. UNPLUG DRYER
  2. TURN OFF GAS
  3. Disassemble by taking apart the FRONT of the dryer:
    a. Remove the door and opposite side door plugs (crosstip screws)
    b. Remove the front panel - this exposes sheet metal bolts (5/16 inch) some with crosstip on left and right of unit. Set panel aside (right side) WITHOUT unplugging wires
    c. Unscrew all the exposed bolts.
    d. Top bolts left and right secure the unpainted metal hooks which secures the top of dryer. Unscrew these bolts and wiggle the metal retainer hooks off. Lift top and support to create 6 inch gap in the front (top unit hinges in back and has electrical connections - do NOT disconnect wires)
    e. Release belt from pulley by reaching left and under drum (this is out of sight)
    f. gently lift out drum and belt and set aside
  4. This has exposed the interior.
Posted on Nov 01, 2008
localwonder
  • 6784 Answers
SOURCE: dryer runs, but no heat , gas dryer and
Check the following components to combat this issue.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Jun 16, 2009
Jahn27
  • 1554 Answers
SOURCE: how to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
Posted on Apr 21, 2010
Maytag Centennial 7 Cu. Ft. Electric Dryer, how to remove front
unplug it,remove the top panel screws in the back,remove the control panel and then you can remove the front.go here
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MDG9700AWW/3048/0151200/M0702017/00001?
blt=06&prst=&shdMod=
you'll see number 14 and 15,you have to remove the 4 1/4 inch screws on the top and the two phillips screws that are behind the door.
Oct 13, 2013 | Maytag Neptune MDG9700A Gas Dryer
I am using a Maytag Atlantis MDG7400AWW gas dryer. It is not heating. I have replaced both solenoids that open/ close the gas valves. The heat coil glows orange, and the thermal fuse is showing 0.0 when...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 06, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Sometimes having heat and sometimes having cool air Maytag Atlantis dryer, Model # MDG7400AWW
heatman101
May 03, 2011 | Dryers
How to remove the front panel of a maytag neptune gas dryer
Apr 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Ihave a maytag atlantis gas dryer model mdg7400aww that when I first start it up it gets warm but then stops heating? what is the problem
The operator coils get hot and quit on these ,when they get a little age on them, quite difficult to diagnose. If the coil feels hot to the touch after failure then that is a clue. f00c98f.jpg
Mar 05, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Trying to get the top up on maytag model #mdg7400aww. Need to get some nails out that was left in pocket & dryed. can you help.
For the model washer you have listed, there should be a a couple of retaining clips inside the front seam where the top panel meets the washer front. If you push a putty knife in the seam about 2 inches in from each side, you will be able to depress the retaining clips to release the top panel. With the retaining clips released, the top panel will open up exposing the mounting screws that hold the washer front in place. Remove the mounting screws and the entire washer front can be removed, giving you full access the washer interior. If you have any questions let me know. I hope this helps you.
Nov 27, 2009 | Maytag Dryers
My Atlantis won't start after I ran it with the lint filter out
might be a sock or something in the blower housing jamming the motor
Sep 28, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag MDG7600AWW not staying hot
Hi, It sounds like that the coils on top of the gas valve are not opening the valve later in the cycle. They get weak enough ovwer heat and will not open the valve. You can listen for the ignitor to click on and then you can hear the gas ignite. If late in the cycle you hear the igniter click and then no gas ignition, change the coils.
You should also make sure the vent going to the outside is clear of any lint or kinked.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 13, 2009 | Maytag MDG7600AW Gas Dryer
Remove front panel of maytag MDG7400Aww gas dryer
1/4 inch socket
5/15 inch socket
  1. UNPLUG DRYER
  2. TURN OFF GAS
Aug 31, 2008 | Maytag Neptune MDG5500AW Gas Dryer
How to remove a back panel of maytag neptune dryer?
You have a choice for which side front door should be on this model. There are 4 screws on front door. Take all 4 screws and pull down the front panel. You will see two metal parts each side which holds top panel. Remove two screws and metal parts. Now you can push up the top panel.
Mar 17, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
57 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
