Question about Gateway dx Computers & Internet
Gateway IR emitter / reciever card cable ?
I purchased this card: http://support.gateway.com/s/PC/R/1009586/1009586rvr6.shtml but did not include cable to hook up to motherboard. card has 8 pin connector on it, trying to figure out how I would connect those to the motherboard (CIR transmitter on board preferably) the card is part of gateway models: GM5485E, GM5485H, GM5632E, GM5638E, GM5639E, GT4220m, GM5643E, GT4222m, GM5664, FX7020, GT3248m, GT4224m, FX7029E, DX440X, DX441X so was hoping owner of said machines could send me photos which show how card is connected in one of those machines (internal, color coded cables, etc..) so that I could build such a cable... or if you have/don't use IR functionality, could just send me the cable or point me in direction of where to purchase said cable or information. Thanks
    Habit-Forming:
  • 124 Answers
What are you trying to do?
Posted on Mar 19, 2017
IB4G2008
  • 3587 Answers
SOURCE: i just bought a new motherboard and managed to swap everything....except the power switch cable
whew..that's not as simple as it looks. You'll need a pin out configuration guide, if one exists, or you'll need to make one. The power interface from front panel, is usually unique to each Dell, so its' not likely to swap over.
got backup for that Dell?
Posted on Feb 17, 2008
bonerz
  • 22 Answers
SOURCE: TV tuner/IR cable
IR is infrared. back to the store maybe you have left something... or forgot to give on you
Posted on May 08, 2008
  • 166 Answers
SOURCE: Dell Optiplex GX620 PC is failing to power up
You may have a failed motherboard then. Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. Make sure you look at all of them, on DELL's especially look under the cooling fan shroud as well. The dead giveaway is the fact that you are not getting anything after you changed the PSU. There are a few companies that will repair broken capacitor issues. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations and that can cause internal parts to fail.
To eliminate some other stuff you could remove the memory and disconnect all the power plugs from the drives and then try to start it up. If it does not change the behavior at all (no beeps, no change in flashing lights) then you probably have motherboard issues. Make sure when disconnecting the memory chips (sticks) that you touch the metal on the inside of the case first to discharge static electricity. If it does change the behavior add 1 component or item back at a time to see what you can find out. Post back with what you find. And remember a bad PSU does not mean no power, just not enough to run the computer. Is the PSU that you replaced the same or greater output watts?
Posted on Apr 29, 2009
joecoolvette
  • 5660 Answers
SOURCE: I have a VPR Matrix
No, VPR Matrix doesn't show information.
http://www.vprmatrix.com/products_desktop_2250.asp
That's okay though. I would like you to take a flashlight, and view the motherboard closely. I need to know who made the motherboard, and what the model number is.
FIRST!
With all Due Respect, I would like you to STOP, (Not shouting), using a vacuum to clean the inside of your computer out.
The vacuum creates Static electricity. Static will FRY OUT the hardware components inside your computer. POOF! No computer!
You may have already done this repeatedly, and have had no problems. All it takes is once.
For a test. Put the wand attachment above your head. Bring it to about 1 inch above your hair, parallel to the floor, and the nozzle end beyond the front of your face.
Have someone turn the vacuum on. Your hair lifts up. This is caused by Static.
Thank you for letting me say that.
It is Much better to use a can of compressed air for computers. Yes, I know it costs more, but it's cheaper than buying another computer.
(About $6 to $8 USD)
BEFORE you reach inside your computer, unplug it from power. ALSO, touch the metal frame of the computer case. This will relieve Static from your body.
Now you are safe, and your computer is safe.
(Work on a table. A Bed, Couch, or directly on a carpet floor are High areas of Static)
You may have to move cables to the side, and accidentally touch components inside your PC.
Look in the center of the motherboard. Also look near the edges. One more common place is in-between the expansion slots.
Expansion slots examples are, PCI slot {White in color},
AGP slot, {Usually Brown}
Due to the hardware components listed above in the VPR Matrix link, I don't think you have a PCI-Express slot.
This gives more detail about the PCI expansion slot, and AGP slot, for identification,
http://en.wikipedia.org/wiki/Motherboard
Look at the photo on the upper right of the page. You can click on the photo to enlarge. The long white slots at the top of the motherboard, are PCI slots. The long Brown slot is an AGP slot. All are Expansion Slots.
On the motherboard you will notice ASUS. It is upside down in the photo, and in-between the brown AGP slot, and the third white PCI slot.
That is the motherboard manufacturer's name. Asus
To the left over by the blue ram memory slot is the Model Number.
It's on a white strip.
A8N-VM CSM Revision 1.10
If I have this information I may be able to find the Motherboard Manual.
I will give you the link to it, and also detail out where the Power On switch, (Button) wires go.
They will go to a Front Panel header on the motherboard. We just don't know where yet. (Connector on a motherboard is called a Header)
Don't worry, we'll find out where those wires go.
Posted on Nov 29, 2009
joecoolvette
  • 5660 Answers
SOURCE: My motherboard takes this: 1 x 8-pin ATX 12V power
Better than Amazon.com Andrew,
http://www.directron.com/ad202.html
Converts two 4-pin standard Peripheral power cables, (Molex) to one female 8-pin EPS +12 Volt power cable.
4-pin Peripheral +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
[ NOTE*
Designated a 4-pin Standard Peripheral power cable, because there is a 4-pin Small peripheral power cable ]
A) 8-pin EPS +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
B) Note the difference from an 8-pin PCI Express power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8
{4-pin Small peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
Used on the older Floppy Drives, and also used on today's Card Readers in desktop computers }
Posted on Apr 16, 2011
Testimonial: "awesome"
Emachine t3616 reset cmos
The eMachines T3616 Desktop PC, is supposed to use the
Winfast MCP61PM2MA motherboard.
If this holds to be true, so does the Gateway GT5476E Desktop PC,
http://support.gateway.com/s/PC/R/1009603/1009603nv.shtml
Click on Components,
http://support.gateway.com/s/PC/R/1009603/1009603cl5.shtml
Scroll down to the - Motherboards - heading
Click on -
4006200R - MCP61PM2MA AM2 uATX Motherboard - in blue.
http://support.gateway.com/s/MOTHERBD/Shared/4006200R/4006200Rnv.shtml
In the list click on - Product Views
http://support.gateway.com/s/MOTHERBD/Shared/4006200R/4006200Rtc.shtml
In the list click on -> P - Clear CMOS jumper
http://support.gateway.com/s/MOTHERBD/Shared/4006200R/4006200Rmvr18.shtml
Took you the 'long way', so you can see all the other connections on the motherboard, too.
Wires come unplugged in the future, you have info now to hook them back up.
Regards,
joecoolvette
(DO NOT forget to FOLLOW Anti-Static Procedures!)
Mar 25, 2013 | eMachines T3616 Desktop PC
My sansung pn50a460s4dxza says it is 3d ready. how can i use this feature on my tv.
Your tv is a 2008 model, legacy 3d tv and requires a lot more than a current 3d HDTV does to view 3d. Today with a current 3d HDTV, Normally you only need a 3d source like a 3d Bluray movie and 3d glasses from Samsung and a HDMI cable connection from bluray player to HDTV. See below for your TV. You need a PC and IR emitter and Samsung 3d glasses plus user selected options on the tv.
Samsung 3-D Ready HDTV How do Samsung 3-D Ready HDTVs work?
Samsung 3-D Ready HDTVs are enabled by Digital Light Processing (DLP(R)) or Plasma Display Panel (PDP) engines that are capable of very fast refresh rates (120Hz). The inherent speed of these display technologies enables high quality stereoscopic 3-D by alternatively displaying left and right eye images. The display is synchronised with 3-D shutter glasses to provide the observer with a vivid perception of depth.
How do I connect my PC to a Samsung 3-D Ready HDTV?
The DVI output from the PC's graphics card must be connected to the TV's 3-D compatible HDMI port using a DVI-to-HDMI cable (or a HDMI cable plus a DVI to HDMI adaptor).
Alternatively, some newer graphics cards have a HDMI port instead of a DVI port. In this case, simply use a HDMI cable to connect the PC directly to the TV.
On all models, the 3-D compatible HDMI port is identified by the letters "DVI". (eg, "HDMI 3/DVI IN" or "HDMI 1/DVI IN")
What other equipment do I need to enjoy 3-D on my 3-D Ready HDTV?
  • Windows PC with DVI output
  • Compatible 3-D Shutter glasses and IR emitter with VESA compatible sync connector
How do I connect the IR emitter to the 3-D TV to support wireless 3-D shutter glasses?
The IR emitter should be connected to the "3D SYNC OUT" socket. The emitter should be placed on top of the TV with the LEDs facing towards the room. How do I turn the TV into 3-D mode?
Ensure that the TV source is set to "HDMI 3/DVI" (or "HDMI 1/DVI" for 720p models).
Plasma HDTVs Press the Tools button and select 3D Effect. Update from Off to Mode1.
May 04, 2011 | Samsung PN50C430 50Inch 720p Plasma HDTV...
Where does the power switch cable attach to the mother board. a diagram would be nice
Here is a link to the front panel connection.
http://support.gateway.com/s/MOTHERBD/MSI/4006273R/4006273Rmvr21.shtml
Here is the entire motherboard broken down into individual sections.
http://support.gateway.com/s/MOTHERBD/MSI/4006273R/4006273Rtc.shtml
Finally, here is a link to the main support page for your computer. Save it...you may need it again in the future.
http://support.gateway.com/s/PC/DX/2906093R/2906093Rnv.shtml
Thanks for using Fixya.
Feb 12, 2011 | Gateway DX4640-UBC01A PC Desktop
I am looking for the Ethernet Controller for a gateway model no. 310 windows xp os
Here is a link to the page. when you get there, click on external mirror to download it.
http://drivers.softpedia.com/progDownload/Gateway-310-S-Network-Driver-70360-Download-61706.html
Nov 06, 2009 | Gateway 310S (2900621) PC Desktop
Do not have Manuel enclosed with computer.
http://support.gateway.com/emachines/emac/EL1200/EL1200ul.shtml
http://support.gateway.com/emachines/emac/EL1200/EL1200il.shtml
or any other downloads including drivers
http://support.gateway.com/emachines/emac/EL1200/EL1200nv.shtml
May 31, 2009 | Computers & Internet
Screen goes off showing VGA with cable on the screen
This looks like a bad cable connection. Try using a new cable for the connection between the computer and monitor. If that does not work test you computer on another monitor to make sure you are getting signal output from the video card.Also check the monitor on another computer.This is to check and make sure the monitor is working properly.You can also try using a add on video card in the computer to see if you can use the monitor this way.If you still are having problems. You can use this web address to get customer from Gateway. http://support.gateway.com/s/PC/R/1013953/1013953nv.shtml. I hope this helps you with your problem.
May 16, 2009 | Gateway GM5259E PC Desktop
No manual included
You should be able to find what you need at this website:
http://support.gateway.com/s/Mobile/2008/MSeries/M-7315u/M-7315unv.shtml
Apr 26, 2009 | Computers & Internet
I need to download my video driver and wireless card driver to go wireless on the internet
here is the site to do the driver http://support.gateway.com/support/drivers/dlcenter.asp if thats not what your looking for here is another site http://support.gateway.com/support/drivers/search.asp?st=pn&param=3501734
Nov 12, 2008 | Gateway Computers & Internet
Gateway solo 5300
Look at these sites:
This is a good "how to" with pictures (although it doesn't show your particular model):
http://www.laptoprepair101.com/laptop/category/lcd-screen-repair/
This shows how to remove the keyboard for your model:
http://support.gateway.com/s/Mobile/Solo_Series/p5350/8508369/8508369.htm
http://support.gateway.com/s/Mobile/Solo_Series/P5300/P5300nv.shtml
http://support.gateway.com/s/Mobile/manuals/8508399/8508399.htm
Manual for your model:
http://www.supportspot.net/gateway5300.pdf
Oct 21, 2008 | Gateway Solo 5300 Notebook
Computers & Internet Logo
54 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
