Question about KitchenAid Architect KBFA25ERSS Stainless Steel French Door Refrigerator
How to fit my thermostat to my refridgerator
My fridge is warm and i believe thermostat is the problem .. how do i fit this to my fridge The brand name of the fridge is Admirial double door ..
Brian
NOT PARTICULARLY T/TAT CHECK DEFROST TIMER
Posted on Oct 25, 2008
Refrigerator freezer cools fridge section warm
Yes there should be a defrost thermostat on your refrigerator what is the model number so I know what we're talking about do you see formation of frost on the rear wall of the freezer? Appliance 911 Sea Breeze
I'm here to help you out if you will answer my questions
Sep 08, 2016 | Danby Refrigerators
Waht makes a Dometic 1402 work normal on electric but the refridgerator warms up when on gas? Freezer warms up slightly but refridgerator 10 to 15 degrees?
Dometic had several recalls for that problem, faulty thermostat I believe. Mine does the same thing, but I haven't taken it out to replace the thermostat / thermocoupler.
Aug 20, 2014 | Dometic Refrigerators
Bottom freezer works but fridge section stays warm
Could you look for the model number that Sears uses on there brands the sell. Sounds like you have air restriction for one reason but Kenmore always uses a number like this 323.125489 as a model number.The first three numbers who really made the refrigerator and the other well I believe more confusion. See if you can locate those number and I will try to save you a service call, Sea Breeze
Mar 20, 2010 | Kenmore Refrigerators
The refridgerator is not staying cold. The
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Mar 06, 2010 | Refrigerators
Side by side refridgerator part too warm
Make sure the small door between the freezer and fridge is open. It should be at the top towards the rear on the wall between the fridge and freezer. Thermostat controls its open/closing. And make sure freezer is in fact freezing and you don't just have residual cold in it. Freezer should be about 0 dertees.
Feb 05, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refridgerator and Freezer
Compressor may be warm but not running. What part is brand new? Would you like me to assist you? If yes please make sure your model number is correct. I'm waiting for your reply, Sea Breeze
Nov 19, 2009 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
Refridgerator not cold
Called Sears to send a technician. Replaced the thermostat (DTS). Fridge is now working. The themostat was $21 + service/labor total $160 +/-.
Nov 30, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
KitchenAid Architect KBFA25ERSS Stainless Steel French Door Refrigerator Logo
290 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
