Question about LG WM-2277HW Front Load Washer
I have a lg wm2701h* washer. it will not drain the water. it reads OE. checked the user guide and trouble shooting says to check the front and back drain drain. drained both sides of the washer, ran a cycle and it still reads OE.
  • 1294 Answers
SOURCE: lg wm1814cw drain error
Click on LG (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
Posted on Nov 28, 2007
MNTECH
  • 1543 Answers
SOURCE: lg washer serial # 308kw00211
That OE is really DE (drain error). Open the access door at the lower left on the front of the washer. Drain remaining water using the small hose. (at least if it is not plugged) Unscrew and remove the large knob. Clean out filter. If filter was clean, you may need a new pump motor, or something may have made it past the filter and is jamming the pump impeller. You can remove the pump without taking the front off the machine. Do an "Ask Me" if you need to do that, and I'll give you further advise.
Posted on Oct 11, 2008
SOURCE: lg wm2277hw
Followed suggestions for LE message and it solved my problem with the OE message - cleaned the drain filter located on the front of the machine near the floor.
Posted on Sep 03, 2007
SOURCE: I have a LG TROMM 4.0 WM2277HW
Unplug the machine and check if filter, pump and water outlet pipe are clogged.
Posted on Apr 17, 2008
MNTECH
  • 1543 Answers
SOURCE: lg wm2277hw
You do not have an "OE" error, you have a "DE" error. DE error is "drain error" which displays if the washer has not pumped out after 10 minutes. If there is water in the machine and no obstruction in the filter I would suspect that the pump impeller is bad, and you would need a new pump motor. (part # 4681EA2001D) Pump motor is located directly to the left of the filter, and can be accessed by tilting the washer back and reaching it from underneath. The pump housing is held onto the machine by three phillips head screws.
If you have "DE" error and there is no water in the machine that's a whole different problem I'll address if you say that's the case.
If you need good service, try calling a small dealer who sells and services the procuct line you are having a problem with. You can find LG servicers at us.lgservice.com but avoid the utility companies, A & E, Sears, and all the big guys who try to service every brand but often times are not very familiar with your brand.
That should help. Carl S., factory authorized LG technician for over 10 years.
Posted on Aug 26, 2008
LG front loading washing machine Direct Drive 7 3.5KG Trouble shooting Error OE
go to lg.com, enter your model number and manual will show error codes and fixed for some including OE
Aug 29, 2015 | LG Washing Machines
Door will not unlock and water will not drain also get an err.code oE
Hello & Welcome to FixYa
Correct, OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter located inside the bottom front panel for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Aug 10, 2011 | LG WM-2277HW Front Load Washer
What does oe mean
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Machine gets stuck in rinse cycle - sometimes gets OE code sometimes not.
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter located inside the front bottom for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Apr 16, 2011 | LG WM2455 Front Load Washer
My washer has stopped it still has water and soap in it OE is flashing on the screen
Kevin
Apr 05, 2011 | LG WM2277H Front Load Washer
It won't drain...keeps stopping and says OE
Kevin
Dec 11, 2010 | LG WM-2277HW Front Load Washer
My LG Front Load washer starts to wash, then when it tries to drain, it stops and shows error code OE. I checked back drain hose and they are not kinked. I removed front filter in bottome left and water...
Hi dear.OE code meaning on Lg washer's"machine unable to drain in 10minutes". You can make a little test.Please remove the filter & pour some water in side drum ,watch for water coming out of filter.If it's slow, tub to pump hose clogged.(there must be some sort of fluff or coin clogging hose)if it's not slow,waters comes out freely, run machine on drain cycle & check the pump motor is it running smoothly?If not change the pump.I hope that helps.Thanks.
Aug 23, 2010 | LG WM2487H Front Load Washer
Starts to run and when i come back it reads "OE"
just check in your user manual. there will be a trouble shootin section. just check over there what the code oe means and repost it again.
Sep 07, 2009 | LG WM-2277HW Front Load Washer
The OE Message on my LG Tromm WM1814CW
Open the little trap door on bottom front of unit. Unscrew lint filter trap. Drain water first with small tube.
Sep 08, 2017 | LG WM1814CW Front Load Washer
Error Message/OE
sounds like too much water is coming into machine.check water valve,and water sensor.it is bringing in too much water or not enough.
Mar 06, 2009 | LG WM1814CW Front Load Washer
LG WM-2277HW Front Load Washer Logo
322 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
