Question about Fisher and Paykel Washing Machines
Code 43 I need service - Fisher and Paykel Washing Machines
  • Fisher and P... Expert
  • 554 Answers
43. (00101011) Phase 1 to 6 - OOB Switch Fault
The Motor Controller module has found that the signal returning from the out of
balance switch indicates that the switch is permanently on or the harness to it is
disconnected.
Primary Source: Mechanical.
Action:
1) Check that the out of balance switch is free to move.
2) Check that no harnesses are blocking switch movement.
3) Check that the switch operates correctly when activated. Replace the switch
if suspect.
4) If the out of balance micro switch shows signs of corrosion, replace the
switch and switch harness, and fit a condensation kit to the console area if
not incorporated in the top deck.
5) Check the level of the machine and also the bias spring.
Secondary Source: Wiring.
Action:
Check the harness to the switch is connected correctly. The terminals should be
connected to the normally closed position. If the harness terminals show signs of
corrosion, then fit a new harness.
Tertiary Source: Motor Controller module
Posted on Dec 26, 2013
Service air bag code 43 2009 pontiac g6
43 is not a code. you left some digits out.
Jan 05, 2017 | Pontiac Cars & Trucks
Error code 43 2005 r1
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
05 R1 Error Code 43
R1 diagnostic modes and codes
2004 2005 Yamaha YZF R1 Service Manual R1 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Dec 06, 2013 | 2006 Yamaha YZF-R1
My F&P washing machine is displaying code 43
Fault Code 43 is out of balance switch.
The out of balance micro switch under the brown motor controller board is corroded and needs replacing.
Aug 02, 2012 | Fisher and Paykel Washing Machines
F&P intuitive washing machine says code 43
I need to know what the code for a 1993 honda accord it flashed 4 slow then three short fast flashes, my car has been lagging really bad and i dont know exactly what i need to do to fix it i was told it is...
Found this for you on the web. Good luck.
c/p;
What is code 43?
Code 43 is "fuel supply system."
This code will trip when the ECU and the readings from the o2 sensor don't get along(in layman's term or easy enough for Si Speed to understand biggrin.gif) read the above two threads).
How to diagnose and fix?
First things first, when was the last time you changed your O2 sensor? Start by replacing that first because most likely, that's the main culprit. Now, you may wonder why doesn't the CEL indicate code 41(heated o2 sensor)? Usually when the o2 sensor is completely dead, that code will trip. Also, even though the o2 sensor is working, the voltage or ground isn't 100% Because of that, it will correlate with code 43.
If replacing the o2 sensor did not help code 43 to disappear, next thing is to replace your fuel filter. A clogged fuel filter will also trip code 43.
Next up, did you install an aftermarket Fuel Pressure Regulator? I have a few friends with 3rd gen Preludes and both of them installed aftermarket FPR's and they too, trip code 43. Him and a lot of people who install aftermarket FPR's mess with the PSI and that will cause code 43 to appear(on a stock ECU mind you). Bring it back to stock PSI to help fight code 43.
Those are the 3 main culprits that will cause code 43 from my experiences. Injectors, spark plugs & wires, most likely anything "fuel' related that isn't working properly will also cause code 43.
May 03, 2011 | 1993 Honda Accord
Code 43
Should clearify by providing engine info. However, this will likely be what you need...
Code 43:
knock sensor or electronic spark control circuit fault
Jun 25, 2009 | 1994 Chevrolet C1500
1989 gmc c2500 service code ''43''
When you replaced the ESC did you disconnect the battery? If not then it is most likely that the vehicles ECM is still running in loop mode because it doesn't realize it has been changed. Clearing the codes, disconnecting the battery should do the trick.
Nov 11, 2008 | 1989 GMC Sierra
Fisher and paykel intuitive washer what is a code 43 please
HI, Go to this site is has all fault codes all you do is find your product click it and it will show you the fault codes and what they mean and suggest how to fix it. http://www.repairclinic.com/0078.asp
Jun 09, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
53 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
