Question about Comfort Products Heating & Cooling
Refrigerant type for Model #PH5530AKA6
Temp Star
Carrier ac E4 error
If this is a ductless mini split e4 appears to be an air temp sensor on the indoor or outdoor unit that is sensing an abnormal reading. Check air filter and both I.d & o.d coil cleanliness. Its hard to troubleshoot without a model number. If its a 38g or 40g in the model number its a discharge temp sensor reading high temp situation (dirty o.d. coil, low freon, refrigerant restriction. Again, need a model #
May 29, 2015 | Carrier Heating & Cooling
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    What is the ac gas pressure for mercedez 200c
    Gas pressure for ac can be determined by the type of refrigerant not the model of the car. The outdoor temp will also be a major factor. 134a low side while its running could be around 35 psi to 45. While filling track temp of air supplying your vents and you shoul get a 15-20 degree differential form outdoor.
    Aug 22, 2012 | 2007 Mercedes-Benz C-Class
    What the psig reading on a reach in cooler on lo and hi side
    Hi, That depends on what refrigerant is used... there are about 10 different ones and they will all have different pressures...
    Here is a tip that I wrote about how to add refrigerant to a air conditioner orcooling system
    How to add Freon to a Air Conditioner or Refrigeration System
    heatman101
    Sep 06, 2011 | Refrigerators
    The unit constantly freezes up. Suction is at 85, liquid is at 285, suction line temp is 52. Ambient 85, while inside is at 85-88. Only 1-2 degrees of superheat. Taking refrigerant out lowers line temp...
    Has anyone added refrigerant? If there was a blockage I would think the suction pressure would be lower. Are you sure it isn't just overcharged. If you take the ambient and add 20F that would give you a condensing temperature of 105 which gives you a pressure of about 210# on the high side and something to shoot for. I don't know if this helps you. Also, the numbers I listed are for R22. You didn't mention what type is in the unit.
    Aug 10, 2010 | Intertherm P3RA-030K Air Conditioner
    Ice up on air condition unit- temp Star Unit
    Icing up is caused by low pressure in the unit. This can be caused by two things:
    (1) Low air flow. (dirty filters, dirty coils, blower not working)
    or
    (2) Low refrigerant.
    Hope this helps.
    Jun 13, 2010 | Heating & Cooling
    Been researching this model, and haven't seen anything about what type of refrigerant it uses. Does it have a compressor and use refrigerant?
    Yes it does have a compressor - I believe this particular unit is a 10000 BTU unit w/compressor and uses R410A refrigerant which is btw a ozone friendly refrigerant.
    Apr 29, 2010 | Sharp CV10NH Air Conditioner
    Bought 2 several years ago. Neither one cools
    What type of refrigerant is running with these units? what Ambient temp do they work in? what is the temp of the Air off.
    Jun 09, 2009 | Maytag M6Q10F2A Air Conditioner
    Need ref charge in ozs suct press at temp for superba 42
    Refrigeration charge in grams will be found on the label with the model number and serial number. The type of refrigerant is also on this label and the type of refrigerant which is more than likely 134a. You can weight the gas in or you can charge to 10psi, then run unit and adjust up or down as required.
    Mar 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
    Heating & Cooling Logo
    60 people viewed this question
    Top Comfort Products Heating & Cooling Experts
    paulcarew
    Dan Webster
    Dan Webster
    Donni Steen
    Are you a Comfort Products Heating and Cooling Expert? Answer questions, earn points and help others
