Question about GE Spacemaker (74290) Clock Radio
GE spacemaker under cabinet radio has very poor reception on AM. Can I somehow add an external antenna?
  • WEN BROOK Apr 07, 2012
    if radio has a light for your counter turn on as well as radio. the radio will be static free
    after 30 min. must heat the part up inside the unit then the radio is static free. but you have to keep the light if you want the radio to work.
2 Suggested Answers
SOURCE: GE 7-5402 Spacemaker under counter radio - all static
fix
Posted on Feb 20, 2012
Question about GE Slim Spacemaker 7-5302a CD Shelf System: Where can I find the antenna?
Connected to the variable capacitor. It turns when you turn the tuning knob if one. Image impossible to make out for antenna.
Sep 04, 2017 | GE Audio Players & Recorders
Poor radio reception
check your antenna wire to see if it came unplugged from back of radio
May 18, 2013 | 2002 Ford Crown Victoria
FM radio reception is poor. User manual suggests connecting an external antenna. Where do I connect it?
Hi, I think your units model number is AJ6111. According to the owners manual, the FM antenna is integrated to AC Power Cord. So you can not add antenna. But you can try to re arrange the cord and perhaps add an extension cord to see if reception gets better.
If this is not the unit you have, please try to provide the model number so I can look up the right owners manual and try to help you.
Good luck.
Mar 21, 2011 | Philips Under-Cabinet Alarm Clock Radio...
I am having very poor FM reception with my Bose Radio wave system. Is there an external antenna that can be attached?
The power cord is the antenna and it should be stretched out straight for best possible reception. You could experiment with re-orienting the Bose, too.
There is a threaded 75-ohm coaxial FM External connector. You could probably get a compatible FM antenna at an electronics store.
See the manual, Page 10
Dec 25, 2010 | Bose Wave Radio
I have a 1970's Sony AM Receiver ICR-9. Reception is poor and sounds almost like it is receiving on another band. It has been a great radio and would like to retain. Bill
Do you use an indoor antenna ? Nowadays, with all gear around, like micro-waves receptors, strong motors, satellites, etc., reception becomes quite poor, unless you use an external antenna, properly set to catch broadcast stations. FM reception particularly has its signal much improved in that way. Correct demodulation requires a good an somewhat large outdoor antenna. Hope I could help. Good Luck.
Flavio/Brazil
Jul 13, 2010 | Sony Audio Players & Recorders
FM reception for Sony ICF-CD513?
The electrical cord acts as an antennae for this radio. Uncoiling the cord will give the best reception for FM. Rotating the radio (and built in ferrite bar antennae) will give the best reception for AM listening.
Jan 31, 2010 | Sony ICF-CD513 Clock Radio
How to add external antenna to a GE 75300 GE Slim Spacemaker
the antenna is internal (I couldnt find an external adapter) - u need to open the top (20 or so screws). Theres a "pipe" thru the back that leads pretty straight into the antennae. Hook ur metal to the closest bundle and out the pipe.
My reception still isn't perfect, but you can listen to it. I moved the ac power code to the far side and gain some improvement as well.
Dec 03, 2009 | GE Spacemaker 75300 Shelf System
could be or the station you have on.in between towers you will get static.
Jul 15, 2009 | 2007 Mini Cooper S Convertible
Ge spacemaker radio model 7-5402 problem
OK, I found out what the problem is.
ON my GE 7-5402 Spacemaker under-cabinet radio, the FM was only static. I've opened it up and there is a component which is failing. When I used a heat gun on the circuit for about 5-10 seconds, it started working and it stopped again when it cooled off. After some time I isolated which component it was that needed the heat in order to work. Here's where to find it:
  1. Remove the top (25 screws of various length)
  2. With the LCD facing you, look to the right of the CD-drive close to the large aluminum cooling fin.
  3. There is a single transistor with markings of: "D2012" and "6:R".
This transistor is the problem and I believe if it is replaced, the FM radio should work. I'm going to try it and see what happens. I think I found the right one online for less than $1.
Hope that helps you guys!
Feb 10, 2008 | Audio Players & Recorders
GE Spacemaker (74290) Clock Radio Logo
218 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jonathon summesfield
Carlos L. Burgos
Carlos L. Burgos
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
