Question about GE Spacemaker (74290) Clock Radio
I have a GE spacesaver under cabinet radio. AM radio reception is poor. Can I somehow add an antenna?
I'm even willing to take the radio partially apart if I can somehow add a wire inside to work like an antenna.
SOURCE: GE spacesaver 05GP009
I had this same problem, I wanted to use this tv with a converter box and the only way to do this was to hook up the converter box with an external antenna to the small 3.5mm input on the back. If you go to radio Shack and get an "F to 1/8" Adapter"the radio shack part number is "278-257". It worked perfectly. I'm able to get many clear channels, and with the converter box I now have remote control. It works well. Good luck, I hope this helps
Posted on Apr 21, 2009
  • 5 Answers
SOURCE: GE Spacesaver microwave table wont turn
It could be the plastic coupler part #942560. Remove your glass tray and lift up the plastic piece in the middle. It slides off of the motor. If it is broken that is your problem.
Posted on Oct 25, 2009
heatman101
  • 43501 Answers
SOURCE: heat won't work on ge spacesaver microwave oven --what to do from
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ioi
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: Model # JVM150001 GE Spacesaver Microwave stopped
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Posted on Jan 04, 2011
SOURCE: My GE spacesaver 7-5300 clock
my radio goes off at 12 am,cant determine why
Posted on Jan 10, 2011
Poor reception
There are many causes for poor reception on a cb radio one cause may be poor or poorly assembled antenna, a good antenna should be of highest gain and put up as high as possible ,An omnidirectional antenna or Ground plane will hear moderately well
in all directions but a directional antenna or Yagi will hear great only in the direction it is turned you will certainly have to decide what you or your homeowners association will allow.
Also and finally The sun is a major factor in communications Propagation sometimes no mater what your setup the reception is terrible.
Feb 24, 2014 | Uniden Bearcat Pro PC68XL 40-Channels Base...
96 Marquis LS Poor am radio reception
Do you have the BLUE power antenna wire hooked up?
If not it may help your issue
Jun 12, 2013 | Alpine Wire Harness Ida-x305 Ida-x303...
Poor radio reception
check your antenna wire to see if it came unplugged from back of radio
May 18, 2013 | 2002 Ford Crown Victoria
Poor radio reception and Setina push bar installation question
for the poor reception have you plugged in the antenna wire into the radio
Poor reception with Alpine cda 7892
I found the manual at Alpine.com.http://vault.alpine-usa.com/products/documents/OM_CDA-7892.PDF
Apr 15, 2012 | Alpine CDA-7892 CD Player
Poor radio reception.I've tried a new aerial mast,no improvement. CD player sounds fine. Any ideas? (Passat Est.2003)
Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 1 Subject: Model(s): Group: Number: Date: AM Radio, Poor Reception 1999, 2000 91 99--07 New Golf, New Jetta, Aug. 2, 1999 New Beetle, Passat Condition AM reception is poor. May be caused by: ? An incorrect antenna mast installed for the antenna base equipped with the vehicle ? Poor ground at the antenna base or radio ? Poor battery ground to chassis or engine ? Poor antenna cable connection at Radio ? Corrosion at the antenna coaxial connectors at radio or antenna Service Vehicles are equipped with either a Bosch or a Clarion antenna base mounted on the roof and (for shipping purposes) the appropriate matching mast is located in the luggage compartment. If radio antenna masts are removed from vehicles and stored until vehicles are sold, there is a chance that an incorrect mast can be installed at the time of delivery. Note: Mismatched antenna mast and base will cause poor AM radio reception. The antenna base and mast can be identified visually as follows: (Cont. on Page 2)91-A260 requires gloss finish antenna mast 57mm 49mm Bosch 91-A261 requires matte finish antenna mast 61mm 41mm Clarion 91-A262 Technical Bulletin Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 2 Bosch antenna ? Base (although oval) is more circular in shape (approx. 57mm x 49mm). ? Made in Germany stamped on underside of base. ? Two screws on underside of base are unpainted. ? Requires gloss finish antenna mast. Clarion antenna ? Base is more oval in shape than Bosch (approx. 61mm x 41mm). ? Two screws on underside of base are painted. ? Requires matte finish antenna mast. If antenna mast matches the antenna base correctly: -- Check antenna coaxial cable connections --arrows-- for corrosion and clean if necessary (DO NOT apply stabilant). Passat coaxial cable connection for radio is under the carpet on right side of tunnel near shifter. -- Ensure that coaxial cable is firmly seated in radio (Passat cable connection, see previous step). -- Check ground at the antenna below roof Nut --4-- (torque = 7+1 Nm) must firmly secure antenna to roof). (Cont. on Page 3)Technical Bulletin Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 3 -- Check ground for radio behind radio on cross member (On Passat models as of Nov. 1998 beginning VIN: XE285000 ground for radio is on right side of center tunnel). -- Check engine compartment ground, left side, below battery tray; frombattery GND to body. -- Check engine/transmission ground on transmission, near engine block. -- If all grounds and antenna mast are OK. -- Replace antenna and coaxial cable assembly
May 06, 2011 | Car Audio & Video
FM radio reception is poor. User manual suggests connecting an external antenna. Where do I connect it?
Hi, I think your units model number is AJ6111. According to the owners manual, the FM antenna is integrated to AC Power Cord. So you can not add antenna. But you can try to re arrange the cord and perhaps add an extension cord to see if reception gets better.
If this is not the unit you have, please try to provide the model number so I can look up the right owners manual and try to help you.
Good luck.
Mar 21, 2011 | Philips Under-Cabinet Alarm Clock Radio...
FM reception for Sony ICF-CD513?
The electrical cord acts as an antennae for this radio. Uncoiling the cord will give the best reception for FM. Rotating the radio (and built in ferrite bar antennae) will give the best reception for AM listening.
Jan 31, 2010 | Sony ICF-CD513 Clock Radio
could be or the station you have on.in between towers you will get static.
Jul 15, 2009 | 2007 Mini Cooper S Convertible
Radio reception
If antenna optimization didn't work you'll probably have to move.
Aug 08, 2007 | Bosch PB10-CD Radio/CD Boombox
GE Spacemaker (74290) Clock Radio Logo
94 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jonathon summesfield
Carlos L. Burgos
Carlos L. Burgos
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
