Question about Motorola Mobility P323 Battery Charger Spn5564
The light on the charger comes on then goes off because i wasted water on it
The red light on the side comes on when you plug it up the goes off and it wont charge my battery anymore
Sounds like you need to get a new charger. water is a killer of most electrical things. have you tried letting it dry out?
Posted on Feb 15, 2012
  • Yasmine hall Feb 17, 2012
    yeah like for a week or 2
Charger not working
When the red light is on it is to indicate that the charger is getting power from the wall outlet. If there is a second light that normally comes on Green when charging pay close attention to it when you first plug the charger in. See if it blinks even once then turns off. If it does that means the charger is not seeing any battery voltage at the plug that goes into the chair. If the green light does not blink at all then it usually means the charger is defective. Also most wheelchair battery chargers will not charge the batteries if the chair is to dead to even turn on.
Apr 12, 2015 | Health & Beauty
I need to know what the charger looks like. does it take batterys? where do they go? how do I charge the camara?
You can purchase a charger for this camera at http://www.amazon.com/Wall-Charger-Adapter-Vivitar-Vivicam/dp/B003M6BXBO/ref=pd_sim_e_1
Feb 28, 2011 | Vivitar ViviCam 8025 Digital Camera
MY BLACKBERRY BOLD 9000 WON'T TURN ON!!! My friend gave me her Blackberry Bold 9000. It's battery was replaced a few months ago but it hasn't been used since then. When I plug it into the wall charger,...
Ok...don't panic. The charger you are using is not compatible. Verizon only works with verizon blackberry's. Non verizon will not work with blackberry and vice versa. This is what will happen. you plug it in and it will boot for a few seconds and then the lightning bolt you see is the charge icon and then a red line in it means that charger is not compatable. Blackberry does make its own charger but there is a "pin" on the plug in that will tell it it is not the right one. Am I confusing you?
Jan 06, 2011 | RIM BlackBerry Bold 9000 Smartphone
My Hoveround MPV5 batteries will not charge, do you think it is a battery problem or a charger problem?
If you plug the charger into the wall, turn on the power switch and the light comes on, the charger should be working properly. Here is a way to test it-
Attach the charger that came with the power chair to the power chair controller firmly and turn the power chair on, while the charger is running. What should happen:the lights on the controller will scroll back and forth. If this does NOT happen and you can confirm the charger is turned on, the charger handle is fully seated inside the controller receptacle and the wall outlet has power, then the charger may have a problem and needs to be replaced.
If the charger is OK, then there may be a problem with the batteries. Here are some sypmtoms:
1-You connect the charger but the light on the charger never goes red, it just stays green.
2-You connect the charger but the light goes from red to green VERY fast.
3-The charger light goes from red to green but when you disconnect the charger and press the power button on the controller, you only have one flashing red light, or the batteries drain within just a few minutes of use.
4-The power chair has been stored or sitting idle for several months.
5- The power chair has been connected to the charger 24-7 for several months.
Any of the above examples indicates that the batteries are oxidized or damaged and will most likely need to be replaced. The MPV5 takes two, U1 12 volt 33 amp batteries which can be purchased at any battery warehouse store like Interstate Batteries or Batteries Plus.
Nov 30, 2010 | NRS Hoveround MPV 5 - Used Power...
I have brand new just fitted MK Gel batteries and a known working charger. When the charger is plugged in and charging a orange light should come on or green when fully charged. At the moment only the red...
David, If you are not getting the yellow light on the charger then you have a problem with the charger. What voltage are you getting at the batteries when charging? You can check the charger by removing the end plate where the lights are to see if there is a fuse on the output side of the charger. if there is check to see if the fuse is blown. There probably is a fuse on the other end but since the red light comes on it is good. If you plug the charger into the charger port and put your ear to it you should hear a hum coming from the charger. Hope this helps you
Sep 29, 2010 | Health & Beauty
They Won't Charge!
Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
Nov 17, 2009 | Motorola Mobility S9 Headphones
How do i connect a battery charger
I suppose this is what you want to know
The battery charger has 2 leads coming off it as well as the power lead to the external power source .THE TWO LEADS WITH CLAMPS ON GO TO THE BATTERY THE RED GOES TO THE POSITIVE TERMINAL PLUS SIGN AND THE BLACK GOES TO THE NEGATIVE TERMINAL.MINUS SIGN, THE POWER LEAD PLUGS INTO THE POWER. AND THAT IS ALL THERE IS TO IT..
Sep 10, 2009 | 2002 Mitsubishi Lancer
My Mambo- Mano MP4-MP3 does no charge
it does not seems to charge / or turn ON either from the computer or when plugged to an electrical outlet to the wall. Red light is still ON after the whole night . What's wrong ?? Can you please HELP - CODY STELLER MINE IS A 4 GIGA BITE MP4 PLEASE HELP ONLY
Sep 01, 2008 | Kaser Corporation Mambo Mano Digital Media...
De walt de9118 charger
when charger is plug in to ac it will blink once.normal voltage out for the unit in between 36v to 55 volt. the reading u have is normal.
Aug 07, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Wont turn on
Remove battery from charger. Unplug charger for a minute, then plug back into outlet. Reinsert battery and see if red LED comes on and STAYS on solid. If so, charge for about 5 hours.
Dec 28, 2007 | Olympus Stylus 790SW Digital Camera
Motorola Mobility P323 Battery Charger Spn5564 Logo
51 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
