Question about Kenmore 63942 Dryer
Diagram to remove front of Kenmore elite 110-60982990
jsrock516
  • 5911 Answers
SOURCE: window dryer
Okay...thank you for the feedback. This repair will be much easier if you remove the door from the dryer. Just loosen the screws on the hinge where it connects to the dryer door opening. That is...remove the door with the hinge still attached. CAUTION: Make sure you support the weight of the door as you loosen or tighten the door hinge. Lay the door face down on a soft surface like some towels. Locate the screws on the door interior. There are a series of them that go around the perimeter of the door. Removing these screws will enable you to disassemble the entire door. The interior door facing will come off, allowing access to all the remaining parts. Just make sure you remember how they come apart. If you get confused, you can go to searspartsdirect.com. Type in your model number and locate the "Door Parts" heading on the next page. There should be an illustration on how the door is assembled. I hope this helps you. If you need further assistance, please post back and let me know.
Posted on May 24, 2008
SOURCE: torn seaL ON KENMORE ELITE WASHER
i have a kenmore elite washer the red lite is lit on controlles locked how do i solve this
Posted on Mar 23, 2009
Maytag317
  • 1136 Answers
SOURCE: Broken door handle
Hi, there should be two screws holding the handle. I looked up my suppliers and this would need to be ordered. The cost is between 21 and 29 dollars, depending on color.
Part#8559750 Graphite color or P#8559751 Black
If I can assist you further, please let me know. I can order the part.
Thanks
Vic
Posted on May 15, 2009
SOURCE: just inherited a kenmore elite oasis dryer model 110 77092600
Go to Sears and buy it! You cheap B.
Posted on Jun 26, 2009
jsrock516
  • 5911 Answers
SOURCE: removing front panel from kenmore elite HE-3 front load washer?
If you've removed the screws and the panel sticks, tapping on each side will knock it loose. The panel should drop down, then off. You can also try propping the two front feet of the washer up slightly for better access. A 2x4 works real well. This will allow more room for the panel to drop and gives better access to the screws. The washer is very heavy, so you may need some assistance to lift the front. Either lift from the bottom, or place your hands on the front facing of the cabinet to push the washer back. DO NOT push on the door or control panel.
If you still need assistance, please let me know. I hope this helps you.
Posted on Jul 05, 2009
I have a kenmore elite he3 smart heat quiet pak4 how much is a motor for this dryer
  1. Kenmore Elite He3 Parts - searspartsdirect.com‎
    Adwww.searspartsdirect.com/Kenmore-Parts‎rating for searspartsdirect.com
    Shop Today at Sears PartsDirect™. The Largest Appliance Parts Seller.
    Ratings:Shipping 9/10 - Website 9/10 - Selection 9/10 - Quality 9/10
Search Results
    MOTOR diagram for model # 41794130000 Kenmore-elite ...
    www.searspartsdirect.com/model-part/41794130000/0583/.../00004.html
    MOTOR Diagram and Parts List for KENMORE ELITE Dryer-Parts model # ... MOTORdiagram for model # 41794130000 Kenmore-elite-Parts Dryer-Parts (18).
    PUMP AND MOTOR PARTS Diagram & Parts List for Model ...
    www.searspartsdirect.com/model-part/11047789702/0583/.../00006.html
    PUMP AND MOTOR PARTS Diagram and Parts List for KENMORE ELITE ... ANDMOTOR PARTS diagram for model # 11047789702 Kenmore-elite-Parts ...
Nov 01, 2015 | Kenmore Dryers
Where is the presure switch locate at on a Kenmore Elite HE5t. Is there a diagram of it?
Take off the lid of the washer. In the back right of the washer it has a small hose attached to it
Aug 24, 2012 | Kenmore Elite 45986 Front Load Washer
Need to replace rubber ring around front of opening. How do i take old one off?
If this is a Whirlpool series front loader, such as Kenmore Elite, Whirlpool Duet or Maytage Epic, the following link explains step-by-step how to remove/replace the door bellow (gray rubber seal):
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
A bellow (if required) can be purchased at any of the following web sites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices differ between sites so shop and compare. The first three sites on the list, have helpful exploded view diagrams to assist you with locating and identifying any parts you may need.
If you have questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Jun 16, 2010 | Kenmore Elite 45986 Front Load Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
Need access kenmore elite washer door latch wiring any ideas
remove the front retainer to boot and pull back on sw side / do not remove complety and you should be able to remove sw and get to wires . not a tuff job . mm
Dec 06, 2009 | Kenmore Elite 45986 Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Torn seaL ON KENMORE ELITE WASHER
Mar 22, 2009 | Kenmore Elite 45986 Front Load Washer
Dryer won't heat
check thermostats on fan duct housing. the white one is a thermal fuse, not the problem if unit runs. for frontloader matching models thermostats are up front. remove lower cover and use ohm meter. wiring diagram avail there as well. then check element.
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite dryer
can you spin the drum by hand? if not,pull front panel off by removing three screws on bottom, remove lint screen, then remove three screws holding inlet housing ( the big brown thing in front) check to make sure not clogged with sock, panty hose ,bra underwire ,etc.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 63942 Dryer Logo
87 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
