Question about Epson LQ Office Equipment & Supplies
To reset memory of epson lq 1150
Page length as set to 3.5" and autotear is on. how can i reset to factory settings?
dodgecharger
  • 254 Answers
SOURCE: epson lq 1150
If the printer is dead - no power- no LED lighting at all, and the power cord is OK, then look at the power supply section for a defect. A fuse could be blown, or some component failure. Note- if a fuse is blown, this is usually due a component failure, and the exact problem must be located.
If you have some technical skills, a VOM or digital voltmeter, you might be able to pinpoint the problem. A circuit diagram would be helpful also.
Posted on Nov 19, 2007
SOURCE: Epson Lq-1150 Custom Page setup is not geting in Print Setup in Windows XP
My Printer is EPSN LQ1150 , Its ribbon doesnot move what do i do?
Posted on May 22, 2008
SOURCE: EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Posted on Nov 24, 2008
  • 117 Answers
SOURCE: epson lq 1150 printer defult seeting
Alright, do the right click on printer icon and select the option "properties" on the second tab you will get the option restore setting default.
Posted on Aug 31, 2009
drifterK
  • 4924 Answers
SOURCE: MY CD OF DOT MATRIX PRINTER EPSON Lq-1150
http://www.epson.com.sg/epson/drivers/driver_download.htm?dc=1&mode=3&m=false&catid=2&pid=679
select the operation system and download...I believe that it is a all windows driver ...
after that install it if it is an installer and plug the printer ..if it is not an installer but just a folder ...unzip..place it in a location on desktop..and run the add new hardware wizard from the control panel...
choose to install from a specific location ..and browse to point it to the folder you downloaded..
this will install the printer and it will make it work ..
Posted on Jan 27, 2010
When printing invoices, the first page skips one line, the second page 3 lines and so on throwing all of the invoices off. Any ideas on how to fix this?
Set the page length at the printer's settings according to the real page length. If your paper is punched on it's sides, you can compute the real length knowing that the punches are 1/2 inch each other (or you can simply measure it). For more details, please specify the type of software you are using (ms-dos, windows, etc).
Mar 08, 2011 | Epson LQ-590 Matrix Printer
My printer is EPSON LQ-1150 II. It is not working with windos xp os. when installing it ask xp. cd. but the system regets it and ask again and again epson.dll. how can i get it.
Hey dude,
Ty to install the epson compatible 24 pin driver fom the add printer Wizard .It woks well with the EPSON LQ-1150 II.if it again asks for the windows xp cd run "regsvr32 dllfilename.dll" where dll file name is where you gets from the windows xp test page.Hope it'll work
Mar 07, 2011 | Office Equipment & Supplies
Restore setting default Epson LQ 1150 Printer.
my have a problem that my printer lq 1150.i do not uderstand page setting and how change iterface mode this printer
Aug 11, 2010 | Office Equipment & Supplies
Skips one page while printing on continious sheet
kindly adjust the page length setting.for more information visit this page it will help you to do the setting
http://support.epson.ru/products/manuals/000419/lq2180ug_e.pdf
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 26, 2010 | Epson LQ-2180 Dot Matrix Printer
Epson LQ-2180 continuous printing problem
The default paper height is 12". If you want to change it to 11" you should refer to printer manual and follow the steps. Otherwise if you are using a software for printing. Ask your developer to give following command for setting paper height
Chr(27) + Chr(67) + Chr(0) + Chr(11)
Mar 09, 2010 | Epson LQ-2180 Dot Matrix Printer
EPSON LQ 1150 Roman letter two last two Can not print in foxpro
best way to come out of this problem is to fire your printing using an batch file
ex.
set print to scrn.txt
set prin on
? 'hello'
? 'welcome to fast printing'
set prin off
set prin to
run fastprin
create fastprin.bat file
edit fastprin.bat
@echo off
type scrn.txt >PRN
then execute the above program
Mar 04, 2009 | Epson LQ1170 Matrix Printer
Page setup
see the paper length you are using
ex. 8.5 X 12 "
set the paper length programatically by using following command
?? chr(27)+chr(67)+chr(0)+chr(12)
Jan 09, 2009 | Epson LQ-2180 Matrix Printer
INSTALLATION OF LQ-1150
no need of installation cd .go in to the add printer wizard it is given there.just select epson and then the model number of your priter. connect the wires proprly it will work.
Aug 16, 2008 | Office Equipment & Supplies
How to set page length in computer for dot matrix printer model wep 800DX
to set up page length in inches
?? chr(27)+chr(67)+chr(0)+chr(12) - for 12" page length
to set up page length by lines
?? chr(27)+chr(67)+chr(50) - for 50 lines / page
Jul 20, 2008 | Epson LQ-2180 Matrix Printer
236 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
