Question about Vizio VF551XVT 55 in. HDTV
New LCD TV, horizontal grey lines, vertical grey bands
Just got the TV, and it has a clear blue bar running vertically along left side of screen, about 1 inch, not affected by screen positioning. As for the picture area itself, there are vertical bands, like trails, which result from the menu data - like the channel numbers. The width of these grayish columns is dependent on the width of the data. Lastly, whole screen has horizontal thin gray 1cm lines in height like writing paper. (I'm about to send the TV back but figured I'd ask). Thanks.
  • 103 Answers
SOURCE: blue vertical stripe
The bad news, it sounds like tou have a bad plasma panel.One of the vertical drive arrays are in the process of failing.This part is part of the display panel.
Posted on Mar 03, 2008
jerryg50
  • 1667 Answers
SOURCE: Blue color spread over the pictures
This sounds classic to a thermo problem where a part(s) are becoming thermo sensitive with aga and use. When the set is cold and then warmed up, the defective part(s) is changing characteristics.
Some components became thermo sensitive that are driving the display. Or an embeded component in the display itself became thermo sensitive. It is very possible that the fault is on the board that does the X - Y addressing or on the backplane electronics of the display screen itself.
Using the set with defective components is a bad idea. If the part(s) fail completely and go shorted or opened, other more costly damage can be done.
The service rep for the manufacture of your set is equiped and trained to be able to troubleshoot and service your set.
You will have to take the set in to have it serviced.
Jerry G.
Posted on Apr 17, 2008
SOURCE: LCD TV - Vertical Blue line
use menu and h/v then change then move to higher level and it will take it away.
Posted on Aug 24, 2008
DRACO A5OG
  • 22 Answers
SOURCE: Vertical Red Line
Fixed!
Spoke with PartStore.com, rep stated 6871QCH038C (038C) is the superceded replacement for the defective prone OEM 6871QCH038A (038A). They and others offer the 6781QCH060Q (060Q) for $50 - $100 more. I opted for the 038C, but I was concerned about the title of the part which states "HAND INSERT"... PartStore.com rep stated it is in fact a board and there is no soldering needed, just "plug and play". DONE, paid only $120.95 + next day shipping for $29.95.
Since I took the TV apart before, it was a breeze and took about 2 hours, start to finish.
Important note, remember to remove the two 1" square spunge type heat sinks/pads the new board needs those for a proper installation and protection of the certain component.
Also you need two small zip ties to replace the ones you are going to clip off.
Added Bonus, the new board fixed other issues:
1. At times I would get a squeegly red line go across the screen. I thought it was the source (cable) but it is gone now.
2. Screen Shift, when I use the XBox for Games or DVD/HDVD the screen would shift. Very annoying, prior to swap out, recently the screen started to shift watching cable. Now it is no-longer an issue.
I am really pleased with my DIY repair and wanted to share.
The damn Vizio Out of Warranty Service wanted $360 for a service call which included the part for $125 plus they take my bad board for exchange.
6871QCH038C $120.95 http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenit h/6871QCH038C/New.aspx
Over Night Shipping #29.95
Posted on Dec 31, 2008
freetek
  • 5568 Answers
SOURCE: left half of screen is filled with vertical
If I am right, this is an expensive problem.
The minute pixels that make up the display are turned off and on by circuits arranged in an X-Y matrix. To avoid using one circuit to control each pixel, the circuits are rapidly scanned at a rate higher than the eye can detect.
One or more of the circuits that do the scanning have failed on your set and the ugly part is, the display panels often have these mounted on the display itself forming a 'package' that speeds assembly and are made only by a few companies. If yours is one of these, the entire panel would have to be replaced since the integrated circuits used are very small and have pin spacings that pretty much preclude replacement by hand since they were originally placed by robots.
I hope for your sake the display panel and its control circuits are separate and the panel is still fine since the cost of an integrated replacement may prove to be about 1/2 to 3/4 of the cost of a new set.
Posted on Dec 12, 2009
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
I have a Vizio M47ONV. Left TV outside and think
In my 30 years that\'s another first for me.. I guess it depends on location. It sounds like a panel issue. The ammonia in it will destroy it fast!
Oct 13, 2013 | Vizio VO47L 47 in. LCD TV
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
1" Band from top to bottom
you need a new panel get it fixed now before it gets really expensive. call up the manufacture to see if they have an out of warranty service or replacement for your tv...
Oct 25, 2008 | Toshiba 32HLC56 32 in. HD-Ready LCD...
Picture disappears
My Konka LCD model KDL32AT23U Displayed a picture, then vanished, showing different colored vertical lines in horizontal blue bands.Then I could not turn it off with the remote or standby button on the side.Only with the main switch.What's wrong??
This is the same problem posted by kukish on july 26,2008
Jul 26, 2008 | Konka KDL32AT23U 32 in. LCD Television
Shimmer and bands
i experienced a tainted vertical black lines on the boths sides of my lcd screen. There was no scratch or whatsoever that could be the reason why thsi balck colored vertical lines to spread. Hope you can help me solve this problem. Thank you..
Jul 12, 2008 | LG Flatron L1710M 17" LCD Monitor
Vizio VF551XVT 55 in. HDTV Logo
134 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
